Originally Posted by
Simps
From 1.20VTT to 1.32VTT
CPU GTL 0: +100mV | +90mV | +80mV | +70mV | +60mV | +50mV | +40mV | +30mV | +20mV | +10mV
CPU GTL 1: +060mV | +50mV | +40mV | +30mV | +20mV | +10mV | +00mV | -10mV | -20mV | -30mV
CPU GTL 2: +100mV | +90mV | +80mV | +70mV | +60mV | +50mV | +40mV | +30mV | +20mV | +10mV
CPU GTL 3: +060mV | +50mV | +40mV | +30mV | +20mV | +10mV | +00mV | -10mV | -20mV | -30mV
CPU GTL 0: -060mV | -50mV | -40mV | -30mV | -20mV | -10mV | +00mV
CPU GTL 1: -100mV | -90mV | -80mV | -70mV | -60mV | -50mV | -40mV
CPU GTL 2: -060mV | -50mV | -40mV | -30mV | -20mV | -10mV | +00mV
CPU GTL 3: -100mV | -90mV | -80mV | -70mV | -60mV | -50mV | -40mV
From 1.32VTT to 1.44VTT
CPU GTL 1: +055mV | +45mV | +35mV | +25mV | +15mV | +05mV | -05mV | -15mV | -25mV | -35mV
CPU GTL 3: +055mV | +45mV | +35mV | +25mV | +15mV | +05mV | -05mV | -15mV | -25mV | -35mV
CPU GTL 1: -105mV | -95mV | -85mV | -75mV | -65mV | -55mV | -45mV
CPU GTL 3: -105mV | -95mV | -85mV | -75mV | -65mV | -55mV | -45mV
*** The CPU GTL's in green, are, from my experience, most like the candidates of the most stable CPU GTL. But feel free to try whatever you want!
*** The positive values for the CPU GTL's, are not available on the 1901 BIOS, from 5 to 5mV increments. Only 10mV to 20mV and so on. So if you need a positive CPU GTL value like "+25mV", you will have to round it to +30mV or +20mV, or better then that, leave the 5mV to the negative CPU GTL's, as they are available on the 1901 BIOS!
*** You can select on your bios, other CPU GTL's that are beyond the +100mV and -100mV showed here. Its very unlikely that those are the best CPU GTL's for you, but you can always try them too!
