This is my first post on this forum, but I have been using this thread to build this machine (thanks Guys, your info helped a lot). Finally got everything running (purchased the mobo some time ago) and wanted to run a couple of my settings by the community and see what you guys think. The last time I overclocked a CPU was back in the slot 1 Celeron days..... My rig specs are below....
CPU-Z photo attached
Thanks,
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting : 9
FSB Frequency : 450
CPU Clock Skew : Normal
North Bridge Clock Skew : Normal
FSB Strap to North Bridge : Auto
DRAM Frequency: DDR2-1066 MHz
Dram Clock Skew CH1 A1 : Normal
DRAM Clock Skew CH1 A2 : Normal
Dram Clock Skew CH1 B1 : Normal
Dram Clock Skew CH1 B2 : Normal
DRAM Static Read Control: disabled
Dram Read Training : disabled
MEM OC Charger : disabled
Ai Clock Twister : Moderate
Transaction Booster : Manual
Common Performance Level: 10
PCIE Frequency : 100
CPU Voltage : 1.36250v
CPU PLL Voltage : 1.51325v
FSBT : 1.2v
DRAM Voltage : 2.1v
North Bridge Voltage : 1.32525v
South Bridge Voltage 1.5 : 1.5
South Bridge Voltage 1.1 : 1.1
Load Line Calabration : Enabled
CPU Sread Spectrum : Disabled
CPU Configuration:
Ratio CMOS Setting: 9
C1E Support: Disabled
Max CPUID Value Limit: Disabled
Intel Virtualization Tech: Enable
CPU TM Function: Disabled
Execute Disable Bit: Enabled
Load-Line Calibration: Enabled
CPU Spread Spectrum: Disabled
