Holy Cow makes my head hurt.... thanks for the explination.... I think I get it now. I will resume testing tomorrow. Hitting the hay. Catch you on the flip side. Thanks again for all of your help. I will give those settings a try and post back...
I know, I had headaches with that too until it took me a few weeks to understand references let alone on the UD3P but one day it just clicked and I understood them....and np for the help
God I gotta get one of these boards!
Jsunn, stay in this range:
CPU Ref = from (CPU Term*0.63) to (CPU Term*0.66)
MCH Ref = from (CPU Term*0.63) to (CPU Term*0.66)
here is a chart that might help
ET6 0.730 / 0.745 / 0.760 \ 0.785 \ 0.800
vtt 1.20 0.730 / 0.745 / 0.760 \ 0.785 \ 0.800
vtt 1.22 0.742 / 0.757 / 0.772 \ 0.797 \ 0.812
vtt 1.24 0.755 / 0.770 / 0.785 \ 0.810 \ 0.825 CPU reference value in bios
vtt 1.26 0.768 / 0.783 / 0.798 \ 0.823 \ 0.838
vtt 1.28 0.780 / 0.795 / 0.810 \ 0.838 \ 0.850
vtt 1.30 0.793 / 0.808 / 0.823 \ 0.848 \ 0.863
vtt 1.32 0.806 / 0.821 / 0.836 \ 0.861 \ 0.876
vtt 1.34 0.818 / 0.833 / 0.848 \ 0.873 \ 0.888
vtt 1.36 0.831 / 0.846 / 0.861 \ 0.886 \ 0.901
vtt 1.38 0.844 / 0.859 / 0.874 \ 0.899 \ 0.914
vtt 1.40 0.856 / 0.871 / 0.886 \ 0.911 \ 0.926
vtt 1.42 0.869 / 0.884 / 0.899 \ 0.924 \ 0.939
vtt 1.44 0.882 / 0.897 / 0.912 \ 0.937 \ 0.952
vtt 1.20 0.720 / 0.740 / 0.760 \ 0.800 \ 0.840
vtt 1.22 0.732 / 0.752 / 0.772 \ 0.812 \ 0.852
vtt 1.24 0.745 / 0.765 / 0.785 \ 0.825 \ 0.865 MCH reference value in bios
vtt 1.26 0.758 / 0.778 / 0.798 \ 0.838 \ 0.878
vtt 1.28 0.770 / 0.790 / 0.810 \ 0.850 \ 0.890
vtt 1.30 0.783 / 0.803 / 0.823 \ 0.863 \ 0.903
vtt 1.32 0.796 / 0.816 / 0.836 \ 0.876 \ 0.916
vtt 1.34 0.808 / 0.828 / 0.848 \ 0.888 \ 0.928
vtt 1.36 0.821 / 0.841 / 0.861 \ 0.901 \ 0.941
vtt 1.38 0.834 / 0.854 / 0.874 \ 0.914 \ 0.954
vtt 1.40 0.846 / 0.866 / 0.886 \ 0.926 \ 0.966
vtt 1.42 0.859 / 0.879 / 0.899 \ 0.939 \ 0.979
vtt 1.44 0.872 / 0.892 / 0.912 \ 0.952 \ 0.992
CPU Ref in ET6 = CPU Ref in BIOS / CPU Term * 1.2
MCH Ref in ET6 = MCH Ref in BIOS / CPU Term * 1.2
or
CPU Ref in BIOS = CPU Ref in ET6 / 1.2 * CPU Term
MCH Ref in BIOS = MCH Ref in ET6 / 1.2 * CPU Term
Hi everyone, here is another problem which i really hate about this motherboard, it says it has dolby sound onboard, hell this oboard sound is the worst ever cause it doesn't work (i know i should get a creative or asus sound card but that's why i bought ud3p instead ud3r for the sound) In vista 64 sp1 when i use any realtek drivers the sound is not installed properly cause under realtek hd audio manager it doesn't know how to configure 5.1 settings right. It disables the rear speakers and it enables the sides speakers which are only available on the 7.1 ch sound speakers. The windows drivers configure the sound as 5.1 sides off rears on without any issues (detected also on the winamp output plugin) i even have speaker fill option available. The sound chipset is ALC 889A the same as on my brothers ep35-ds3r and to him the sound drivers are installed corectly on vista x64 sp1 as it should be on 5.1 configuration, sides off and rear on and also on the realtek console it has speaker fill avilable which i don't have. This is one hell of a buggy board and gigabyte doesnt have a support forum and they don't seem to be aware of the problem so i dont know what to do cause the sound doesn't have any amplitude and is very low in any way possible. I really dont understand why they didnt @ least fix the :banana::banana::banana::banana: sound on this board. My speakers are logitech g51
An issue with sound and it is a "buggy" board? Sounds like some frustration there. Computers, no to alike, often no explanation as to why soemthing is happening. Get used to it.
Here is a link to a forum with Gigabyte representation. Some good info available, as there is here.
http://forums.tweaktown.com/f69/index3.html
I have EP45-UD3R, E7200, OCZ Reaper PC9200 and stock cooler :D this is my first gigabyte MB and it was hard to understand UD3R bios, especially SPD multiplier menu:
http://s60.radikal.ru/i169/0904/be/d7e1f762546f.jpg
http://s51.radikal.ru/i131/0904/5b/5e0de62657ff.jpg
can anyone help me to get what are those 2.00b, 3.33c, and etc.
sorry for bad english :)
about buggy let-s not forget the 333 mch strap, and some voltage blanks ,very picky about memory my ocz 4gb reaper 1066, can't do 1066 pl6 on this board if it's not @ default settings, pLus some picky as hell damn references.
Thanks for info i will look into it, did youre sound drivers installed corectly on vista x64?
Kemocer.here are the the straps and their dividers.
200 strap: 3:4, 3:5, 1:2
266 strap: 4:5, 2:3, 1:2
333 strap: 1:1, 5:6, 5:8, 1:2
400 strap: 1:1, 3:4, 2:3
example:333strap-1:1=2.00B / 5:6=2.40B / 5:8=3.20B
thanks a lot :)
Don't know why I just noticed it but when overclocked does anyone elses board do this....When I first turn on in the morning (after shutting down at night and switching main power center/surge protector off) it does a quick power on (about a half second) then off then back on in about a second or 2 and continues to boot. It only happens when OC'd. Is it just my board or do any of you have this as well? Thanks!
Got a new Q9550 (had an 8500 that I hit 4.2 with, was doing more video work so i decided to get a quad core) , this oc is with 8gb of ram, havent stressed it so far but its looking good!
http://i281.photobucket.com/albums/k...77/screeme.jpg
bump, no one have any ideas for tweaking this setup?
http://img401.imageshack.us/img401/3345/19291988.jpg
boot Q9550 for the first time
@ 500x8 4.0GHz
http://img159.imageshack.us/img159/6...0429202043.png
http://img520.imageshack.us/img520/9...0429204026.png
http://img140.imageshack.us/img140/7...0429211527.png
@ 500x8.5 4.25GHz
http://img151.imageshack.us/img151/3...0429230257.png
http://img151.imageshack.us/img151/9...0429230115.png
@ 500x8 4.0GHz updated
http://img207.imageshack.us/img207/3...0430024309.png
Bout this moding of the cooler :
I've changed the pad of the NB whith AS5 and sanded the SB cooler which wasn't plane at all
Than it appears a massive hole inside, seen after a few second of scratchin' ^^ don't know yet what it will change, but I feel it's better now ;)
First look with my E8600 : some 570 FSBmax with all on "auto" , I'm gonna digg for now W&S
Hey guys sorry for the stupid question...
if i update to bios F9 (i have F8) i lost all my OC profiles ?, i have them on a pen drive, in case that i flash to F9 can i load them ?
Anyone saw any improvements on bios F9 in quads ?
Cheers
Sergio
YesQuote:
Originally Posted by andressergio
With others versions it's work.Quote:
Was finally able to get 500fsb Prime blend stable 9 hours, 500x8.5 on my q9550. Took me freakin forever..http://i587.photobucket.com/albums/s...rime500x85.jpg
nice o/c OC Nub! :)
EP45T-UD3R F6, Q9550 4.30GHz air-cooled
http://img9.imageshack.us/img9/6597/20090430222853.png
http://img9.imageshack.us/img9/95/20090430233626.png
http://img91.imageshack.us/img91/327...0430234948.png
http://img523.imageshack.us/img523/6...0501004236.png
http://img156.imageshack.us/img156/9...0501013831.png
http://img12.imageshack.us/img12/547...0501014607.png
http://img156.imageshack.us/img156/1...0501023643.png
http://img13.imageshack.us/img13/529...0501020955.png
