Results 1 to 17 of 17
Thread: Computer Case Modding - Guides, Tips & Tutorials
    Royal Administrator
    Jul 2005
    New York City
    If you find or have any good guide, tip or tutorial, please post a link!
    Sep 2008
    Montenegro, Europe
    Useful
    Thank you, really useful advices
    Rig from 2004 - S478 Intel P4 3.0Ghz@ 3.6Ghz on stock cooler. 2X 160GB HDD, 6600GT - later 7600GS, 4X 512mb DDR.
    EX RIG: Athlon LE1620 @2,8 Ghz, nForce 5 motherboard, 2GB RAM 800 Mhz, 400GB WD, 8600GT 256MB DDR3, 550W.
    Current RIG: E5200, 2GB RAM, 400GB, HD4850 512MB, NZXT Apollo, OCZ Vendetta 2, ASUS P43, 600W PRO PSU
    Banned
    May 2008
    vermont, yes i like women
    this is a ok one from techpowerup. http://forums.techpowerup.com/showthread.php?t=32848
    EDIT: here is a thread with EVERYTHING you need to know about case modding :P
    http://forums.techpowerup.com/showth...ghlight=MKmods
    Royal Administrator
    Jul 2005
    New York City
    Cable Sleeving Guide added to the list.
    May 2007
    Sweden
    be the judge
    I did this one myself, if you don't like it you can delete this post. . .
    LED Fan external switch mini guide
    They say the definition of madness is doing the same thing and expecting a different result.
    Howlin' Pelle Almqvist
    Project Log Completed: all internal v1000
    Sep 2008
    hey i dunno if i should put this in the cm690 modding section since i should be doing it on a cm690 at some point... but i guess it could be done to all cases or even a new thread? idk im new to these parts
    i was lookin thru the cm690 mod thread when i saw one where someone added a 35% tint to the window he modded onto the side panel so that it was dark when turned off, and lit up with CCFL's when on.
    my question is could you have some flames or other vinyl type thing in between the tint and the window, so you couldn't see it when off, but lit up when on? is that possible?
    Dec 2007
    San Francisco
    thanks for the great links
    Jan 2009
    Chandler, Arizona
    Very expansive list, all of them. Definately will be very helpful when I get into modding my case.
    -trekie86
    Antec 900 Black
    Rosewill 600W RP600V2-S-SL
    Gigabyte EP45-UD3P Rev 1.0
    Intel E8500 @ 3.8 GHz
    2 x 2 GB GSkill PC6400
    EVGA Geforce GTX 260 Core 216 SSC 55nm
    EVGA 8800GTS PhysX
    640 GB WD HDD 7200 RPM
    Quote Originally Posted by dengyong View Post
    Started life as a FTW and ended up as a WTF.
    Oct 2008
    Flint, MI
    id like to see a guide to cutting out a hole to mount a rad/radgrill
    Jul 2007
    Cambridge, UK
    [SIGPIC][/SIGPIC]
    Sep 2008
    there are quite a few unique tips on the mod nations forums site.
    Mod Nation guides and tips
    May 2009
    Nice case mod.
    Dec 2009
    Nice guide thanks for the share.
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    Life saver
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Mar 2010
    I guess that by now you expert modders will already know this site but just in case, I've just found it and it looks helpful.
    http://scc.jezmckean.com/home
    Hope you like it.
    Feb 2008
    sunderland
    hi guys i wanted to show you a pic of my haf x case.
    I have done a window mod that i havent seen any one do it but i cant seem to upload the pic.
    thanks here is the link below
    http://www.youtube.com/watch?v=8sLYP...ature=youtu.be
    Aug 2003
    mini mod coolermaster storm enforcer fans
    hi
    I have a 200 mm fan on front intake 110 cfm and one on top
    I also have a 120 mm rear approx 45 cfm
    I am planning to put a 120mm 103 cfm in rear
    how does this sound?
