Originally Posted by halo112358
Seems like it's doing well - I'm going to run Orthos overnight tonight, I'm at 2.833/1.425V right now and I've got great (for air) load temps. I still need to test my ram and my cpu independently to figure out what's causing instability above ~312x9 (ram is UCCC g.skill HZ on ddr333 divider). I'll know more after more testing, if I remember right I've run this ram on this motherboard up to ~265 at 3-4-4-8 but I might not have known about the a64 memory divider at that point so that could be false. I'll know more in a few days. I think the bios is limiting things more than anything else, my ABIT an8-ultra doesn't have the options that the DFI people have to really tweak my ram for the best OC.
After I have a good 12h stable dual prime setup I'll isolate cpu & ram and try to go further, right now I just want to know what a reasonable 24/7 OC is so my girlfriend can use the machine while I'm at work.
I also have the rest of my watercooling loop on the way from petras (storm + ddc-2 & pa120.3 = :toast:), if things work out maybe I can get 3.0+ out of this chip :D
ps: I bet your opty 165 LCB9E is like my CABYE opty 148, it needs really good cooling (nice water cooling or waterchilling) but can clock really well. I noticed that with opterons, they seem like they OC well with air but they perform *very* well with water or other cooling. The trick seems to be to keep the core temp down around 50'c or lower under load, then the machine is rock stable.
Out of curiosity, what is your full load (dual prime) temp and what is ambient?
