Page 1 of 3 123 LastLast
Results 1 to 25 of 54
Thread: r1150/r14 tev/evap experiment
    -100c Club Member
    Jul 2005
    England
    this experiment is built around cascade 6
    which can be found here
    http://www.xtremesystems.org/FORUMS/...d.php?t=184106
    Goals: to see if a tes2 can be used to control the temperature of a cpu evaporator using R14 and if so load holding ability
    parts:
    tes2
    chill evap
    first gas R1150
    first frost r1150
    there are many things here i need to understand more
    along with load testing but as an experiment its showing some promise
    readings/pressures to follow
    1. The first rule of Bench Club is, you do not talk about Bench Club
    2. The second rule of Bench Club is, you do not talk about Bench Club
    3. If someone says stop, goes limp, taps out, the the benching is over
    4. No bummers in the batcave, apart from unkie dave
    5. One Bench at a time
    6. No air, no water
    7. Benching will go on as long as they have to
    8. If this is your first night at Bench Club, you have to Bench
    -100c Club Member
    Jul 2005
    England
    information on the mod to the tes2 "by August"
    august has kindly re-writen a post in english for me on how to mod a txv for r14
    many thanks to him for this mod
    http://www.extremecooling.net/index/...php?38725.last
    OK, for our english friends here an descripton for changing gas in sensor of an TXV:
    You need an TXV, it sould have an Outlet to Braze! If possible, use outer pressure compensation.
    it`s very easy when the bulb has 2 captubes already, older Danfoss Valves have this.
    You have to let out the pressure, after this you braze an Schrader Valve on the Bulb/ Sensor.
    That was it Now you can pull vacuum and fill it with the gas you want (as a number, start with 5bar, in my R14 TEV is about 10-13bar )
    The difficould thing is the very, very less volume of the bulb. If you take off your filling hose, pressure has gone!
    You need a quick coupler like this:
    http://kaeltetechnik-shop.at/Schnell...g-16C-Imperial
    And then it should work!
    In lower stages of cascades, note:
    I had some problems because TXV was leaking at superheat screw. Never try to move this screw when TXV is cold, and always put on the cap before cool-down. At room temperatur it is normalle leak-free.
    An little reciever like an 50g- filter dryer is enough, you save refrigerant (R14 is expensive!)
    6. No air, no water
    Oct 2004
    Crazypc.ro
    Between the Bulb/Sensor and Schrader Valve a very restrictiv capilar(0,5mm) and also long enought can be brazed...
    So what is the end result that you want here, -130 constant temperature? and at any time of the day you want it?
    -100c Club Member
    Jul 2005
    England
    Quote Originally Posted by quintus View Post
    at this point i am interested in the r14 and will work with this setup
    after that i am keen to see how the tes2 copes with the load from a cpu while benching
    and of course if -130 is possible or near with this arrangement
    6. No air, no water
    Feb 2008
    London Ontario Canada
    cant wait to see this finished good luck
    Case: Corsair 400R
    PSU: Corsair HX1000W
    mobo: Maximus IV Gene
    CPU: 2500K @ 4.2ghz 1.19 volts
    RAM: Gskill Ripjaws 1866mhz 2 x 4 gigs
    OS Drive: Kingston Hyper X ssd 120 gig
    Graphics: XFX HD5850
    Cooling: Corsair H100
    OS: Windows 7 Pro 64 bit
    -100c Club
    Jun 2005
    Slovenia, Europe
    That's very interesting bazx, keep it up!
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    The mod that you performed on the TXV is very interesting. Makes sense, don't know why I didn't think of it earlier. Think I'll have to one day try this will R1150 using a similar TXV. Very interested in seeing your results with R14 though. Hope you can get it working
    Jun 2006
    Near CeBIT-City Hannover
    Hey Bazx!
    For better results, you should mount the tev bulb with a clamp. Here a pic with the orginal clamps:
    This is important, because 50% of heat transfer goes over the clamp.
    I also would recommend you insulation around the suctionline/ captubes because the tev needs bubble free refrigerant.
    Just want to help you removing error sources.
    Good Luck!
    Paul
    Quote Originally Posted by Xeon th MG Pony View Post
    ....and avoid being a total venting loser!
    May 2005
    Boulder, Colorado
    What is the material used in the capillary tubing on the TXV? Steel?
    I am Xtreme
    Mar 2005
    You also need to insulate over the tvx,only a small portion is in contact with the tube,the rest with much warmer ambiant air.
    The Laws of Thermodynamics say:
    Zeroth Law: "You must play the game."
    First Law: "You can't win."
    Second Law: "You can't break even."
    Third Law: "You can't quit the game."
    Do you wanna Play Thermodynamics ???????? I forgot "you must"
    -150c Club Member
    May 2005
    Northeast, USA
    Bazx! Great project!
    If you have any questions that I might be able to help with R14, I did have a hard time getting it to work, and have a large log as I tried different approaches.
    If you have a cooling question or concern feel free to contact me.
    approaching aphelion
    Nov 2005
    Aix-en-Pce | France
    Interesting to say the least.
    Best Regards,
    Xavier
    "I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
    -100c Club Member
    Jul 2005
    England
    i am now waiting for a gas delivery for the r14
    should have the gas around thursday for the next step
    6. No air, no water
    -100c Club Member
    Jul 2005
    England
    bit nippy out in the shed tonight but i have had some results with the R14
    still early days but i am very happy to have the stuff working at last
    next up i will build up the real line set/toms evap and put in a small receiver and load test
    6. No air, no water
    -150c Club Member
    May 2005
    Northeast, USA
    Good to see!
    Oct 2006
    England
    Outstanding work baz, -127c with a little tuning we will see the full goodness of the R14.
    Hats off to you again mate this is truly outstanding work.
    -100c Club Member
    Jul 2005
    England
    thanks paul
    tbh adam i was beginning to think i would never see frost from r14
    i will need to work on the SH settings some and the bulb pressure and i will break it all down and make up the real line set and start load testing
    @ moc you are right mate i will use the metal strap
    6. No air, no water
  18. #18
    Feb 2008
    Thats cold now lets see some temps under load
    Case: Corsair 400R
  19. #19
    -150c Club Member
    May 2005
    Northeast, USA
    Should be able to do quite a bit in vacuum with those compressors actually.
  20. #20
    Jun 2006
    But the smallest valve for the Danfoss TEV are 0X = >300W so I guess the valve can not close that much that the compressors run in a vacuum.
    @bazx
    Will be interesting to see how fast the TEV reacts to load!
  21. #21
    -100c Club
    Jun 2005
    Slovenia, Europe
    Looking good bazx, show us some loaded temperatures
    Best Regards,
    N.
  22. #22
    Jun 2008
    Denmark, near Copenhagen
    Quote Originally Posted by Moc View Post
    @bazx
    TXV can go down to 20% of their listed capacity without starting to pendle.
    That means that 20% of 300W = 60W. So it should be good enough for you.
    It probably won't react that quick. After all, they are made for slow decreasing/increasing loads.
    Also, when you have a certain load, it needs some time to find the right position to be in.
    A thumb of rule: When you make an adjustment on a TXV, you should wait as long as it takes to smoke a cigaret.
    So around 5-7 minutes, before reading temps, pressure, SH and so on.
    OCTeamDenmark.com Crew
    Cooled and sponsored by Coolerkit.dk
    CPU: E8600 @ 4000 MHz
    Mobo: Biostar Tpower I45
    RAM: 2*2 GB OCZ PC-6400 @ 800 MHz 4-4-4-12
    GFX: Zotac GTX280
  23. #23
    Jun 2006
    Quote Originally Posted by Duzter View Post
    Your a very slow smoker !
    I never heard the 20% theory. Do yo have datasheets or a book where it's written?
  24. #24
    Jun 2008
    I'll see what I can find.
    GFX: Zotac GTX280
  25. #25
    -100c Club Member
    Jul 2005
    England
    @duzter thanks for the info
    before breaking the line set down i tested again to make sure it is still working ok and turned in the SH 1/2 to see if i could get the -130 shot
    6. No air, no water
