looks great. how well do those hard drive coolers work as far as heat and noise?
yeah basically the same X backplate cept noctua has a pad on top the plastic sheet that you see on the TRUE's backplate. Prevents scratches or maybe even helps in a pressure mount. I'm just guessing. Oh there is a new Revision. If you look at their website you will see the changed the L775 mounting bracket so it fits on the asus rampage that should work for all motherboards. Thats what i got.
Thanks, I just wasnt sure if it used the same sized screws for the hole/thread. Looks like i'll be ordering one soon :up: .
Edit: Has anyone ordered from the heatsinkfactory.com ? Is it a trust worthy place ?
Don't like the color of your case, but nice cabling in there :)
Hey I built my new computer a few weeks ago so I decided to post a few pics of my new beast!
http://i240.photobucket.com/albums/f...Picture017.jpg
http://i240.photobucket.com/albums/f...Picture015.jpg
http://i240.photobucket.com/albums/f...Picture014.jpg
http://i240.photobucket.com/albums/f...Picture013.jpg
http://i240.photobucket.com/albums/f...Picture011.jpg
http://i240.photobucket.com/albums/f...Picture010.jpg
http://i240.photobucket.com/albums/f...Picture009.jpg
@ deepsilver... i have notice that you have spent so much on mobo and everything else is just really low... should of evened everything out instead blow cash on mobo, lol
First trials with a DSLR.....sry for posting the same hardware again and again. Next Week I'll get new parts :)
http://www.abload.de/img/_mg_7679nwi.jpg
http://www.abload.de/img/_mg_7689yy2.jpg
http://www.abload.de/img/img_769805f.jpg
http://www.abload.de/img/img_7712gxy.jpg
Aquacomputer Aquaero with selfmade Lian-Li-Brezel ;)
http://www.abload.de/img/img_7734ica.jpg
http://www.abload.de/img/img_773869z.jpg
gorgeous pics tommy. i want to get a lcd display at some point.
is that foam wedged between your hard drives tommy? additional to being sandwiched together, i bet they get even hotter with blocked airflow
Nice pics Tommy
This Noctua has a excellent performance
amazing pictures people :) good stuff. And Tommy, do you dust your hardware before taking pictures :P hehe They all look so new. Not a spec to be seen on the PCB.
Looking forward to your new hardware ^^. Hope the DSLR is fairing well with you. May I ask what model?
cheap ass built into a Chieftec Aegis....
@giorgos th. - Cable management FTW. What temps are you getting on the GX2?
Yo tommy, make me one of them, would go perfect in my PC-60 =]
:D
Some pics of my air cooling:
http://i247.photobucket.com/albums/g.../Imagen046.jpg
http://i247.photobucket.com/albums/g.../Imagen048.jpg
http://i247.photobucket.com/albums/g...magen061-1.jpg
http://i247.photobucket.com/albums/g.../Imagen051.jpg
http://i247.photobucket.com/albums/g...magen066-1.jpg
http://i247.photobucket.com/albums/g.../Imagen055.jpg
Regards!
i was never keen on cable management....i always have my case wide open so dont really need it...
as for the GX2,with the 12mm fan exausting hot air from the card,temps went straight down..
with 25C room temp,i have 53C idle - ~68C load with the fan permanently at 55%..
to Tommy or anyone else that have use the HR-11, was wondering if you could assist if I have enough clearance to add this on my vidcard:
advance thanks :up:
