same here works on all my OC's :up:
Updated some of my previous scores on HWbot.org:
wPrime32m = 7.612sec
wPrime1024m = 4min 8sec 910ms
http://i27.tinypic.com/2zpjn0w.jpghttp://i25.tinypic.com/sb4vm8.jpg
Have a $250 4870 X2 2Gb + more SSD's incoming to conquer that last gold cup for PCMark05. :up: As soon as I get this done I'll let you guys know.
I am seriously stuck at 4.038 :( I have tried vcore up to 1.44, dropping the divider down to 1:1 and multiplier to 7 with no stability : (
Code:Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 8.0 ]
Fine CPU Clock Ratio............................[ +0.5 ]
CPU Frequency............................[ 475x8.5 ]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 475 ]
PCI Express Frequency (Mhz).....................[ 100 ]
C.I.A 2.........................................[ Disabled ]
******Advanced Clock Control******
CPU Clock Drive.................................[ 1000mv ]
PCI Express Clock Drive.........................[ 1000mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 50ps ]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
Extreme Memory Profile (X.M.P)..................[ Auto ]
(G) MCH Frequency Latch.........................[ Auto ]
System Memory Multipler.........................[ 2.40B ]
Memory Frequency 1066...........................[ 1140 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.1875 ]...................[ 1.4250 ]
CPU Termination [ 1.20 ]...................[ 1.380 ]
CPU PLL [ 1.50 ]...................[ 1.590 ]
CPU Reference [ 0.760 ]...................[ 0.914 ]
MCH Core [ 1.100 ]...................[ 1.300 ]
MCH Reference [ 0.760 ]...................[ 0.954 ]
MCH/DRAM Refernce [ 0.900 ]...................[ 1.200 ]
ICH I/O [ 1.500 ]...................[ 1.500 ]
ICH Core [ 1.100 ]...................[ 1.100 ]
DRAM Voltage [ 1.800 ]...................[ 1.960 ]
DRAM Termination [ 0.900 ]...................[ 0.980 ]
Channel A Ref [ 0.900 ]...................[ Auto ]
Channel B Ref [ 0.900 ]...................[ Auto ]
Machinus how are you mate, from what i see you have my same vid of chip wich is great CPU Vcore [ 1.1875 ].
try to drop vtt to 1,20 and see that CPU ref is .785 and MCH .80, then up it and this values will change auto, for lots of us this worked perfect so for me tom and zucker2k...
start on a normal OC, like 445x9 ti try your CPU and MEM on 1:1 CL5 all auto, PL9 and trfc 68 (you have 2x2GB ???? wich RAM), try to find FIRST as stable point where you can start upping, dont start messing around with values and changing all at time and multis etc...go step by step or you will go crazy.
Use 800/800/0/50 or 900/900/0/50, i use 1000/1000/0/0 to 4800+ to bench the rest are for my 24/7
i will send you a template of my 445x9 and 500x8 so you have a start point, should work for ya as owr quads are close.
Cheers :up:
Sergio
I caught the x58 fever and wanted to familiarize myself with the architecture, so I sold my UD3P+Q9650+8GB G.Skill Pis and upgraded without spending a penny more.
This was my result:
http://www.hostthenpost.org/uploads/...19dbac2416.jpg
But then I started getting withdrawals from moving away from s775 :rofl: so I decided to build a cheapo rig and satisfy my appetite for overclocking on this platform.
I had the choice of picking another Q9650, but there were many horror stories in this thread about lack-lustre 9650s with 1.300 vids, while the 9550s seem to show relatively better results. I decided to go as cheap as possible while pushing the clocks as much as my air-cooler would allow for 24/7. I still haven't finished putting parts together; I need better ram and psu, but this is what I've done so far. Oh, this chip also happens to be my best s775 chip do date. :cool:
Q9550 L844B872
EP45C-UD3R
2x 1GB Mushkin DDR2 1066
Xigmatek HDT S1283 (Stock fan)
Windows 7 x64
8x500 64bit P95 (Single-stock fan)
http://www.hostthenpost.org/uploads/...053b17b19f.jpg
8x500 Linx 64bit (Stock fan + 93cfm thermaltake fan)
http://www.hostthenpost.org/uploads/...7cd5e05327.jpg
8.5x500 Linx 64bit (Stock fan + 93cfm thermaltake fan)
http://www.hostthenpost.org/uploads/...0fd35ab14e.jpg
Very nice Zucker. :up:
Ah! I made a mistake :( I copied the template with the wrong VID! Mine is a terrible 1.3v :(
I will lower the clock to 900/900/0/50.
Even at 1:1 and higher mch/ref the board doesn't seem to go over 500 despite having temps always 65 and below.
So I should start atvcore 1.3125 and put everything on auto and just try to increase clock with 9x multi? It is very unstable at 9x with 400 and over unfortunately.
I guess I got a bad chip.
CPU Vcore [ 1.30 ]...................[ 1.41250
Hey Zuc nice to see you're back in town! Those are amazing results on the Q9550 and what really cough my eyes is the fact that those Q9550 don't give up after 70oC when most of the Q9650 bugs out after 63oC :clap:
Might get one of those to play with on the other rig, thanks for sharing.
Got the EP45 DQ6 installed, after some head scratching I am running some small fft's at 4500mhz. The dates are screwed up in prime because it fudged up after my last try and 4500 when it bsod'd. The temps seem to be much lower than with before on my other board. Don't know why they would be any lower, same chip.
EDIT: Had to go up a notch on vcore. The board has 2 CPU Ref's and 1 MCH Ref, the values are different and has thrown a curve in my ocing. I left CPU Ref's at default .760 ref1 and .80 ref2 and went up 2 notches on MCH ref, seems to be working so far. I tried to leave at default but failed instantly. The skew doesn't work the same for 4500mhz either as on the UD3P. I went with Napalms 1000/1000/0/0, running blend now, for 4400 it was blending fine at 800/800/0/50.
http://img524.imageshack.us/img524/962/dq64500mhz.png
I've finally found a q9650 thread!!! Great!
I've got a water cooled q9650 on a P5Q Deluxe with 1066Mhz DDR2 - im hoping for 4.25Ghz - thats 9*470 - about!
U all recon this is possible? I hope so!!! - Stock speeds - my 9650 idles at 28c and loads after a couple of hours P95 at 38c - so ive plenty of room for a higher Vcore!!!
Any advice??
Sould be possible mate, start off with 400FSB , get to know ya CPU (what it likes regarding FSB term , PLL volts) , 450 is a no brainer on P45 (normally) and even 500FSB is doable on the P5Q Dlx but be prepared to pump over 1.35FSB term voltages... and you will need to get off the 1:1 Divider ( so good high speed rams are a must )
now I have a new baby! :) my 9550 E0 FPO L922B951 VID 1.1125V:clap:
today finishing testing and results is :
http://pic.ipicture.ru/uploads/090908/mzq73diz81.png
I belive,4Ghz too izzi for this chip, but my mobo is not good for quad 45nm.
465 FSB is good result, and it not a limit,but I dont want raising too much volt fot NB.
BTW, what temp is critical for NB? now I have 64'C at peak load, is this good or not?
Temps for chip is not more,than 79'C at LinX,Prime95 at 65-67
and my rig is:
Intel Core 2 Quad E8550 E0@ 3952 at 1.264V real
Thermalright IFX-14 +NOCTUA NF-P12-1300@
Asus Maximus Formula @ Rampage Formula x38
DDR2 2x2Gb G.Skill F2-8800CL5D-1100@1117
2xClub3D ATI RADEON HD4870 512MB OC Edition 800/950 CROSSFIRE
Raid0 2x320Gb Seagate SATA2 16Mb
DVDRW Samsung 182M LightScribe
PSU 780W Tagan Superrock
Full Tower Thermaltake Xaser VI + 4x120 vent. + Scythe Kama Meter
Windows7 x64 RTM
sorry,wrong thread
Hi Guys
I Thinck Problem With That Benchmark 3D Mark 01
Look:
http://shahrsakhtafzar.com/img/out.php/t18546_82516.JPG
82516 Is Not Low? For 4600Mhz CPU Frq And 1300Mhz Ram???
Any Sugesstion?
How are you ViViD i got 87k with the quad at 4500 and the GTX285 at stock clocks mines are 729/1674/2800, didnt tried to OC more cause i have a problem with XP that wont lent me use High CPU OC + High Clocks on VGA, just could do some benches on 3DM06 but on W7 i can do whatever i want.
Cheers
Sergio
Score is low mate for them clocks, should be more in the 89K region. Tried another driver ? thermal throttling ?
