Originally Posted by
zoqiet
Must admit I'm starting to get a bit annoyed with the vdroop on this board. With load-line cali disabled I put 1.33vcore in bios, it shows as 1.3 at idle. Bit too high idle volt, since my clock is stable at 1.28 full load, although I can live with that. But during full load it drops even further down to 1.26... Thus making my system unstable. I turn up the bios volt quite a few steps to actually hit 1.28 during full load, but then my idle skyrockets.
So, I enable load-line instead and set the volt to 1.28ish, My idle stays at 1.26, but during full load my volt get boosted to in between 1.31 and 1.32. Which is not needed, thats just extra heat for an already hot CPU.
I set my volt to 1.26, full load jumps to 1.29-1.3. Good enough, but then my Idle volt drops too low, and my system crashes in between full load and idle. Sighs :P
Gonna try another bios than 1504, hopefully I find something less annoying :>
