:toast:
Your welcome
:toast:
Your welcome
Here's 1004 for those of you having trouble downloading of asus slow ass server I put it on mine: www.tonysmod.netfirms.com/downloads/P5BD1004.zip
I have NEVER gotten ANY OC Profiles to work worth a DANG after doing a BIOS FLASH with ANY Asus motherboard i own. That includes the P5B Deluxe WiFi, a P5W DH Deluxe, and now a Striker Extreme.Quote:
Originally Posted by Blackoberst
Each BIOS upgrade does some jacked up $hit to the profile. It wil let me load them, but on the next boot, the system just acts like a total window licker.
Bad part is, i had a 500Mhz overclock going and totally dicked the dog with the profile and can't remember the votlages I was using. Now, i have to waste time trying to find the sweet spots again. Should have taken a picture and banked it.
STUPID STUPID ME
Yeah oc profile is only good for the bios you saved it on.
just got my p5b-d(sold the old 975x/g).
all I can say so far is wow. I can get this X6800 stable @ 1.54V 3.8GHz, on the dfi it wouldnt even POST even @ 1.6V.
also my OCZ PC8000 XTC XE is flying. currently Orthos blending 1112MHz@2.4V 4-3-3-10. again on the DFI I needed 2.55V to get it stable @1100MHz.
also FSB of course just @ 445MHz at the moment and the DFI wouldnt blend orthos for 1 second above 420MHz.
I love this motherboard!:D
cant edit?????
anyways any difference noticed between 1004 and 0910(which Im running)?
http://www.xtremesystems.org/forums/...d.php?t=131518
read the Kunaak post, I test my Patriot 6400LL and the timings now are tight
hmm that sounds good. flashing now. ;)Quote:
Originally Posted by Gam3Ra
hey nicepun , you're the guy who found about the 10th , as i recall :clap:
I wish there was someone like TicTac of NF7-S Ver2.0 to tweak the BIOS..
Get Rid of Q-Fan to give SpeedFan full control
Bring SoundMax up to its promises - players tell me I sound like I'm talking from the bathroom , and the damn background noises while recording voice :slapass:
And perhaps find a way to OC with OC , as I promised a friend I won't be naughty again :woot:
Honestly i haven't tried the option, but I think u are supposed to select AC97 option instead of HD audio. I will check the bios option when I get back from work and write it down to you. Anyway regarding your obesrvation about 1 thing doing both bolded stuff. Every sentence is a standalone step that is supposed to be tried. And they are placed in certain order, which means e.g. if step 1 fails to make any difference try step 2 (or in this case next line). Anyway today I will revise the manual, since many new stuff happened, and perhaps add a better few explanation here and there.Quote:
Anyway to keep my onboard sound ang reduce boot tines? when I followed thiese instruction my boot times were 2=X as fast, but I get no sound at all. What did I miss here. When I do the first bolded item, the second is already done when I reboot.
Me, i have apacer 512 MB . But I still havent tried renaming the file, so today when i flash new bios I will try, a report back.Quote:
Anyone having problem with EZ Flash 2 + usb drive?!
:slap:Quote:
STUPID STUPID ME
Moral of this story is : write down your settings to paper or e-doc . Man that without a doubt trusts his computer, is like an animal trainer believing that without a wip he could command a hungry tiger.
Yes! I sounded like that, then i messed around with volume levels in soundmax, and it dissapeared. Have u engaged your mic boost? I enable it, then i reduce volume of mic... dont know maybe it helps.Quote:
Anyway I got response from asus support regarding that question about type/name of intell AHCI controller used on thius mobo. I swear to God, ppl working for them either dont know english very much or are complete retards (or they think we all are) This is what i sent and what they replied
:slapass: :fact:Quote:
ASUS CASEID=RWTM2007012528124513-279 Please click here if you wish to reply this mail !Please click here if you wish to reply this mail!
How would you rate the quality of this mail?
Poor 1 2 3 4 5 6 7 8 9 Best
Dear sir/madam,
Thank you for contacting ASUS Customer Service.
My name is Penny. It's my pleasure to help you with your problem.
The AHCI driver is installed when you install OS. Please make the floppy Raid driver disk from Support CD. Then when you install OS, please press F6 to install the AHCI driver in the floppy disk.
If you have any problem, please refer FAQ(Frequently Asked Questions) or contact us again. We will try our best to help you.
http://support.asus.com/faq/faq.aspx?SLanguage=en-us
Sincerely,
Penny
ASUS Customer Service Center(China)
---------- Original Message ----------
Sent : 2007-1-25 2:10:47
To : "tsd@asus.com.tw"
Subject : <TSD> Motherboard P5B Deluxe/WiFi-AP
[CASEID=WTM2007012528124513]
[Problem Description]
I wanted to know which drivers to install for AHCI intel controller from 4 drivers available
http://img180.imageshack.us/img180/2...idrivervc1.jpg
Thank God that ppl on this forum are smarter then asus support, acctually many of u should get payed for doing their job :toast:Quote:
Dear Miss Yang,
As I stated in my email, i want to know which driver to install for AHCI from 4 given as option in intel drivers folder. I do not want to install by F6 procedure or by slipstreaming drivers to windows install cd. If u can tell me the name of controller driver that is displayed when intell controller is set to AHCI mode, thank you, eitherwise you are wasting my time.
Looking foward to hearing from you,
Sincerely your,
Angelico Payne.
What do u think I rated this reply from 1-10, not that it matter so them anyway? :rolleyes:
Anyone tried 1004 ? Anything new and worthy to mention ?
R.
changelog:
1 Enhance memory compatibility
2 Support CONROE E0 CPU(FSB 1333)
Anyone here flashing using ez flash?! I'm having trouble with it!
Please read my thread:
http://www.xtremesystems.org/forums/...d.php?t=131413
just flashed to 1004 and everything seems to be normal, my bios settings didnt get reset either like what happened with 910 lol :)
Uhm. then I'll wait a bit more. Nothing in there for me, my memory works OK and my CPU is already @ 1333 :DQuote:
Originally Posted by webwilli
Originally Posted by Stx
maybe you didn't do it correctly then.... a successful bios flash will erase all settings.
mm i used EZFlash and everything is fine, what did you use?Quote:
Originally Posted by Elisha
LOL - same thing I was thinking :)Quote:
Originally Posted by runmc
hello old friend.....how goes the battle? :toast:
i used EZ flash as well but i reverted back to setup defaults before i flashed it.
well there doesn't seem to be anything wrong, i only set the stock fsb and multi before I flashed. I used 910 before it and used Asus Update for that, which did erase the settings.
you need to load setup defaults and not just set multi and fsb to stock.
Anyone else have to up vcore with the 910 bios? I was able to boot fine at 1.325v at 410x8, now I had to raise it to 1.375v to boot into Windows. Running Orthos now, hopefully I can nudge it down a little bit more.
yup i had to bump it from 1.625V to 1.65V in BIOS to get it stable again... i have a feeling im going to go back to 0804 soon... i dare not try 1004Quote:
Originally Posted by sluzbenik
EDIT: just went back to 0804 and now is nice and stable at 1.625V again :)
OK so now I"m baffled... Last night I go to change some settings around and my board started acting completely...NORMAL... I didn't have to use any extra sticks of RAM to get it booted... I played around with the multi and the FSB and the strap and the nb settings and the board acted like it was suppose to....
I was all ready to send this sucker back and OUT OF THE BLUE literally the first time since I've had this particular board it acts like it's suppose to....STRANGE.
I was running at 450x7 then decided to go with 400x9 which boots but wouldn't load windows...even when I upped the cpu voltage to 1.475.... It actually booted at 400x9 at 1.4 but of course wouldn't go into windows so I started upping it and still couldn't get it to load... finally I settled on 380x9 @1.47 and my memory is at like 800something... Any ideas or tips on getting it stable at perhaps 400x9 and RAM@ 1000+?
Yes, it was me.Quote:
Originally Posted by Ancient1
Is there a difference between the WiFi and non-WiFi BIOS version?
