Since many people are switching to A64 for the first time, I thought I'd provide a little primer. I posted some of this information in the Asus A8V thread, and thought I'd give a little broader explanation here.
Technically speaking, there is no FSB on A64 systems. FSB is a bus that allows the CPU to communicate with system memory. A64 systems use a different type of connection called HyperTransport. It's a point-to-point link. The term HTT is used to described the connection speed. This is roughly equivalent to FSB but not the same thing.
The general formula for determining optimal HyperTransport speed is HTT (FSB) X HT multiplier. The multipliers are sometimes listed in the BIOS as frequencies that are multiples of 200MHz. 1000MHz = 5x, 800MHz = 4X, etc.
The HyperTransport speed should not exceed the motherboard's specs. The Asus A8V, for example, has a maximum HyperTransport speed of 1000MHz. So using the formula, if you have HTT at 250, the HT multiplier should be set no higher than 800MHz (4X). 250 X 4 = 1000.
More information about HyperTransport can be found here (
http://www.hypertransport.org/faqs.html#b) and here (
http://www.amd.com/us-en/Processors/...2_2353,00.html)
