Woww nice temp m8te !! Which cooler PangingIII ?
What kinda temps running small fft's Pangin? Very nice Overclock
EP45T-UD3R (DDR3), E8400 Thermalright ultra 120 extreme (black color one)
Max CPU FSB ( at CPU multi 7x ) CPU-Z validation on air
http://img245.imageshack.us/img245/4...0428193755.png
Max CPU FSB ( at CPU multi 7x ) 1M SuperPi
http://img204.imageshack.us/img204/5...0428193904.png
Max CPU FSB ( at CPU multi 7.5x ) 1M SuperPi
http://img410.imageshack.us/img410/3...0427174653.png
******Gigabyte EP45 UD3P******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 ]
Fine CPU Clock Ratio............................[ + 0.5 ]
CPU Frequency 4.25GHz............................[ 500x8.5 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 500 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive..........................[1000mV]
PCI Express Clock Drive................[1000mV]
CPU Clock Skew..........................[0ps]
MCH Clock Skew..........................[50ps]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
MCH Frequency Latch.........................[ 333 ]
System Memory Multipler.........................[ 2.40B ]
Memory Frequency 1066............................[ 1200 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.12125 ]...................[ 1.350v ]
CPU Termination [ 1.20 ]...................[ 1.320v ]
CPU PLL [ 1.50 ]...................[ 1.450v ]
CPU Reference [ 0.760 ]...................[ .861]
MCH Core [ 1.100 ]...................[ 1.360v ]
MCH Reference [ 0.760 ]...................[ .876 ]
MCH/DRAM Reference [ 0.900 ]...................[ 1.000 ]
ICH I/O [ 1.500 ]...................[1.500 ]
ICH Core [ 1.100 ]...................[ 1.100 ]
DRAM Voltage [ 1.800v]...................[2.100v]
DRAM Termination [0.900v]...................[.920v]
Channel A Reference [0.900v]................[1.000v]
Channel B Reference [0.900v]................[1.000v][/QUOTE]
Channel A&B Driving and Timing Settings OC1200-PL8.
Just got some OCZ Reaper pc2 9600, can't get them to run the rated speed with PL8. My Dominator 1066's will do 1200-PL8.
Can someone help me with these UD3 models?
There are now 8 of them on Newegg.
I just want the one tat has full feature overclocking and no other bells and whistles.
It's not like me to ask questions of this nature but ive been looking for over an hour and I still cant' sort them all out.
Thanks.
Can someone with 2x2gb pc8500 OCZ reapers post their settings? I just got these yesterday and can't seem to get them to run anything under CAS 5 PL10
Heh bluestang, how do you like that F9 Bios for the UD3R?
well the computer i built for my buddy using my old GA965P DQ6 bit the dust (capacitor went bad) soooooooooo.....i used that as an excuse to sell him my X38-DQ6 (at an awesome deal for my friend $60) and buy myself an EP45-UD3P...... i cant wait to see what this board is all about :)
Does SetFSB work with the EP45-UD3P and if so which clock generator should I use?
Also do the new BIOS revisions help with high(520+) quadcore FSB at all?
Here is the clockgen you want for UD3P >>
ICS 9LPRS914EKLF
ud3p/1.2875vider/thermalright ifx14/gtx285/areca1231/4xssd
http://img364.imageshack.us/img364/442/69412646.png
more than "justa screenshot" ;)
i could probably get it to bench nicely @ 4.8 if time permits..
I have been trying to get 32m with only 1.375v and finally got it last night. Bios info incl. I wanted to use lowest volts. possible. KHX 9600 rams.
[IMG]http://img67.imageshack.us/img67/7871/32m11375.jpg[/IMG]
Code:MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 9
CPU Frequency .........................: 4.707GHz (523X9)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 523
PCI Express Frequency (Mhz) ...........: 100
C.I.A.2 ...............................: [Disabled]
CPU Clock Drive........................: 800
PCI Express Clock Drive................: 800
CPU Clock Skew (ps)....................: 50ps
MCH Clock Skew (ps)....................: 50ps
Performance Enhance....................: Turbo
Extreme Memory Profile (X.M.P.)........: Disabled
(G)MCH Frequency Latch.................: 333MHz
System Memory Multiplier ..............: 2.40D
Memory Frequency (Mhz) ................: 1255MHz
DRAM Timing Selectable ................: Manual
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
Advanced Timing Control
Everything In Advanced Timing Control on auto.
but tRFC 56 and Drive Strength Profiles OC-1200
DDR Write Training: Disable
CPU
Load-Line Calibration..................: [Disabled]
CPU Vcore..............................: 1.375V
CPU Termination........................: 1.34V
CPU PLL................................: 1.61V
CPU Reference..........................: 0.873
MCH/ICH
MCH Core...............................: 1.34V
Reference..............................: 0.768*
MCH/DRAM Ref...........................: 0.910v
ICH I/O................................: 1.5V
ICH Core...............................: 1.100V
DRAM
DRAM Voltage...........................: 2.24v
DRAM Termination ......................: Auto
Channel A Reference....................: Auto
Channel B Reference ...................: Auto
very nice coop!
@Leeghoofd: I'm eatin' my nuts on the dividers with my crucials mate !!
Even reached 1800 (cas10 lol) @450FSB and 2,18 vDimm (with the F6 bios and a E8600)
I'm following your I4 datasheet and improving it a bit :D than I'll post my results here when it'll be ready.
What I can say ATMO is that the dividers and the FSB don't react simply ^^ ...what's passed @400 or 450 isn't @425 :/
Risin' thru the night (500+), tweakin' tomorow if I'm not dry xD
