Jor3lBR,
Wow, very nice numbers, but yes, prime is needed. No prime, the comparison is even less apples to apples as it already is.
I also see that your CPU is a 45nm, it will by definition need less volts to it its business on the same clock a 65nm will. That is independent on boards or anything. Its just a better and newer cpu. That is the major thing making the comparison even less fair.
I see the vPLL and vFSB you needed was lower then mine. But those are very cpu related, and this is a problem when comparing 45nm to 65nm cpus.
The vNB I used was lower then yours. I was on 1.23 on bios and 1.24 reported on everest, as you can see on pics. This voltage is much less cpu dependend that the others, but still, you are on 2x2gb mem, and I am on 2x1GB mem, which could explain it too.
I guess the only way to compare it, would be the same CPU running on each board. That would be the best. Or, second way, if I had a 45nm or you a 65nm. I don't have a 45nm. Do you have a 65nm quad by a chance? :)
Anyway, the numbers are good. Congrats. But as a comparison, it won't do, because the difference on the CPU's are much more then I imagined.
Anyway, this is what I get on the everest, for the mems clocked as yours. My write and copy values, are lower because I have less cache on the CPU (65nm vs 45nm). Every 65nm cpu will have lower write / copy. But the read / latency are unafected by the less cache and are fair comparison.
http://img296.imageshack.us/img296/2472/mf2qqn8.jpg
[]'s
Simps
