Also if anyone is wondering F9b bios still doesnt fix S3.
I just got a E5200 :D
Right now its running at 2.75GHz on stock volts :)
Just wondering, does anyone know if there is a E5200 theard? I did a quick search, but I didn't find anything?
i spend a bit of time on each bios version for fsb and ram overclocking and then i can choose which one i like to use most, but so far they are all the same as far as i can see.
anyway what you think about this below everest's, is this good or bad for P45 DDR3-based board?
the scores still suck, don't you think?
http://img9.imageshack.us/img9/5748/20090312135040.png
Hello again everyone.
I really need serious help here ..
It is still the graphics card problem, and that it is only running under half the speed of that, on the X48..
It is a 9800GX2 card and it is running with two GPUer (as SLI) multi gpu..
In GPU-Z it shows to cards and that SLI is enable, it shows PCIe 2.0 x 16 on both cards, so everything is ok here.
But when I check the hardware in SiSoftware Sandra, there is one card in SLI and one beside that. when I benchmarks in Sandra,for comparison with a similar card, it can only run less than half the speed?? ..
It is as if there is something there are blocking over a certain speed, even if I OC the graphics card, is dont do the slightest difference.
It can run at a certain speed and then it will just not anymore.:confused:
I've never had problems on X48.....
Could it be PCIe port there is something with, it must be a hardwre problem, I tried to reinstall the OS and drivers several times ...:confused:
so far this is what i can get out of memory with bios f9b.
has somone notice any pefformance gain on any of latest bios?
EP45-UD3P bios F9b
Intel QX9770
1x320GB WD
2X1GB Team Xtreem DDR2 PC2-10400 1300MHz
Sapphire radeon 4870X2
Vista Ultimate x64
Scythe Mugen 2
CoolerMaster Real Power M1000 PSU (1000W)
i own a ep45-ud3p rev 1.0 with bios f8 final, but its the hardest 775 board to get stable from my experience. I previously owned an abit ab9 quadgt and an asus p5k premium and my e8400 was stable @ 4ghz with 1.225 set in bios without any problems with ram @1068, pl6 . I have 2 x 2gb ocz hpc reaper pc8500 and i am having a hell time gettin this board to run @ 4ghz with decent memory timings and voltages . My only stable config was the default settings. I am now testing @ 4ghz with 8.5 x475 fsb, ram settings standard, xmp disabled, 400 strap, ratio 2.00d, ram settings manual @ 5-5-5-15 2.14v, pl9, llc enabled, cpu @ 1.2500, vtt 1.24, vmch 1.28v, every ref up 1 notch, case closed, room temp 23C, eist and c1e enabled cause i don't like to run a 4ghz cpu while browsing websites. BTW i am using vista x64 sp1 and i have creative t6060 5.1 sound speakers but i am only able to hear the rear speakers if i set the audio device to 7.1 speaker configuration. If i set the 5.1 setting i have no rear speakers only the suround ones:( which ofcourse are not present and when i click on them under the testing menu i hear the sound on my front speakers:(. When i insert my rear speakers on the black port they are sensed like rear speakers so i really dont know what to think. I am using the sound driver from the gigabyte website.
Hope this helps dualcore users who have a hard time finding 4ghz, 24/7 settings with 2 x 2 gb ram
This settings are fine up to [460*9] or [500*8.5] F.E.A.R. 2 stable.
GA EP45T DS3P
Intel Q9650 (@4883 MHz with LP DK P45-T2RS PLUS)
Kingston Hyperx 1800 MHz (@2000 MHz/Pl. 10)
http://img24.imageshack.us/img24/1094/42206364.jpg
http://img15.imageshack.us/img15/3264/resim056x.jpg
I've had this board for about a month now, my cpu overclock is stable 4000hmz@8x500 but im really lost on the memory settings.
here is how its set now.. (dont pay attention too the volts I was messing around trying something out :P)
Im looking too either get my ram too 1200mhz, or keep it at 1000mhz with better timein, whatever will give me better memory bandwith
i have the G.Skill PI8800 (1100mhz 5-5-5-15 1.8-1.9v)
Code:******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8 ]
Fine CPU Clock Ratio............................[ + 0.0 ]
CPU Frequency 3.8GHz............................[ 500 x 8.0]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 500 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2.........................................[ Disabled ]
******Advanced Clock Control******
CPU Clock Drive.................................[ 700mv ]
PCI Express Clock Drive.........................[ 700mv ]
CPU Clock Skew..................................[ 200ps ]
MCH Clock Skew..................................[ 200ps ]
******DRAM Performance Control******
Performance Enhance.............................[ Turbo ]
Extreme Memory Profile............................[ Profile1 ]
(G) MCH Frequency Latch.........................[ 400 ]
System Memory Multipler.........................[ 2.00D ]
Memory Frequency 1066...........................[ 1000 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD[4].........................................[ Auto ]
tWTR[4].........................................[ Auto ]
tWR[13]..........................................[ Auto ]
tRFC[68]........................................[ Auto ]
tRTP[4].........................................[ Auto ]
Command Rate (cmd)[0]...........................[ Auto ]
******Channel A Timing Settings******
Static tRead Value [ 10 ] ................[ Auto ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 8 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 7 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 9 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.23750 ]......................[ 1.40000 ] (gives 1.36)
CPU Termination [ 1.20 ]...................[ 1.440 ]
CPU PLL [ 1.50 ]...................[ 1.710 ]
CPU Reference [ 0.760 ]...................[ Auto ]
MCH Core [ 1.100 ]...................[ 1.400 ]
MCH Reference [ 0.760 ]...................[ Auto ]
MCH/DRAM Refernce [ 0.900 ]...................[ Auto ]
ICH I/O [ 1.500 ]...................[ Auto ]
ICH Core [ 1.100 ]...................[ 1.200 ]
DRAM Voltage [ 1.800 ]...................[ 1.900 ]
DRAM Termination [ 0.900 ]...................[ Auto ]
Channel A Ref [ 0.900 ]...................[ Auto ]
Channel B Ref [ 0.900 ]...................[ Auto ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
Could someone tell me why my PC won't post unless I use the 1:2 RAM driver?
fatguy1992, you're not new to the board so maybe something your overlooking (in plain sight poss) in some of the less obvious settings. Did it do a reset?
Can someone do a compare of aida32 and Everest mem write read benches? please, for reference. Thanks.
When I applied the settings it would not post, then try again which wouldn't post and then on the third time it would reset back to default, but still show my settings in BIOS. I hope that makes some sense cause i'm really tired atm.
EDIT: I just tested it again and I got the 200MHz Latch with 2.66C to work :D
Hi folks,
I need help with OCing my e7300, i can't seem to push it past 3.4ghz and make it stable enough. Any thoughts would be appreciated.
e7300 @ 3.4ghz 400x8.5@ 1.3v
Xigmatek Dark Knight CPU Cooler
corsair ballistix tracer PC6400 5/5/5/14 @1066mhz
gigabyte ep45 ud3p
corsair vx550
HIS Radeon 4830 @650/1000
fatguy make sure your not setting performance level too low for any givin strap.sometimes when i switch straps i forget the PL setting.
gang its in the advance memory page.static read value
Static tRead Value [ 8 ] ................[ 8 ] THIS ONE HERE make sure you change channel b too
tRD 2rd (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 5 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 8 ] ................[ Auto ]
Stanispoulos: whats your current bios settings?
can somebody post recommended bios setting for stock (2.4ghz), 2.8 ghz and 3.0ghz of my spec
Intel Q6600
Gigabyte EP45-UD3R
Palit GTX260 Sonic
Corsair 2x1gb 1066mhz
WD Raptor 74gb 10,000rpm
I always get a BSOD or lag during games.
i’m posting to find out how you like your new gkill 9600 kit, and if you don't mind me asking, how much you paid for it?
i still have a brand new UD3R 1.0 ddr2 board and still waiting to get the kit whenever i see the price is right.
in the meantime i'm learning how to use the ddr3 one.
i finally got a better everest's at below 500fsb and strap 266 (4.0A)
and this's under vista 32-bit...
http://img5.imageshack.us/img5/3852/20090314043539.png
im liking them alot pangingIII.i got this kit for 240$
Did anybody else notice how high the pll voltage spikes under load? My multimeter is showing 1.63v-1.66v under load with pll voltage set to 1.5v in bios. Dropping it down to 1.45v keeps it under 1.55v under load.
Is this a common problem or should I return this board for another one is 1.6xv safe for 24/7 use? I read that anything over 1.64v could cause degradation or death with these 45nm chips.
BTW, I got my Q9650 up to 4.4ghz @ 1.36v SS are in the Q9650 thread.:D
