Here's how I calibrate the RealTemp test equipment.
Point Fluke temp gun outside and compare.
http://img89.imageshack.us/img89/893/ocweathergk8.png
Yep, looks about right to me! :yepp:
Perfect overclocking weather in western Canada today.
Bhairava: I screwed up when I first wrote RealTemp. It was originally based on measurements of the IHS. rge did some testing and determined that the actual core temperature is likely about 5C higher than my IHS temp readings so I adjusted TJMax 5C higher between version 2.70 and version 2.90.
Reported Temperature = TJMax - Digital Thermal Sensor Reading
The DTS (Distance to TJMax) data should be the same no matter what software you use but if the assumed TJMax is different then the reported temperatures will be different. TJMax is not a fixed value. There is an unknown amount of error in this number and Intel has not given the user community any guidance on how much error at their calibration point there really is.
solarises: You list your ambient temperature as 46C - 51C. Ambient temperature is your room temperature. If it was over 46C in my room I sure as hell wouldn't be sitting there using my computer. :D
JohnZS: I always like seeing your numbers because it helps demonstrate some of my crazy theories. Between the 30% and 88% level, core2 goes from 65.9 to 49.8 which is a difference of 16.1 and core3 goes from 60.6 to 44.3 which is a difference of 16.3. The slope error difference is only 0.2 degrees. The rest of the difference is all a difference in TJMax between two cores on the same die. How's that for quality control?
Your data suggests different TJMax values for each one of your cores. Some cores are pretty close, core0 vs core1, while others like core1 vs core2 might have a TJMax difference of 10C or 11C. :eek:
You don't read about stuff like that in the publicly available Intel docs but the numbers in the Cool Down Test tell a story that is hard to argue against. I still plan to have a good look at your numbers and come up with a calibration suggestion for you so bug me on a regular basis. I should have time in the next couple of weeks.
Venturer: rge's testing showed that there is about a 25C difference between the core temperature at full load and the Tcase temperature which is at the center of the chip. A good heatsink does not get nearly as hot to the touch as one would think. I'll go get my Q6600 up over 90C and take a measurement of the top of my Tuniq. We all need some exact numbers to understand this better.
