heres a comparison of 525x8 everest scores the only difference is theone with the low copy(9k) is 32bit XP OS and the 11k copy score is x64 XP OS.
http://i41.tinypic.com/2dr55c4.jpg
http://i43.tinypic.com/121g1lj.jpg
i bought mine used here on XS.
i dont own a DMM yet.sorry
So what do you think Jor? In your opinion is it still safe to use 1.50/1.57PLL on this board with 45nm's? BTW, I fixed my rig, stable at 476x9 now 1.39vcore! Thanks to you and Hoss for helping me! When I run my final blend test I will post all settings and information.
Are these the voltage read out points you were looking at? http://www.hardwarecanucks.com/forum...review-15.html
does anyone here have a 5.1 analog system conected to this board and using vista x64 sp1 cause i can't use the realtek drivers to work well with my speakers. Even tried latest version 2.18 still no rear speakers detected under 5.1 configuration :( The windows drivers work well no problem, but i think it should be more.
That's great news Slim, I'm glad I could help a little. You should e fine with those PLL's. I didn't need more then 1.5 all the way to 4750Mhz.
Nice find coop.
According to the review "the EP45-UD3P has terrific voltage output. There is very little variance between what you select in the BIOS and what the board actually outputs. The DIMM, NB, PLL, and VTT voltages are very accurate and stable, showing no variances between idle and load states."
So the value you set on BIOS for NB, VTT and PLL it's pretty much the real one, if you measure those and the output is way off I would be concerned and double check DMM batteries too.
But then again, every motherboard/psu combo should output slightly different values and that can change even from cpu to cpu type.
I agree Jor3lBR, the accuracy is about spot on. Great product.
That is the point that I used to measure PLL voltage and mine reads exessively high with anything above 1.45v. If I set it to 1.5v in bios I get 1.63v-1.66v under load. I've been doing some experimenting and this does seem to be the correct spot. When I change PLL settings in bios the voltage from this spot changes and none of the other voltages move.
So what am I to do, keep the board knowing that it has issues with voltage regulation or return it for a new one?
Edit: I think I'm going to return this board tomorrow and hope the new one has proper regulation, this one is F.U.B.A.R. and I don't want to take the chance of it giving me some magic smoke and taking my quad away with it.
can somebody post recommended bios setting for stock (2.4ghz), 2.8 ghz and 3.0ghz?
Here is my stock BIOS setting, I always get a BSOD or lag during games.
Specs:Quote:
MB Intelligent Tweaker(M.I.T.)
Robust Graphics Booster ...............: Auto
CPU Clock Ratio ..........................: 9
CPU Frequency ...........................: 2.4
Clock Chip Control
Standard Clock Control
CPU Host Clock Control..................: [Enabled]
CPU Host Frequency (Mhz) ............: 266Mhz
PCI Express Frequency (Mhz) .........:100
C.I.A.2 .................................:[Disabled]
Advanced Clock Control
CPU Clock Drive...........................: <<< 800
PCI Express Clock Drive.................: <<< 900
CPU Clock Skew (ps)....................: <<<
MCH Clock Skew (ps)...................: <<<
DRAM Performance Control
Performance Enhance...................: [STANDARD]
Extreme Memory Profile (X.M.P.).....: Disabled
(G)MCH Frequency Latch...............: [Auto]
System Memory Multiplier ..............: 4.00A
Memory Frequency (Mhz) ..............: 1066
DRAM Timing Selectable ................: [Manual]
Standard Timing Control
CAS Latency Time........................5
tRCD .........................................5
tRP'...........................................5
tRAS..........................................15
Advanced Timing Control
tRRD...........................................4
tWTR..........................................5
tWR............................................6
tRFC...........................................60
tRTP...........................................5
Command Rate (CMD) ....................:2
Driving Strength Profiles
Driving Strength ............................1066
Channel A
Static tRead Value.........................:10
tRD Phase0 Adjustment...................:Auto
tRD Phase1 Adjustment...................:Auto
tRD Phase2 Adjustment .................:Auto
tRD Phase3 Adjustment..................:Auto
Trd2rd(Different Rank)....................:Auto
Twr2wr(Different Rank)...................:Auto
Twr2rd(Different Rank)...................:Auto
Trd2wr(Same/Diff Rank)..................:Auto
Dimm1 Clock Skew Control...............:Auto ps
Dimm2 Clock Skew Control...............:Auto ps
Channel B
Motherboard Voltage Control
Voltage Type. ... Manual
CPU
CPU Vcore . .........................:Auto
CPU Termination ..... 1.200V*.......: Auto
CPU PLL ....1.500V*.......: Auto
CPU Referen. ....0.755V*.......: Auto
CPU Reference2 ,,0.800V*.......:Auto
MCH/ICH
MCH Core .....1.100V...........:1.2
MCH Reference . .0.800V...........;
MCH/DRAM Ref. ......0.900V...........:
ICH I/O .....1.550V............:
ICH Core ... 1.100V............:
DRAM
DRAM Voltage ....1.800V............: 2.1
DRAM Termination . 0.900V............:
Channel A Reference 0.900V............:
Channel B Reference 0.900V............:
Advanced Settings
Limit CPUID Max. to 3.....................: [Disabled]
No-Execute Memory Protect............: [Enabled]
CPU Enhanced Halt (C1E)................: [Disabled]
C2/C2E State Support....................: [Disabled]
x C4/C4E State Support..................: [Disabled]
CPU Thermal Monitor 2(TM2) ...........: [Enabled]
CPU EIST Function.........................: [Disabled]
Virtualization Technology................: [Disabled]
Intel Q6600 2.4ghz
Gigabyte EP45-UD3R rev 1.1 Bios F6
Palit GTX260 Sonic
Corsair 2x1gb 1066mhz
WD Raptor 74gb 10,000rpm
xavisimao, start by setting your vcore manualy and see if that helps. I would also set vtt and pll voltage to defaults instead of auto.
does this m/b needs more MCH voltage than other P45s ?
as stated here
http://www.clunk.org.uk/forums/revie...html#post48572
I am to choose between EP45-UD3R and P5Q - E( or deluxe@more expensive though)
or is only that MCH Reference thing you are talking about all the time...sry , 975X here no idea about P45, yeah a little bit old fashioned
im pretty sure those sticks will not do 1200.but one thing you can change is ,set trfc to 55.i used to run mine at 520x8 and at 1:1 that gives your memory 1040.you can also try 471x8.5 and run the 333strap 2.40B should be around ddr1130 set pl8
DUDE! 1.71PLL is not a good idea! Your going to be way way way better off with 8.5x471 running the 2.4B strap and much much less VTT/MCH. Try these and see if you can boot. If not raise your VTT/MCh to 1.32/1.32, raise the VTT first and let the references adjust. You should be running something like ~65% of the VTT for a reference and ~67% of the MCH for a reference. You can run 2.0V ram at first and then lower it later. Get rid of that 700mv/700mv and 200ps clock skews. Try 900/900/0/0 or 1000/1000/0/50. You can also try up to 1.57PLL but NO MORE. Boot with these setting first though. Good luck:up:
Code:******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 ]
Fine CPU Clock Ratio............................[ + 0.5 ]
CPU Frequency 3.8GHz............................[ 471 x 8.5]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 471 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2.........................................[ Disabled ]
******Advanced Clock Control******
CPU Clock Drive.................................[ 900mv ]
PCI Express Clock Drive.........................[ 900mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
(G) MCH Frequency Latch.........................[ 333 ]
System Memory Multipler.........................[ 2.40B ]
Memory Frequency 1066...........................[ 1130 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD[4].........................................[ Auto ]
tWTR[4].........................................[ Auto ]
tWR[13]..........................................[ Auto ]
tRFC[68]........................................[ 55 ]
tRTP[4].........................................[ Auto ]
Command Rate (cmd)[0]...........................[ 2T ]
******Channel A Timing Settings******
Static tRead Value [ 8 ] ................[ 8 ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 5 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 8 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ 1200 ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.15 ]......................[ 1.4000 ]
CPU Termination [ 1.20 ]...................[ 1.280 ]
CPU PLL [ 1.50 ]...................[ 1.500 ]
CPU Reference [ 0.760 ]...................[ 0.835 ]
MCH Core [ 1.100 ]...................[ 1.300 ]
MCH Reference [ 0.760 ]...................[ 0.850 ]
MCH/DRAM Refernce [ 0.900 ]...................[ 1.000 ]
ICH I/O [ 1.500 ]...................[ 1.500 ]
ICH Core [ 1.100 ]...................[ 1.100 ]
DRAM Voltage [ 1.800 ]...................[ 2.000 ]
DRAM Termination [ 0.900 ]...................[ 1.000 ]
Channel A Ref [ 0.900 ]...................[ 1.000 ]
Channel B Ref [ 0.900 ]...................[ 1.000 ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
Great! Just remember that using the 2.4B strap might prevent you from running 1.34VTT/1.34MCH(I do not think you will need it that high) so don't freak out if you can not boot or instant BSOD if you try that high. I think you might be able to go lower on the ram then I suggested but make 100% sure your vcore/vtt/mch levels are stable before lowering your ram. If you get BSOD's or prime fails do not change to many settings at one time. Those settings are pretty much identical to what I can run my 9650 at with 9x471, since you have a 9550 then 8.5x471 should be spot on. :up:
okay i got 4GHz stable @8X500
what needs to get more volts besides v-core to get more Mhz stable ?
