Page 1 of 10 1234 ... LastLast
Results 1 to 25 of 237
Thread: Cascade 6 (mobile assault unit)
    -100c Club Member
    Jul 2005
    England
    most of the parts for this build will be comming from cascade 4 accept the comps and cases
    http://www.xtremesystems.org/forums/...d.php?t=126920
    She lived a short but glorious life 12-17-2006 to 11-04-2008 R.I.P my freind
    any ho on with the new
    Cascade 6 is to be a mobile unit as I have had the need to go to events of late and my current cascades have been difficult at best to move around
    With this unit the compressors will be mounted around a central column along with the oil separators and most of the first stage
    From this the pipe work will raise up throw a table top where it will be routed to the evaporator, heat exchangers and gauges
    This unit will also have the ability to change evaporator sets with out the loss of refrigerant along the lines of cascade 5
    So could be used in a skulltail 2x CPU configuration or GPU/CPU or just CPU
    As the chassis on this build is key this unit i may well be making changes to it for the best arrangements as the build progresses
    The top and sides of the unit will be closed in this build
    The evaporator is to be the new V8 from SoddemFX
    first stage
    NP 362P R-407C LG
    Condenser:1x STVF 273
    de-super heat 1x STVF 100 Luve (will be able to turn the fan on and off if needed )
    1,6l receiver
    Danfoss tev: Tes2 00 orifice
    Hx: 16 plate
    in line filter 3/8
    in line spun filter to cap
    High pressure gauge
    R507
    second stage
    compressor: Hitachi CHY33MC4-U 17630 BTU
    Oil separator: temprite 900
    danfoss high pressure cut off KP 5
    Hx: 12 plate
    TEB2 danfoss
    STVF47 de-super
    cold ice pressure relief valve 24 bar
    High pressure gauge
    spun drier/filter
    R23
    Third stage
    STVF47 de-super
    High pressure gauge
    spun drier/filter
    5.6L expansion tank
    R14
    -100c Club Member
    Jul 2005
    England
    This is the chassis so far tomorrow i will mount the 2x oil sep's
    -100c Club Member
    Jul 2005
    England
    -150c Club Member
    May 2005
    Northeast, USA
    Very nice job, I love the idea, very thoughtful! I'm assuming you made that table thing yourself? Great job I'd recommend r14 for the third stage, but why not try an autocascade?
    If you have a cooling question or concern feel free to contact me.
    Jul 2006
    Bucharest, Romania
    Haha, nice assembly, but i wouldnt be anywhere that thing when the 3 rotarys are up and running.
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Hot damn bazx, that looks awesome. Great idea on the chassis also, should really help with usability. Nice job welding that steel together
    -150c Club Member
    May 2005
    Northeast, USA
    So lets see, condensers going to be mounted to undersize of the "mobo" tray? I think your going to need more of those little pull stands
    Jul 2005
    Austria
    Make sure that you mount different wheels - WITH brake
    May 2005
    Boulder, Colorado
    Quote Originally Posted by godmod View Post
    What if this is a dual-purpose chassis though? It is after all a mobile assault unit, I think bazx is really creating the opposite of a flamethrower, a cold thrower! In all seriousness though, brakes would be helpful as stuff tends to get accidentally bumped from time to time and it'd suck to drag everything off the table and snap a suction line.
    -100c Club Member
    Jul 2005
    England
    hehe these are not the final wheels just mock up once all the welding of the mounts is compleat its going of to be powder coated
    yes nol the condencer will be under the table also the receiver
    and most of the oil sep just the top of each sep will be visable from the top
    -100c Club Member
    Jul 2005
    England
    Quote Originally Posted by marru View Post
    why
    Admin
    Mar 2003
    North Texas
    Very nice idea bazx This is like a new program coming on the television. I like it.
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    -100c Club Member
    Jul 2005
    England
    Quote Originally Posted by runmc View Post
    i have missed the phase section and have wanted to build a new cascade for some time ron
    so will be enjoying this build a great deal
    @ nol i was thinking R14 myself never used it before so it will be a new refrigerant for me
    as for auto cascade i will build one eventually but i am not ready yet
    1. The first rule of Bench Club is, you do not talk about Bench Club
    2. The second rule of Bench Club is, you do not talk about Bench Club
    3. If someone says stop, goes limp, taps out, the the benching is over
    4. No bummers in the batcave, apart from unkie dave
    5. One Bench at a time
    6. No air, no water
    7. Benching will go on as long as they have to
    8. If this is your first night at Bench Club, you have to Bench
    Jan 2007
    Anchorage, Alaska
    It is amazing what people come up with. Weld a heavy duty dolly to it and you have mobility and stability.
    -150c Club Member
    May 2005
    Northeast, USA
    Trick to R14, have an extremely short unrestrictive captube on the r1150 stage, you need the capacity if your going ambient down to -90C and expect to transfer load well.
    Xtreme Cruncher
    May 2007
    In a hell hole called Sac
    Use the captube like an orifice tube?
    Quote Originally Posted by [XC] Kayin View Post
    Should the RIAA ever target me, I will immediately forfeit US citizenship and move back to reservation, which has no extradition policy and would probably tell Whitey to get bent or we'll scalp you and take your women...
    Free Omastar!
    [SIGPIC][/SIGPIC]
    -150c Club Member
    May 2005
    Northeast, USA
    LoL no not that unrestrictive, just less then you'd normally use. Sdumpers has 5ft of .031" on second stage.
  18. #18
    Jun 2006
    Near CeBIT-City Hannover
    00 nozzle will be too small I think.
    With 1kW load, -40°C 4K Subcooling and 35°C condensing temp, DanVen 5 says
    02 nozzle !
    Quote Originally Posted by Xeon th MG Pony View Post
    ....and avoid being a total venting loser!
  19. #19
    -150c Club Member
    May 2005
    Northeast, USA
    Why the monsterously huge compressors by the way? Thats going to be a hell of a 3 stage. Revolutionary idea too. Wish I could make that sorta stand
  20. #20
    Jun 2006
    Move to Europe ....
    -120°C @ 300W ?
    Bazx, what do you want to hold in the third stage?
    Perhaps a bigger Plate HX in the first stage would better...
  21. #21
    Jul 2005
    Austria
    Seems like nowadays 2 stage cascades become uncool and 3 stagers are cool 8)
  22. #22
    -150c Club Member
    May 2005
    Northeast, USA
    Well Bazx, Sdumpers, whom else got one? Ricky. Fuggers got his but I havent seen him use it lately...
  23. #23
    Jun 2006
    And Fuggers is R4/5**/R1150/R1150 what is in my opinion quite useless.
    R14 or R50, if you have a -100°C second stage (under load!) make sense.
  24. #24
    -150c Club Member
    May 2005
    Northeast, USA
    R50 requires too much flow, and chilling from 0 to -100C is horribly hard actually. The benefit of r1150 in third again is it acts almost like a water loop
  25. #25
    approaching aphelion
    Nov 2005
    Aix-en-Pce | France
    Very nice project Bazx
    40.7cc/rev + 33cc/rev + 33cc/rev
    Best Regards,
    Xavier
    "I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
