Page 1 of 69 12341151 ... LastLast
Results 1 to 25 of 1707
Thread: athlon64 overclock record. all owners please post
    Champion
    Jun 2003
    cape town
    would all athlon64 owners please post full stepping codes and overclock stats. saves you having to scratch around for it later. unless the IHS is already your keyring. lol
    i just ordered an 0330 - 99 myself. full codes to follow. hoping to create a collection of records for athlon64 overclocks. will be trying out the soltek K8AV2-RL next week. will be shooting for 233fsb sync on air till i get better cooling.
    thanks in advance to all posters
    edit: for image
    Xtreme X.I.P. Soulburner's Avatar
    Oct 2003
    Lincoln, NE
    http://www.cpudatabase.com/ is a good place to start, you should upload your records there when they are final.
    System
    ASUS Z170-Pro
    Skylake i7-6700K @ 4600 Mhz
    MSI GTX 1070 Armor OC
    32 GB G.Skill Ripjaws V
    Samsung 850 EVO (2)
    EVGA SuperNOVA 650 G2
    Corsair Hydro H90
    NZXT S340
    Champion
    Jun 2003
    cape town
    the first post here will be more usefull as they don't have a single one yet.
    Oct 2003
    Lincoln, NE
    Exactly, that's why you add it to the database. Look how many P4s, 1700+ and 2500+'s there are. They had to start from scratch too.
    They're still brand new.
    System
    ASUS Z170-Pro
    Samsung 850 EVO (2)
    Corsair Hydro H90
    NZXT S340
    Champion
    Jun 2003
    cape town
    nevermind everyone lets just post all our notes and experiences and discussions over there K!
    Xtremely Large Member
    Jul 2003
    Britland
    The OC thread is kind of a tradition on XS Soulburner, the only reason I haven't posted is because I don't have an A-64.
    I've heard it all, I've seen it all, I've done it all. I just don't remember any of it.
    DFI LanParty UT NF3 | A-64 3200+ | 1Gb OCZ EL DDR PC-3500 Limited Edition
    Radeon X800XT | Audigy 2 | 2x WD 74Gb Raptors | 60Gb IBM | 20Gb Maxtor
    OCZ PowerStream 520w | Mach II GT Cooled
    Oct 2003
    Lincoln, NE
    Um that's not what I was saying...apparently you missed my point.
    All I said was it would be cool to add it to the database...nevermind my suggestion .
    System
    ASUS Z170-Pro
    Samsung 850 EVO (2)
    Corsair Hydro H90
    NZXT S340
    Jul 2002
    [M] - Belgium
    check the CPU database for XP 1700 Tbred
    highest CPU overclock.... 4400Mhz ??
    Belgium's #1 Hardware Review Site and OC-Team!
    Aug 2002
    0330 "F4" in third code line - 2670mhz at 1.9V rock stable on Gigabyte mobo, 3rd highest score on ORB.
    My new 0331 "9" isn't that great though.
    Champion
    Jun 2003
    cape town
    sorry you were right it was a fantastic suggestion . plenty info there
    i can see this is going to be a brilliant thread
    Champion
    Jun 2003
    cape town
    thanks QuadDamage for the comparison. maybe my 0330 will be a good one too.
    Jul 2003
    Britland
    Off to a cracking start.
    Jun 2002
    Saskatoon, Saskatchewan
    I'll stick this, since I think it will have some relevance .
    AXP1700+ JIUHB 0302 @ 2400MHz - TEC-Watercooled in The Skyscraper
    ABIT NF7-S , Sapphire Radeon 9500 Pro, 1.5GB XMS3200C2
    XS IRC channel: irc.quakenet.net #xtremesystems
    www.ocfaq.com
    Champion
    Jun 2003
    cape town
    my first sticky. i'm honoured
    Jul 2003
    Britland
    Nice one, now all you need is some A-64 owners.
    Feb 2003
    Sunny California
    I just took a peek. Nothing yet!
    Asus rampage III
    i7 950
    corsiar dominators 3x2Gb
    Evga 280 gtx
    silverstone 800 watt power
    ssd 6Gb/s
    Water cooling
    BASS ALE COOLENT FOR ME!
    heat
    Xtreme X.I.P.
    Jan 2003
    Huntsville, AL
    I hope you can read the pic info !
    The rest is in my sig
    24/7 Work & Play Rig
    Gigabyte X58A-UD5, i7 920 @ 4.56ghz 1.48v 21x217, G.Skill PI 12Gb 8-8-8-24-1T 1.56V @ 1736Mhz
    EK Supreme HF P1, Dual EK DCP 4.0 Pumps and EK Res, XSPC RX360 & RX240 w/ 1850rpm GT's
    Sapphire HD 4870 1Gb @ 810/1020mhz, 2x Dell 2407, 2x 1Tb WD Black SATA3, 2x 2Tb Hitachi 7k2000
    Cooler Master ATCS 840, Corsair 750TX PSU, running OSX 10.6.3 & Win 7 64
  18. #18
    boughetto overclocker
    Jun 2002
    NORAD Command Center
    Someone clean up this thread and let's post up overclocks!
    Dinosaurs are chortling.
    Lian Li PC1200B, Custom Water Cooling, Lamptron FC5 Fan Controller w/ 4x 120mmx38 Deltas
    i7 930 @ 3.8ghz, Rampage III Extreme, 12GB G.Skill PC2000, BFG 260GTXOC, PNY Quadro 380FX
    (1) HP LP2475w 24", (2) Dell 2007WFP 20", Corsair AX1200 1200w, 3Ware 9650SE Raid
    (2) 500gb Hybrid Seagate Raid 1, (2) 2TB WD Red NAS 64mb Raid 1, (5) 1TB Hitachi 32mb Raid 5
  19. #19
    Dec 2002
    Germany
    2350 MHz stable, 2400 MHz benchable @ 1.65V (maybe the ram).
    Cooled with water.
    Next week i'll try some Mushkin Level II. Hope for 2400 stable.
    <img src="http://www.prometeia.de/3dmark.jpg">.
    My system
  20. #20
    Champion
    Jun 2003
    cape town
    Major Slaughter - perfect thanks
    KingInge2000 - forget to write down the codes before installing the waterblock? thanks for the vcore info anyway
  21. #21
    Nov 2002
    Inside out
    2380Mhz using 1.7v vcore and totally stock cooling. I'll write down the codes from the cpu and post them when I pull off the IHS this weekend.
    I'm using an ASUS K8V running the memory at 238mhz 1:1 cas2 2-2-6 at 3.2v. The same chip only did 2310 in an MSI K8T800. Hopefully I can get the prommy running on it this weekend and get back into the top 10 on the ORB...
    edit:
    cpu codes are as follows:
    ADA3200AEP5AP
    CAACK 0330UPWM
    9438245200435
    Running at 2500mhz now with the prometia installed. I'm pulling the IHS off now in hopes of 2.6ghz, but I also need to reload my OS (lost it at 251mhz fsb). Also my corsair xms3500 is up to 245mhz 1:1 at cas2 2-2-6 I never thought this memory would clock so high...
    FOLD!!!
    Bench rig: Athlon64 3200 // Gigabyte K8NNXP with vmem/vddr voltmods // 256MB Corsair XMS3500 // Promise Fasttrak TX2000 // Maxtor 40GB 7200RPM HDD // TTGI 500W PSU voltmodded @ 3.7v/5.4v/12.6v // Prometia cooling (stock, r507 soon) // BBATI 9800XT stock no vmods YET // Speeds, voltages, and timings change daily
    25701 3DMarks
    "Everything you do will be more fun" -Microsoft, Windows 95 Installation
    I am american, PM's in english only please
  22. #22
    X.I.P.
    Jun 2003
    Patras - HELLAS
    Just for start i am running with Stock Cooling at 2230 MHZ and keep going UP with ONLY 1.488 Vcore (default).......
    E8400 4400(Q814A015 Wafer **91)@1.296 Vcore
    Q6600 (L733B458)@4054 1.5 Vcore
    ASUS P5Q Unmoded - 2X2 GB Corsair Dominator 8500
    Blaster AUDIGY 2
    Sound Blaster Megaworks Speakers 2.1 250D THX / 300 WRMS
    ATI 4850 512MB @750/1150 Stock cooling
    LG W2600HP-BF 26" Wide TFT Monitor (S-IPS)
    System Cooled by ThermalRight Ultra 120 Extreme
    System Powered By OCZ 600W
    Limits do NOT exist
  23. #23
    Xtreme X.I.P.
    Aug 2002
    http://www.aocb77.dsl.pipex.com/abit2.jpg
    It's a bit big so I include it in a LINK
    I seem to have ended up with a CAAMC 0034 MPMW
    Hope it's not a remarked XP1700+
    Anyone else got a CAAMC ? You don;t think it is one that didn't quite make the grade to a K do you ...?
    Regards
    Andy ( slightly concerned )
  24. #24
    Champion
    Jun 2003
    cape town
    it looks good to me. how is it performing?
    btw i've hosted it for you. - zakelwe's chip below.
  25. #25
    X.I.P.
    Jun 2003
    Patras - HELLAS
    Well now on 2400 MHZ stable using ONLY Stock AMD HEATSINK @ 1.64 Vcore.......
    Blaster AUDIGY 2
    Limits do NOT exist
