+VMCH and plus all kinda reference voltages' must be in a good balance.
for the life of me i just cannot get this stable. i get either a bluescreen or a failure of prime/occt about 5-10min in. im using Jor3lBR's template for 4.41ghz
the only things i changed are i set the ram to 1:1 (333mhz strap 2.0 multi) and DRAM voltage to 2.1. the driving strength profiles, channel a & b, should i set those to 1066? i've even gone a notch or two higher Vcore, giving me 1.392 windows and still no go. grrr.... its odd because, i boot into windows in under 30sec, just like i do now @ stable sig settings, everything seems smooth and groovy. i dont know how to tell if i need more vcore or if its the mch/cpu ref values that need tweaking.Code:Q9650 489 X 9 4401MHz
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ 0 ]
CPU Frequency 4.35GHz...........................[ 489 x 9 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 489 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2 [Disabled]
******Advanced Clock Control******
CPU Clock Drive.................................[ 1000mv ]
PCI Express Clock Drive.........................[ 1000mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 50ps ]
******DRAM Performance Control******
Performance Enhance [Standard]
Extreme Memory Profile (XMP)....................[ Disabled ]
(G) MCH Frequency Latch.........................[ 333MHz ]
System Memory Multipler.........................[ 2.40 ]
Memory Frequency 1066...........................[ 1174 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD............................................[ Auto ]
tWTR............................................[ Auto ]
tWR.............................................[ Auto ]
tRFC............................................[ 52 ]
tRTP............................................[ Auto ]
Command Rate (cmd)..............................[ Auto ]
******Channel A Timing Settings******
Static tRead Value [ 7 ] ................[ 8 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 7 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 9 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ OC-1333 ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
Static tRead Value [ 6 ] ................[ 8 ]
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration [Enabled]
CPU Vcore [ 1.23750 ]...................[ 1.41250 ]
CPU Termination [ 1.20 ]...................[ 1.40 ]
CPU PLL [ 1.50 ]...................[ 1.570 ]
CPU Reference [ 0.766 ]...................[ 0.871 OR 0.886 ]
MCH Core [1.1 ]...................[ 1.400 ]
MCH Reference [0.760 ]...................[ 0.926 ]
MCH/DRAM Refernce [0.900 ]...................[ 1.150 ]
ICH I/O [1.500 ]...................[ 1.570 ]
ICH Core [1.100 ]...................[ 1.200 ]
DRAM Voltage [1.800 ]...................[ 2.300 ]
DRAM Termination [0.900 ]...................[ 1.150 ]
Channel A Ref [0.900 ]...................[ 1.150 ]
Channel B Ref [0.900 ]...................[ 1.150 ]
******Advanced BIOS Features******
CPU Multithreading..............................[ Disabled ]
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
any ideas?
Posting to add to my bookmark.
Not really, if you get a good balance between the reference voltages you can run almost as low as the Asus series : eg for 580FSB/DDR3 action I need 1.36NB, on the Asus I needed 1.33 set in bios ( 1.34 in reality) Many users push high FSB and NB volts here due to the fact that the reference voltages aren't balanced. I alos got a DDR2 version now and it's way easier to setup than the DDR3 one I got. These boards are fab, but needs some tinkering to get it soaring ( and there seems to be some variation in the biosses between the different versions )
good evening lads
got my hands on an e8600 today,currently got it at 4 gig 10 x 400 @1.28vcore idling at 34/48 under load.i have tested it under orthos for an hour and its stable,
i use cpu-z and it always shows that my multiplier is x6 but this is not true, should show x10 - also the program will not show what mhz the ram is running at,shows timings only,
i downloaded the last cpu-z 1.50 and the same with that.even realtemp show x6 and occt also shows x6 , am i missing something here.like a performance saving setting,lol,
any advice would be much appreciated or tips on futher overclocks as i think this has a lot more to give.24/7 i am after.
i also bought the new akasa nero 1366 cpu cooler,it is massive and quite fiddly to get all the springs to lock,and getting the fan attached with the rubber bits is scary,you have to pull so hard you think the rubber is going to snap.
its running max 1680 rpm and its whisper quiet so i am pleased despite the hard work getting it on,dont want to mess around with that again if i can help it,next thing will be to source some ram which we let me go further.want to get at least 1250mhz but dont think the ram is up to it.
any suggestion or advice on any of the things i have talked about will be great to know,take it easy lads.
regs
paul
cholo777.here you go disable these
Try running memtest #5 and #7 for a while. That will tell you if its your ram/mch problem. If that works ok then run prime small fft for a while. If that fails then its a Vcore/Vfsb vtt problem. See what is breaking down before you change anything. If it fails prime blend then it could be anything:shrug:
This board is amazing.
I was upgrading my wife's PC and I bought a UD3R.
I used to have a DFI DK P45 T2RS for my E8600. Good for benching, but this Giga is awsome for 24/7.
After seeing the results for her PC, I bought a second board for me... :rolleyes:
Her E8400 + 2gb G.Skill 8500PK @1200MHz, 5-6-5-15 (non Micron D9):
IBT stable.
http://www.pctunerup.com/up/results/...IBTG.skill.JPG
First attempt with MemTest: stable.
http://www.pctunerup.com/up/results/...G.skill_06.JPG
MemTest86+, 10 pass: stable.
http://www.pctunerup.com/up/results/...Photo-0283.jpg
Everest Memory Benchmark.
http://www.pctunerup.com/up/results/....skill_05a.JPG
I set alpha timings to be like the ones from my D9 kits... :eek:
This week end I will install the second UD3 under my E8600 (batch Q822A435), and will see what happens. :cool:
By the way, I spent lot of time reading and getting very usefull informations from this thread, and that made the approach to this new MB very easy.
So, thanks to all of you. :up:
Based on that review I made a little block to measure the voltages safely (should come with something like this from the manufacturer :up:)
http://i41.tinypic.com/23jom55.jpg
Reposting:
Can somebody post recommended bios setting for stock (2.4ghz), 2.8 ghz and 3.0ghz?
Here is my stock BIOS setting, I always get a BSOD or lag during games, Easy tune 6 won't run.
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 9
CPU Frequency ...........................: 2.4
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 266Mhz
PCI Express Frequency (Mhz) .........:100
C.I.A.2 .................................:[Disabled]
CPU Clock Drive...........................: <<< 800
PCI Express Clock Drive.................: <<< 900
CPU Clock Skew (ps)....................: <<<
MCH Clock Skew (ps)...................: <<<
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............: 4.00A
Memory Frequency (Mhz) ..............: 1066
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................5
tRCD .........................................5
tRP'...........................................5
tRAS..........................................15
tRRD...........................................4
tWTR..........................................5
tWR............................................6
tRFC...........................................60
tRTP...........................................5
Command Rate (CMD) ....................:2
Driving Strength Profiles
Driving Strength ............................1066
Channel A
Static tRead Value.........................:10
tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Channel B
Voltage Type. ... Manual
CPU
CPU Vcore . .........................:Auto
CPU Termination ..... 1.200V*.......: Auto
CPU PLL ....1.500V*.......: Auto
CPU Referen. ....0.755V*.......: Auto
CPU Reference2 ,,0.800V*.......:Auto
MCH/ICH
MCH Core .....1.100V...........:1.2
MCH Reference . .0.800V...........;
MCH/DRAM Ref. ......0.900V...........:
ICH I/O .....1.550V............:
ICH Core ... 1.100V............:
DRAM
DRAM Voltage ....1.800V............: 2.1
DRAM Termination . 0.900V............:
Channel A Reference 0.900V............:
Channel B Reference 0.900V............:
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
Specs:
Intel Q6600 2.4ghz
Gigabyte EP45-UD3R rev 1.1 Bios F6
Palit GTX260 Sonic
Corsair 2x1gb 1066mhz
WD Raptor 74gb 10,000rpm
Windows Vista Ultimate 64bit
i have no idea what the reviewer said in there as i have not read the page yet, however, in my opinion based on my experience at using a couple of asus P5Q-D boards, gigabyte P45 UD3's uses less NB voltage at the same CPU and RAM overclocks and with similar system ram configuration.
also my P5Q-D boards were not good boards at all, most of the release BIOS sucked and caused numerous problems in the past, the P5Q-D board looks good with dark colour pcb and the 16 phase component layouts but that's all i used to like about them, but after a while of using the boards i get rid of them, so i can only recommend you to get gigabyte UD3's (either UD3R or UD3P) board. i think asus have made 965P and P35 based boards a lot better than they produces P45.
anyway, you may want to read around first (before you decide which board you like to use) as this threads have covered a lot of things on UD3's boards.
My Q6600 runs fine at defaults. As a matter of fact I can go all the way to 3.6 with everything on auto (which I don't do, but tried for testing). You might want to run your RAM at defaults to see what it does. You also might want to get your hands on the F9a (beta) BIOS. Mine would freeze at any setting with the official F8, but has no problems with the F9a.
one thing you guys can try that works for me is dont set strap (leave on auto) like this.
Performance Enhance...................: [Auto]
(G)MCH Frequency Latch...............: [Auto] leave on auto this works for me at 500fsb
System Memory Multiplier ..............: 2.40B
Memory Frequency (Mhz) ..............: 1150-1200
Hey guys, I need some help here. I'm on my second UD3P v1.1 and the PLL voltage is not correct on this board either. Set it to 1.5v-1.57v or laeve it on auto and I get 1.63v-1.66v under load.
If any of you guys own a multimeter or have access to one can you please check your PLL voltage under load so we can figure out if this is just an isolated case or if there is really something to be concerned about.
The absolute maximum rated PLL voltage according to intel data sheet is 1.57v.
May be this is the info for some one who compare this board with P5Q serie. I just got P5Q Deluxe buy the second hand in my country for a while and I can got 550x8 stable very easywith a simple setting in BIOS,but every thing need more Volt than UD3P for sure.!!I don't want to complain my UD3P may be It's not match with my E8600 I try to hit with the high fsb and no luck . Just let you know I 'll back with UD3P later after I got some Quadcore and new ram to this board. I plan to have a new Rig soon.:)
Now I'm happy with my expected FSB setting.
DFi LP DK P45 T2RS + Q9650 = 4883 MHz/Dice
GA EP45T UD3P + Q9650 = 4750 MHz/Air XIGMA Achilles
That's nice :)
http://img26.imageshack.us/img26/253/cpuze.jpg
4145 MHz Air XIGMA Achilles 63°C DDR3 1840 MHz 7-7-7-20 Pl8
http://img26.imageshack.us/img26/7594/primeq.jpg
The q9650 I have runs very warm even at stock vid 1.2125v, idle 38c to 40c mid 50's loaded out small fft's. Have tried 3 different HS's a TT120 first then 2 different Ultra120 Extremes, ordered a couple Scythe 133cfm. fans with the same basic results. The 120 does help when loaded out, better than the TT120. Also put the same chip in the other case on a different ud3p with similar temps, even tried a different PSU. I am still shooting for 4.25ghz for 24/7 use. My question is if I am able to get the fsb I need but with a lower multi, is it just a matter of vcore at that point to get it stable with a higher multi? Should I then leave the reference voltages alone? I know the memory is good where it is, so running small fft's trying to get the cpu stable at 473fsb. Will run Prime blend for a final test. At 4.25 ITB would :rofl: at my temps so that probably isn't an option.
EP45T-UD3R F5 e8400 500x9 DDR3-1600 CL7-6-5-18
http://img17.imageshack.us/img17/791...d1600cl765.jpg
http://img17.imageshack.us/img17/557...0316033359.png
took the plunge and bought myself an e8600 and its a very nice example,been quite easy to overclock and i am happy.will try a little more tonight.these are the settings i have currently - the more important ones.
vcore 1.28
10 x 400
cpu term 1.28
cpu pll 1.57
mch core 1.38
http://i175.photobucket.com/albums/w...7/setting1.jpg
