Just got the ip-35 pro today and i got the damn C1 error, reseated the memory and moved it around for a good hour and still cant get it to boot.
i dont have another stick so im screwed.
ive tried everything and i still get the C1 error, i already started a rma so we'll see how that goes when i get the new memory back.
thats if the memory really is the problem.
My IP35 Pro is on its way from Clubit! Should i be using BIOS 11 or 14. Im planning on doing the bolt mod leaving the TIM pads in place. I have a Thermaltake Armor Case with a 25CM side intake fan. Do you think I still need the the 40mm fans for the NB and Mosfet area
Hello,
I just got my board and am trying to overclock my Q6600.
But How come the the lowest Vcore voltage I could go is 1.3125 ?
Aren't that too high ? Even or 3.2GHz ?
How do you adjust it lower ?
Thanks in advance ! :up:
http://www.canadacomputers.com/main....80&cid=RAM.812
Does anyone know if that ram is compatible with the IP35-Pro board or should I just get some of these?
http://www.canadacomputers.com/main....08&cid=RAM.812
Basically, I'm looking for memory that I don't need to screw around with. Just plug it in and go. No C1 errors or fiddling with a cheap stick to get the system up and running. Thanks for the help...
i thought that was code for a sledge hammer mod...LOL:D
the better it is for what?
there was/is a legend that if you have a low vid, that its a good overclocker. the only rhing that a low vid means is exactly what it is meant to be - it will run the default speed stable, at that vcore. the only other correlation i know of is that quads with low vid generally run much hotter at higher than default vcore than quads with higher vid, ie my 1.2v vid chip runs hotter at 1.3v vcore than some other guy's 1.275 vid chip does at 1.3v vcore.
Intel have revised the voltage specs for all C2D processors, the spec is now 0.85 - 1.5v :D
Link to Intel processor finder : http://processorfinder.intel.com
Link to the Q6600 SLACR spec : http://processorfinder.intel.com/det...px?sSpec=SLACR
CN :)
Ahhh, so the Vid doesn't really matter.
I have another question.
I am running Prime95 stress test on my Q6600.
It runs 100% stress on all 4 core at first.
But on the 2nd hour, it lowered to 75% stress, with the 2nd core at 10%.
Is there anything wrong ? :confused:
Though No error is shown on Prime (I checked Round off checking)
NOTE: I clocked CPU at 3.2 (356x9), with 1.3325 Vcore.
Is there any talk of Xtreme front side bus OCing in this thread I'd like to hit 500Mhz. right now I'm at 465. Definitely can feel the difference between. 395 x 9 and 465 x 7. What should I up to go further.
MCH @ 1.41
ICHIO @ 1.6
EDIT: thats funny now in windows it says I'm doing 465 x 9. What a glitch.
EDIT #2: and coretemp says I'm doing 597 x 7. I'm just an amazing OCer.
Your CPU volts are extremely low for an OC of 3.2ghz. I would put it to at least 1.40V. I know most Q6600 owners with this board will go to 1.50V because the vdroop on this board is pretty big. For example, my Q6600 has almost a .06V vdroop during load which makes an effect 1.44V if I select 1.50V in BIOS.
You can safely start at 1.40V and work your way up from there. You may need to increase other voltages as well as you increase your OC.
I would definitely use the 14 BIOS since the 11 BIOS that ships with most boards (I still believe that's the case) is almost 4 months old. I think most agree that the 14 BIOS is more stable than the 11 and provides better chance for greater OC.
As for your cooling, it all depends on where the 25CM fan is blowing. The PWM heatsink will get the hottest so if you put a 40mm fan on anything, I would put it there. I have the bolt mod installed and 2 40mm fans, one on the NB and the other on the PWM. Honestly, the 40mm fans push so little air that I'm not even sure it's doing anything. I know my CPU tuniq tower 120 heatsink is doing the majority of cooling on the PWM and not the silly 40mm. It's your choice. Your 25CM likely puts out a lot of air flow so if it's directly over the PWM or NB heatsinks, then I don't believe you will need any additional fans.
As for my PWM, it gets bloody hot even with a 40mm fan and the bolt mod installed. After 1 hour of Prime95, my PWM will be over 80C!! It's unreal.
