one would think, but maybe 775's can run two sockets.
1333 fsb? or have they added the 1600 multiplier to the bios :D :D :D :D
put the heatsinks shown on this post are 775, not 771 which are nearly identical to 604 (just lower).
the northbridge will run hot with the cpu orientation. will need a fan.
http://www.xbitlabs.com/news/cpu/dis...011211728.html
they claim 771
especially packed that tight. I had to build a duct which leads to a 120mm fan to cool the ram and nb on my two dual 5000x sm systems.
i was really hoping for 775, cheap dual socket like the old days.
No...you can't say that -Vapor
I'm loosing interest already, 3k retail a cpu!
can someone post a link or explain to me what the difference between regular ddr2 and fb dimm (or fd whatever it was) ddr2 memory is?
Also this is just a truly sickening setup...really amazing too see, I want one even more now!
FB-DIMMs use what's called an AMB (advanced memory buffer) chip located in the center of the memory module. An FB-DIMM transmits data in packets, using a bi-directional serial bus. Also, a conventional memory controller requires 240 trace lines per channel, while an FB-DIMM requires only 70. This reduces the complexity of the circuit layout.
come on FUGGER show us some nice pics of that system
http://forum.offstage.be/images/smilies/threadpics.gif
P.s put in 3 8800 ultra's and break your the 30K 06 record :D
Still would have been nice if this board had used DDR2/DDR3 normal memory. Quite a few here would have scooped one up.
http://www.xtremesystems.org/forums/...79#post2716379
http://www.overclockzone.com/zolkorn/Pic/r10.jpg
It was noted that the operating system was 32 bit and not 64-bit, and that is resulting in a large performance drop. Also, the RAM was noted to be running in single channel.
http://www.xtremesystems.org/forums/...3&postcount=76
Fugger - 34,839
ZoLKoRn - 25,004
800 megahertz difference.
32-bit operating system vs 64-bit.
RAM.
9,835 difference. I can't count. :P I apologize.
any word if Skulltrail will hit the retail shelfs this coming week?
It will release on February 4th (Monday). Problem is, very few stores will have stock since this is a premium quantity-limited product.
couldnt find these one anywhere, first one look very familiar ;)
http://www.jens.tauchclub-krems.at/d...skulltrail.jpg
http://www.jens.tauchclub-krems.at/d...kulltrail).JPG
source: http://www.jens.tauchclub-krems.at/d...enchmarks.html
here is how it scales:
2x4000 = 11.8
4x4000 = 23.43
8x4000 = 36,97 (Intel Yorkfield QX9775 @ 4Ghz 400x10)
from 2 to 4 is good, but from 4 to 8 for 98% Clock increase there is only 58% efficiency increase.
