I have actually owned quite a few EK parts, I acutally have 7 in my rig right now (thankfully nothing nickel plated). A lot of the issue people are having is with the fact that the blame for this is being pushed onto the customers. The people who are experiencing issues with the blocks apparently didn't follow a set of unwritten guidelines for keeping the nickel plating from degrading and are responsible for the damage, but EK will be nice and RMA these anyway. Slashdot car analogy: This would be the same as me running 91 octane in my car, having the engine blow up, then being told that BMW will replace it but it was my fault that I was running just 91 octane without their tested additives. No other engines blow up on 91 octane, just theirs, and it's my fault. That is not an acceptable response.
There is no apparent intent from EK to fix this issue that seems only to occur with their nickel plating. If EK stated that they are planning on modifying their nickel plating so this won't happen in the future, that would be great. If they said they were going to use a different company for their nickel plating that would be great. If it was stated that measures to resolve this problem in any way would be taken, that would be great. That hasn't happened. They pushed blame onto the customers and have stated no intent to change their plating process. This alone is reason enough for a lot of people not to use their products.
All we have gotten is "this isn't a nickel plating problem" and "you need to use these specific additives" and no "we will be changing our process". They can RMA everything for free and replace all the blocks as much as they want, but if the original problem isn't addressed (and most here agree that it hasn't) then the problem isn't solved. Until EK states that their plating process was flawed (or at the least that they will be changing it) a lot of people won't be buying their nickel plated blocks and a lot of people will be bashing the company for how this was handled.
