Finally after several hrs. of Pi, I was able to get under 10.09.000. I did need to raise vcore but was able to lower MCH. Also ran PCI-e freq. @101. Idk if that mattered. I tried for a long time to do lower vcore, but that was not happening.
[IMG]http://img12.imageshack.us/img12/5737/32m4807f.jpg[/IMG]
Code:MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 9
Fine CPU Clock Ratio...................: 0.5
CPU Frequency .........................: 4.807GHz (506X9.5)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 506
PCI Express Frequency (Mhz) ...........: 101
C.I.A.2 ...............................: [Disabled]
Advanced Clock Control
CPU Clock Drive........................: 900
PCI Express Clock Drive................: 1000
CPU Clock Skew (ps)....................: 50ps
MCH Clock Skew (ps)....................: 100ps
DRAM Performance Control
Performance Enhance....................: Turbo
Extreme Memory Profile (X.M.P.)........: Disabled
(G)MCH Frequency Latch.................: 333MHz
System Memory Multiplier ..............: 2.40D
Memory Frequency (Mhz) ................: 1214MHz
DRAM Timing Selectable ................: Manual
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
Advanced Timing Control
Everything In Advanced Timing Control on auto.
but tRFC 56 and Drive Strength Profiles OC-1200
DDR Write Training: Disable
Motherboard Voltage Control
CPU
Load-Line Calibration..................: [Disabled]
CPU Vcore..............................: 1.4375V
CPU Termination........................: 1.36V
CPU PLL................................: 1.61V
CPU Reference..........................: 0.901
MCH/ICH
MCH Core...............................: 1.40V
Reference..............................: 0.801
MCH/DRAM Ref...........................: 1.13v
ICH I/O................................: 1.5V
ICH Core...............................: 1.100V
DRAM
DRAM Voltage...........................: 2.26v
DRAM Termination ......................: Auto
Channel A Reference....................: Auto
Channel B Reference ...................: Auto
