Thanks for answer, i was on 'ftp.asus.com' and was only 0803 available.
Mom :help:
need a little help
E8600 @ 5GHZ Cellshock PC8000 CL 1000MHZ 5-5-5-15/18 2T
can run superpi ½ time,by 500x10 fsb,an 501x10 no go
stramp 400 a 500x10 ? no go,can only run strap 333 here :confused:
501+ x10 fsb can i not run superpi more,MEM will not be write :(
have tried everything,with temingset.
what can I Disabled,so I can get mem with again,over 500x1o fsb
AI Overclock tuner: manual
CPU Ratio Setting: 10
FSB Strap to North Bridge: Auto
FSB Frequency: 500
PCI-E Frequency: 101
DRAM Frequency: 1000
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : 5
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
2nd Information :
READ to WRITE Delay (S/D): AUTO
Write to Read Delay (S): AUTO
WRITE to READ Delay (D): AUTO
READ to READ Delay (S): AUTO
READ to READ Delay (D): AUTO
WRITE to WRITE Delay (S): AUTO
WRITE to WRITE Delay (D): AUTO
3rd Information :
WRITE to PRE Delay: AUTO
READ to PRE Delay: AUTO
PRE to PRE Delay: AUTO
ALL PRE to ACT Delay: AUTO
ALL PRE to REF Delay: AUTO
DRAM Read Training: Disable
MEM. OC Charger: Enable
AI Clock Twister: AUTO
AI Transaction Booster: Manual
Common Performance Level [10] to 13
Pull-In of CHA PH1: DISABLED
Pull-In of CHA PH2: DISABLED
Pull-In of CHA PH3: DISABLED
Pull-In of CHA PH4: DISABLED
Pull-In of CHB PH1: DISABLED
Pull-In of CHB PH2: DISABLED
Pull-In of CHB PH3: DISABLED
Pull-In of CHB PH4: DISABLED
CPU Voltage: 1.58XXV
CPU GTL Voltage Reference (0/2): AUTO
CPU GTL Voltage Reference (1/3): AUTO
CPU PLL Voltage: 1.52
FSB Termination Voltage: 1.36
DRAM Voltage: 2.36 more volt help not
NB Voltage: 1.56
NB GTL Reference: AUTO
SBridge Voltage: AUTO
PCIE SATA Voltage: AUTO
Load Line Calibration: Enabled
CPU Spread Spectrum: Disabled
CPU Clock Skew : Auto
NB Clock Skew : Auto
Why don't you download Intel drivers directly from Intel website? :confused:
INTEL MATRIX STORAGE MANEGER
Is your G.skill new? I heared from some German dudes that G.skill used recently new powerchips in their 8000CL5 4GBPQ, and they are incompatible witht he Asus P5Q series.
Also a friend of mine wanted to buy a kit for his P5Q deluxe and the shopowner said they had several RMA because of the newer chips in the 8000CL5 4GBPQ and recommend him not to pick that kit, however older chips works on this board......maybe ask G.skill technician about it. Maybe u can confirm yourself if u have a spare kit of a different brand/chip
* edit I am sorry I got somehow mixed with another thread , and thought u had the G.skill but u got the ballistix, and those should work espacially good old micron chips.
polizei,I'm on a p5q-e,Raid is working on mine.
Try this-
http://rapidshare.com/files/137527598/xp.rar-files to put on floppy
or this-
http://rapidshare.com/files/137527790/xpmakedisc.rar-makedisc utility
The raid driver is the same download for p5q-e/deluxe.
Which slots tends to clock better on this board, normally the black ones (slot2/4) on most asus boards, but how about on this board, heared some said slot1/3 the yellow onces.
I used the yellow ones.
the manual says the yellow ones
$199 looks like an ok deal for this board. Think I'll order one. There's plenty of great info here to get a o/c running fast! Thanks everyone.
Thnx, The yellow it is then, what does actually Mem Charger do ? Does it give performance boost in programs like everest, or just for stability? Could this be drive strenght?
I did some testing with different DRAM SRC, strap and Clock Twister, all on 534 FSB.
This is what I came up with:
http://shrani.si/f/38/sh/4vPDSlat/everest-memory.jpg
Not much of a difference, so I then tested 9x445 SRC En./333/Moderate:
9013-9444-9341MB/s
Judging by these results, FSB matters the most.
Screens with settings used:
http://shrani.si/t/1H/TK/1YohuizZ/ev...-src-disab.jpg
http://shrani.si/t/T/7w/bFkVOpy/ever...-src-disab.jpg
http://shrani.si/t/5/rO/4l64LugJ/eve...-src-disab.jpg
http://shrani.si/t/x/ao/4Qaz9KUq/eve...-src-enabl.jpg
http://shrani.si/t/1H/zB/DGTCcx4/eve...-src-enabl.jpg
http://shrani.si/t/i/I7/2jL34vso/eve...-src-enabl.jpg
333/Strong resulted in no boot.
9x445, DRAM 1069:
http://shrani.si/t/X/HV/1Is45xqR/eve...src-enable.jpg
Orthos stable:
http://shrani.si/t/S/125/3HmtHsNr/75...375v-llc-e.jpg
http://shrani.si/t/2m/si/2JTLw13f/9x...75v-llc-en.jpg
Had no luck with 1.26V NB/strap 400 and Strong, so I am not done testing.
JumperFree Configuration Settings
AI Overclock tuner: MANUAL
FSB Strap to North Bridge: AUTO
FSB Frequency: 400
DRAM Frequency: 1002 tried on 800
DRAM Timing Control: MANUAL
1st Information :
CAS# Latency: 5
DRAM RAS# Activate to Precharge: 15 tried on 18
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: 55 tried on auto
DRAM Read Training: AUTO
MEM. OC Charger: AUTO
AI Transaction Booster: AUTO
CPU Voltage: 1.4
CPU PLL Voltage: 1.56
FSB Termination Voltage: 1.30
DRAM Voltage: 2.0
NB Voltage: 1.30
Load Line Calibration: ENABLED
CPU Clock Skew : AUTO
NB Clock Skew : AUTO
Advance CPU Settings
CPU VID: Default
C1E Suppport: Disabled
Max CPUID Value Limit: Disabled
Intel® Virtualization Tech: Disabled
Vanderpool Technology: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
__________________
right theses are my settings will boot and stay stable for about 16 mins tops some time a few seconds i cant understand why. i only have the 4 pin power in not all 8 pins. bios 1103 but going to 1201 when i go home 2moz ram in yello slots.
i also tried 465x8.5 with a lower v core and it stoped stable for 22 mins but nothing wants to work not even 450x9. if anyone has any templates for me to try then pm them me. and ill try in the morning. i need my rig rock solid stble for gaming temps not a problem 9800 gx2 and cpu watercooled.
thanks in advance will let you know how i get on
it is usually a better idea to gain stable fsb with a low multi first, then add the higher multi later. that way if there is a problem you know its not the CPU.
too much voltage can crash these system just as easily as not enough. lower your voltages to 1 notch above defaults.
Oke there were rumours that the 1201 BIOS would be close to real according to Cryptik, he said with all previous BIOS if u set @ BIOS: 1.96v , in windows Ilde: 1.97 and load : 1.98v. So I just installed my board it came shipped with 0803 BIOS and I was curious about it , so I grabbed my $7 Multi meter and check it out. I set @ BIOS : 1.96v , in windows idle I get 2.04 ( steady), when I run Blend it fluctates all the time between 2.04- 2.05v. After this I installed the 1201 BIOS, unlike Cryptik this BIOS behaved the same : when I set 1.96v it indicates still 2.04 @ windows Ilde and fluctates between 2.04- 2.05 during Prime blend. We just have 2 peeps measured the DIMM @ BIOS 1201 would be nice if some1else could meassure it aswell, so we can be abit more "sure" about it
*edit I also tried it @ 2.00v BIOS set windows Ilde: 2.07 -2.08 prime blend: 2.08- 2.09
I just tested Vdimm Full Load.... Bios 1201
I am folding right now...... so Bios is set at 1.96 and volt meter reads . fluctuates 1.96-2.0 MAX... cause of folding going on...... so MAX is 2.00 load.
As for idle i don't know yet, but i assume it is around 1.96-1.97v
I will check later on today when i decide to shut folding off.
Yes ThugsRook
600x6 is ok,but will have the same problem here by 601x6,I have with 501x10 :confused: the temp is not high, i got watercooling.
guys,
its not just vdimm that overvolted... CPU PLL, FSB term, and NB, all overvolted. especially on AUTO or what was supposed to be the "default" setting.
i got most if not all of my OC by lowering my voltages, not by raising them :yepp:
Guys, why is it an advantage to set the PCIE @ 101 instead of 100? thanks
[thanks for the replies guys]
Hi Boyz
I just bought this motherboard and an E8600 and 2x1GB Kingston 12800 CL9 modules wich im able to overclock to 1800Mhz. :)
The only problem i have so far is that i cant seem to adjust the bass and diskant on the onboard audio.
Does any know how to adjust theese settings?
/*Svend
