thats bad :(
hope they release a new bios that supports memset :)
memset are very useful.
tnx for the hard work felix :D :clap:
DJSUB:...i like it when you and others fix your own big problems...good show!:up:
http://img513.imageshack.us/img513/9...441tbi2ge5.jpg
I've been able to run 600MHz 4-4-4-4 1T (see pic) with the IP35 Pro, but this ***tty mobo doesn't let me boot at 1280+. The same RAM does superpi 1M at 700MHz 5-5-5-15 with Blitz Formula, so it's a mobo problem.
Too bad, ABIT. :slapass:
you are doing GREAT!...not many can run at DDR1200 at CAS 4.:up:
How does this board perform with 4x1GB? I have 4x D9GMH dimms that'd like to use.
just placed an order for the abit ip35 pro.....My Ausu P5K died so its out on RMA so i got the abit to replace it.....My question is do I need to touch the voltages on the nb for fsb between 450-490fsb? And any other voltages that need to be upped for this type of oc besides the cpu
I had the problem with values not being applied on my AW9D-Max. Turns out that if I disable Vanderpool technology it won't let me save any values and reverts to a default. I have to have it enabled in bios all the time. I know its not the same board, but its exactly the same symptom, so worth a shot I think. GL :).
Ive got 4X1GB of Gskill @ 8X450 runing most smoothly. I'm unable to get 8X475 to run. Need to use the 9X multi for 3800+Mhz
I run my IP35-E 24/7 at 475 FSB with 5:6 memoryratio, MHC@default, ICHIO 1.5@1.65. If i keep ICHIO at default programs crashing when i boot to windows. Picture
thank you ace-a-rue and jolly
board is on its way prob have it tomorrow
Here are photos of a v1.00 and v1.10. I do not notice a difference.
http://picasaweb.google.com/gibson.e...0AndV110Photos
different caps near the bottom... near the corner look taller?
Sure, sorry :)
2,5v set in BIOS.
Thank you. :up: :)
I can't get mine over 600mhz either...I give up on it.:down:
add one more owner to the thread... http://www.xtremesystems.org/forums/...d.php?t=162123
shipped today... weee! new build approaching this weekend...
Thanks for all the reads here, good stuff... :)
Slight difference between the top PCI-E and PCI slot....
http://img.photobucket.com/albums/v150/new-b/v11.png
There's no need to run 1180-1200 to get those kind of Super_Pi results...
