Impressive:up:
I'm tempted to toss a 8400 in today and play around
:party: http://i237.photobucket.com/albums/f...istmas_t_3.gif :party:
MERRY CHRISTMAS...I WISH YOU GUYS ALL THE BEST FOR THE NEW YEAR.
http://i266.photobucket.com/albums/i...usxmasgift.jpg
Merry Christmas Everyone, hope you all have a safe and happy holiday :)
thx guys!!!!! ;)
merry xamas too ;)
anyway, what about my temps and voltages?
http://img114.imageshack.us/img114/9...1454gy2.th.gif
vCC = 1.240
vFSB = 1.25
vNB = 1.40
vPLL = 1.54
vDIMM = 2.2 strap 333 @ 1.080mhz
@ Liquid cooling (CPU & NB)
Nice Kurtz, that is a ridiculously good cpu you have there. NB voltage may be a bit high not sure if you need that but everything else looks spot on. I assume you're running you ram at 600 MHz, at CL5 my CS kits needs 1.98v at 600 MHz to be stable, but depends on your timings, and not every kit behaves the same.
Man, I think my memory controller has finally bit the dust. Every so often it used to act up. It would not allow me to run my memory in Dual config, only single would work. After a few hours of resetting, reseating, clearing CMOS it would usually kick back in and start working again.
Recently I moved back from Japan and set my PC back up here. I can't get dual channel to work for the life of me. Even under default settings without overclocking. I tried different sticks of RAM. Basically the first two slots work but the second two do not.
Any ideas?
You have tested each dimm with memtest I assume
Check the mobo dimm slot area for swollen / fat capacitors, if you see any its a RMA.
You could give Asus a call, doubt there open today but it couldnt hurt to try.
North American #'s
510-739-3777
812-282-2787
If you do have to RMA the board request teh California facility, it has been my experience that the losers work in the Indiana facility, avoid it all costs
the DIMMs are @ 540 cl.5 2.2 vDIMM ... i dunno why i can't boot with a lower voltage ... anyway i need to test my HW better ...
this is only my first run ...
however Crytik just a tip: what are the max voltage that i can run onto my board safely? i mean vPLL, vFSB and vNB ... cause i wanna try and reach 5Ghz :D
edit: new result
http://img381.imageshack.us/img381/7...1855le4.th.gif
Merry Christmas to all, and Happy Holidays! :toast:
THX.
and merry xamas for all
Merry Christmas and a happy new year !! to all of you ppl.
Thanks for the response,
I already have an RMA coming. This board qualified for the Advance swap.
Each stick of RAM is fine by itself in either of the first two slots. The last two wont boot with one stick in either.
This kind of thing had happened to me on the striker II formula as well...with different RAM even...
I hope they RMA with new boards and not refurbs..
I tried two different types of RAM, so it has to be the board.
another big shot for me ... now i've fixed the vNB to 'only' 1.30v ... :p unfortunately the bios bug wants 1.20 vFSB cause if i set 1.10/1.15 i can't reboot ...
http://img376.imageshack.us/img376/6...1242za9.th.gif
4600mhz @ 1.264 vCC
however, a friend has told me that the most important GTLs are the 0/2 and NOT the 1/3 ... so i used the Cryptik formula to calculate the 'distance' thru the 0.635 and 0.667 GTLs but ik haven't carried the 1/3 GTLs near the 0/2 ... i did the contrary ... so i settled the 0/2 GTL +40mV and NOT the 1/3 to -40mV ... :)
edit: AND NOW HERE WE ARE!!!! :D
http://www.vocinelweb.it/faccine/big/pag2/14.gif
5000!!!!!!!!!
http://img383.imageshack.us/img383/8...1316nq2.th.gif
VALIDATOR: http://valid.canardpc.com/show_oc.php?id=469816
vCC: 1.36
vFSB: 1.20
vNB: 1.30
vPLL: 1.54
vSB: Default
i need some voltage for a superPI ... :D stay tuned ... :p
Hi
Mary Xmas Happy Holiday
http://valid.canardpc.com/cache/screenshot/468146.png
Valid Link
hey guys i have an E0 Q9550, what would the best official/beta or modded BIOS be?
GTL calculations -> http://www.xtremesystems.org/forums/...d.php?t=202292
Also you can use edit - believe me it works just fine.
cheers mate.... funny, edit has never worked for me :p
Just got home today. My family spent Christmas out of town...
MERRY CHRISTMAS EVERYONE!!!
Sorry for the late greeting :)
