Well i found out the volts i can run stable/errorfree
8.5x485fsb @ 1213.
My system likes normal skews only. After many many combinations i realized that the most important setting was nbv. In the beginning i started with 1.51nbv and i got a lot of errors and lock ups. I thought it was fsbv, vcore or ramv. I played with skews but nothing. I raised nbv a little @ 1.53 and then @ 1.55 but i kept getting lock ups during memtest without giving any errors before.The reason i raised nbv so little was that @ 8.5x480(only 5mhz lower than 485) i needed 1.49 to have a stable system. I went up @ 1.61v and i run 70-80%memtest without errors before my system freezed again. Finally i managed to find the magic - almost skyhigh - nbv setting...and that is...1.65:eek:. after that i could lower vcore from 1.325 to 1.29..;). Now ill try to lower ramv and see how itll go.
QUOTE]
bios
0803 settings:
Code:
Ai Overclock Tuner [Manual]
CPU Ratio Setting [8.5]
FSB Strap to North Bridge [Auto]
FSB Frequency [485MHz]
PCIE Frequency [105MHz]
DRAM Frequency [1216MHz]
DRAM Command Rate [Auto]
DRAM CLK Skew on Channel A/B [Auto]
DRAM TimingControl [Manual]-5-5-5-15
DRAM Static Read Control [Enabled]
Ai Clock Twister [Moderate]
Ai Transaction Booster [Manual]
Common Performance Level [07]
Pull-In of CH A/B all disabled
CPU Voltage [1.29375]
CPU PLL Voltage [1.50V]
North Bridge Voltage [1.65V] - 1.63V real
DRAM Voltage [2.10V]
FSB Termination Voltage [1.46V] - 1.38V real
South Bridge Voltage [Auto]
SB 1.5V Voltage [Auto]
Loadline Calibration [Enabled]
CPU GTL Voltage Reference [0.63X]
NB GTL Voltage Reference [0.67X]
DRAM Controller Voltage REF [Auto]
DRAM Channel A/B Voltage REF [Auto]
CPU Spread Spectrum [Auto]
PCIE Spread Spectrum [Auto]
CPU Clock Skew [Normal]
NB Clock Skew [Normal]
C1E Support [Disabled]
CPU TM Function [Disabled]
Vanderpool Technology [Disabled]
Execute Disable Bit [Enabled]
Max CPUID Value Limit [Disabled]
Intel(R) SpeedStep (TM) Tech. [Disabled]
