Interesting! thanks alot Grnfinger
To everybody with watercooled MIIF.
Can you please post some pictures of your system? I need info, how do you connect CPU block with NBMax block. How long is the tubing, what is the bending radius and etc.
Thanks in advance !!
I dont use the NBMax I use the MCW30 but the concept is the same.
http://i237.photobucket.com/albums/f...DSCF0035-1.jpg
http://i237.photobucket.com/albums/f...DSCF0037-1.jpg
Anyone know what advancing the clock skew on the DRAM does? Does increase performance?
I"ve advanced mine to 350ps and am testing Large FFT's on prime with 480fsb & 8.5multi..
why won't this board do over 500fsb :shakes:
Grnfinger, what brand tubing is that? i can't get the tubes to not kink when connecting the CPU to the NB block.
This is world record Maximus II Formula 610 FSB of air, and this is just the beginning:
http://valid.canardpc.com/show_oc.php?id=526302
Congrats Simone, nice work. What vNB did you use?
Yes but with multiplier 6 , why don't you try 8x585 i want to see 20 loops IBT I just can't do it.
very nice Simonix,looking forward to more high fsb runs from you.keep pushing
Simonix
Very nice :up:
529th
MIIF can rock quads as good as duals.
630 DI FSB
http://valid.canardpc.com/show_oc.php?id=526483 :shocked:
I use Primoflex and the stuff Swiftech sells, I do believe that photo is of the 7/16th Swiftech tubing.
Tygon will not kink nor will the chepo stuff from home depot, my only gripe with home depot tubing is that it gets cloudy after a while, no problems if you use dyes but if your running clear water than its not so nice.
450FSB on the 333 strap should post with ram set to 1081MHz.
See if you can post with that setup, if so I have a few memory tweaks to get you some decent bandwidth,
VERY VERY NCE!!! :up:
I'm beginning to think that the board runs very well when cold
