Results 1 to 15 of 15
Thread: XP-M FSB overclocking problem (and solution)
    Feb 2004
    Sweden
    Erlier my max stable FSB was 215Mhz . I decided to do the L12 mod.
    First I tried this mod, http://www.geocities.com/trats102002/nf7sFsbsense.html wich didn't work.
    The I tried this mod, http://downloads.modlabs.net/bios/pic/L12mod.jpg wich worked Thanks to TicTac
    With this mod I was able to get to 235Mhz FSB (1.7v vdd, 2.9v vmem, 2-2-2-11, cpu interface enabled) Not to bad.
    Running 230x12=2760Mhz stable, no problem. Running 200x15=3000Mhz @ 2.0v stabel, no problem .
    BUT running 230x13=2990Mhz @ 2.0v, problem! No boot, just alarm sound.
    Could not understand this weird problem, until the 10/10.5x multp. problem crossed my mind. It seems like I have this problem (no boot above 222Mhz FSB) on multip. 13/13.5/14/14.5 and probably eaven 10/10.5.
    I downloaded TicTac's D23 3D-Fire bios with fixed romsip tables, and volá. 230x13, no problem
    Thanks to TicTac (again)
    [ Intel Q6600 B3 @ 3.2GHz ][ Asus P5K DLX ][ 4Gb PC6400 ][ X1900XTX ]
    Jan 2004
    Frankfurt, Germany
    Nice, I'd also like to have one of these 3ghz xp-m
    May 2004
    Sweden/Malmö
    Det är kalas oozberg!
    -=XP-M 2400+=- -= ABIT AN7=- -=9700PRO=- -=TW/WB 2x256(BH5)=- -=Antec True Power 550W=- -=h2O=-
    -=Clock=245x11 | 11-2-2-2 (sync)=-
    Xtreme X.I.P.
    Nov 2002
    Shipai
    hooray for tic tac!
    /dev/zero
    Nov 2002
    Germany, Berlin
    Looking great... Tictac is the LORD of the Abits it seems :thumbsup:
    Xtremesystems.org
    i7-4820K * ryba 2-stager + 1-stager * EVGA X79 Dark * 32G Team Xtreem 2666C11 * EVGA GTX 680 SC Sig. * Intel G2 80G * Corsair HX1000 * Lian Li PC-70B * Watercool Heatkiller, EK Fullcover/Backplate for GTX, MCP355 Dual Setup@Koolance RP-402X2, PA120.3+Alphacool 360, Tubing 16/10.
    Jan 2004
    Frankfurt, Germany
    btw SAE how many volts you're giving your xp-m ?
    Sep 2003
    Poland, Lodz
    Re: XP-M FSB overclocking problem (and solution)
    Link doesn't work
    My problem is FSB >233 (233 works fine but 234 no)
    NF modded Vmem=Vio, Vtt too (4th metod)
    Mobile 2500+, L12 mod
    Ram 2x256 Buffalo BH5
    I Use memtest (windows)
    Feb 2004
    Sweden
    The link did work before
    And I have also discovered that the problem still remains
    I tried to run 215x14=3010Mhz, no boot (and alarm sound )
    But multp. 15 seams to work good after all 210x15=3150Mhz, no problem
    Weird problem...
    /dev/zero
    Nov 2002
    Germany, Berlin
    Hmm. Between 1.95 and 2.08V.
    Xtremesystems.org
    Apr 2003
    Mushroom Hill Zone
    Can you find a link to that second mod that does work?
    Gizen:
    Core 2 Quad Q9450 @ 3.2Ghz
    8GB DDR2 DC @ 800Mhz 5-5-5
    512MB GeForce 8800 GT
    750GB 7200rpm SATA 2.0
    Blu-ray reader
    X-fi
    20" 1680x1050
    Apr 2003
    Mushroom Hill Zone
    BUMP! I could really do with that link.....
    Gizen:
    Blu-ray reader
    X-fi
    20" 1680x1050
    Xtreme Cruncher
    Nov 2003
    MD, USA
    erm the link works for me...
    3570K ● Asus V Gene ● 8GB Mushkin DDR3-2133 ● EVGA 660 Ti SC ● Seasonic X750 ● 128GB Samsung 830 SSD & External 1TB RAID1
    SupremeFX SPDIF -> MHDT Constantine DAC -> Darkvoice 336i Tube Amplifier -> AKG K701
    Xtreme Cruncher
    Nov 2003
    MD, USA
    here is the picture
    Feb 2003
    San Diego
    Can you use 2 wires instead of just one?
    Take out your ex tonight... one bullet should do it.
    I've effectively killed my sig because it is no longer accurate. Oh well!
    A64 3200+ Newcie
    2x512 OCz PC3500 GX
    DFI NF3 250gb LPUT
    No Name 9700 that refuses to die!
    Jun 2004
    Sweden
    Yes.
    3000+ nc CG @ 270x9 | Dfi LP 250Gb | 512 mb adata DDR500 | 9500 pro @ 365 / 330 |
    17300 marks
