this program is a bit scarey when you run orthos prime at 320 x 11 (3.52 GHz) @ 1.45v and it climbs above 70c :eek:
this is pretty much expected from core readings, correct?
Intel TAT gives me 17C more @ idel and 10C more @ load compared to Core Temp speed fan and Gigabyte Easy Tune :confused: I have a E4300 BTW
Got some funny readings with an E6600 and Gigabyte DS4...
CoreTemp 0.94:
#0: 20ºC
#1: 19ºC
Ambient according to a digital thermometer:
23ºC
Waterblock temp:
27ºC
Is it somehow possible to output the coretemp readings to samurize?
2 favouriites together Tetedeiench developer of OCCT has bta =
OCCT with Coretremp Support
works well.
http://homepages.nildram.co.uk/~chsm...22h37-CPU1.png
http://homepages.nildram.co.uk/~chsm...22h37-CPU2.png
Version 0.95 - 17th March, 2007
- Fix: Revision F Turion/Turion X2 detected wrong.
- Fix: Core Temp fully loads one core on a dual core AMD CPU.
- Fix: Core Temp crashes on Dual Core Opteron 200 series systems.
- Fix: Core Temp misdetected certain Dual Core Opteron CPUs.
- Fix: Must set Core Temp to run as Administrator in Vista.
- Fix: Can't see Core Temp GUI if Core Temp was last closed minimized.
- Fix: C2D L2 rev. report very low temperatures. (Tjmax to 100C)
- Fix: Core Temp reported wrong temps after a while. (Driver conflict)
- Fix: Core Temp reported Max VID on Intel CPUs. (Now shows current)
- Add: Show temperature in System tray.
- Add: Manual refresh option by pressing F5 or "File" Menu.
- Add: Show "Delta to Tjunction" temperature for Core 2 CPUs.
- Add: Support for latest Intel and AMD CPUs.
- Add: Minimize/Restore option in system tray icon right click.
- Add: Save last window position.
- Add: Prevent 2 instances of Core Temp from launching.
- Change: Rewritten Intel CPU recognition code.
- Change: Core 2 Duo codename change to Conroe-2M from Allendale.
- Change: Pop up bubble-window with temperatures removed.
- Change: Not Beta status anymore.
Good stuff mate :clap:
Keep up the good work :)
Yes, same here. Both http://www.thecoolest.zerobrains.com/CoreTemp/ and http://www.alcpu.com/CoreTemp/ fail to open :shrug: :help:
http://69.93.81.146/~thecoolest/CoreTemp/
I added the link in fine print at the bottom of first post too.
when will it work on phase?
Whenever Intel fixes the DTS. This is not a software glitch AFAIK.
Hi Arthur, I believe there exists some problem regarding name resolution and access to alcpu.com, but I'm not capable to identify where is it.
Name servers here in Hawai cannot resolve alcpu.com or www.alcpu.com to 69.93.81.146. And 69.93.81.146 is completely inaccessible too. Tracing route to 69.93.81.146 stop at po1.car03.dllstx6.theplanet.com, so no luck following this approach.
Name server for alcpu.com is ns1.psk-dns.com (69.93.81.146). Trying to use that to resolve alcpu.com failed. By the way, ns1.psk-dns.com looks inaccessible too.
Talking to a UK friend last night, he reported the same problem now although he was capable to download the 0.94 version weeks ago directly from your website.
I know this doesn't help too much, but I'm reporting what I've discovered so far to let you know.
I get a BSOD with 0.95. :(
Never had any problems with previous versions.
Edited.
Thanks for all your work...
If anyone is having problems with Core Temp crashing on them, please look at the appropriate thread and post there your problem and system spec. I think this way it will be very effective at getting to the bugs faster.
Intel Thread
AMD Thread
I just registered and posted over at your forums "The Coolest", thanks for a place to post our issues with the program! Since I consider your program "CoreTemp" a nessessity I just searched and found CoreTemp v0.94 so I can use it in the meantime until v0.95 is working on my rig without shutting everything down! If anyone needs a linky for CoreTemp 0.94 just ask!
TheCoolest,
coretemp 0.95 now reads the correct temp on e4300/e4400s :) (and a different tjunction o0)
however, i have encountered a problem soon as i stop priming (this will happen every time i prime for a while with coretemp 0.95 open and then i stop)
FYI, I am 24 hours orthos stable at this clock
priming
http://img458.imageshack.us/img458/6960/coretempdc8.jpg
stopped
http://img132.imageshack.us/img132/1...mperrorhz9.jpg
http://img132.imageshack.us/img132/1...perror2do9.jpg
http://img490.imageshack.us/img490/4...perror3uy5.jpg
That's quite interesting. I will investigate, thanks.
I may have found a solution(!) to the BSOD problem in 0.95.
My test system stopped crashing. I need more computers with this problem to confirm the fix is working.
If you want to test the fix, please contact me via one of my IMs.
Thanks,
Arthur
Version 0.95.4 - 22nd August, 2007
- Fix: Core Temp causes restarts/BSODs on start.
- Fix: Core Temp causes hard shutdowns on some AMD systems.
- Fix: System tray icons are black squares on less than 32bit desktops.
- Fix: Some other minor bugs fixed.
- Add: Support new Intel CPUs.
Anyone please could do a zip file with Version 0.94 and this newest 0.95.4 and make an alternative link (rapidshare) to me? Trying downloading direct from the site since version 0.94 but no way my server here in Brazil recognizes the site adress, dont know why, probably a proxy issue? Wathever i try always get the "page cannot be bla bla bla...." So, please anyone could do that for me? :(
Just out of interest, are you ever going to get driver signing so coretemp will run under Vista 64bit. The current workaround is just trash, would be nice to have it 100% supported and functional under 64bit vista thats for sure. :up:
