Please Help me Optimize my O/C... UD3P & E8500
Hello,
I am currently sitting at 4Ghz (finally)
BIOS F9
E8500 E0 stepping
GA-EP45-UD3P rev 1.0
G. Skill 8800 @ 1130MHz 1.9V
Below is my template. I think I can do better with the volts on the motherboard, but since I am finally stable I am a little hesitant to do random changes.
My temps are OK, looking at mid to upper 30's during idle and I get right around 65ish deg during prime95 small FFTs. I saw as high as 74deg during intel's burn in test.
Please help me optimize my O/C.
Thanks,
J
PHP Code:
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 x ]
Fine CPU Clock Ratio............................[ + .5 ]
CPU Frequency 4.00GHz...........................[ 471x 8.5 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 471 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.........................[800mV]
PCI Express Clock Drive.................[900mV]
CPU Clock Skew..........................[400ps]
MCH Clock Skew..........................[300ps]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
MCH Frequency Latch.............................[ 333 ]
System Memory Multipler.........................[ 2.40B ]
Memory Frequency 1066...........................[ 1130 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.25 ]......................[ 1.41250v]
CPU Termination [ 1.20 ]...................[ 1.40v ]
CPU PLL [ 1.50 ]...................[ 1.610v ]
CPU Reference [ 0.760 ]...................[ .956v ]
MCH Core [ 1.100 ]...................[ 1.360v ]
MCH Reference [ 0.760 ]...................[ 0.866v ]
MCH/DRAM Reference [ 0.900 ]..................[ 1.11v ]
ICH I/O [ 1.500 ]...................[ auto ]
ICH Core [ 1.100 ]...................[ auto ]
DRAM Voltage [ 1.800v]...................[1.900v]
DRAM Termination [0.900v]...................[auto]
Channel A Reference [0.900v]................[auto]
Channel B Reference [0.900v]................[auto]__________________
Core 2 Duo E8500 @ 3.8GHz auto(v)
