Page 1 of 5 1234 ... LastLast
Results 1 to 25 of 106
Thread: Push or pull config on PA120.3 Radiator?
    Sep 2005
    Utrecht, NL // Kingston, Jamaica
    well uh, someone said in another thread that thermochill reccomends push config for their PA series of rads. Is this for slower fans? does it work better that way for the slower fans? is it a real difference?
    here is my setup:
    fans pull cool air thru rad in this config. thoughts on this push/pull concept?
    Apple Macbook Pro º 2.4GHz Intel Core 2 Duo º GeForce 8600M GT 256MB º 2GB 667MHz DDR2 º 15" TFT LED backlit display // Dell 2407WFPHC // Xbox360 // Ek + Swiftech blocks in storage
    r3vo+PC Fall_06 Build
    Spring Customer Build
    Xtreme Guru
    Jan 2006
    Milan, Italy
    the diff is about 1-2% in favour of push. try both and see what wopks bets for you. fan speed shoudlnt make a difference because of the minimal restriction of PAs.
    Quote Originally Posted by Bloody_Sorcerer
    flowrate is for losers!
    Quote Originally Posted by MaxxxRacer
    Thermaltake is kind of like AIDS; it won't go away just by ignoring it.
    Sep 2005
    any difference noisewise? and its kinda difficult to try the diff things out hmmmz, cuz of the way the tubes are attached n all. hmmz
    Xtreme Guru
    Jan 2006
    Milan, Italy
    push is quieter generally - rad before fan causes cavitation more than puish causes noise because of backpressure, with PAs.
    but if youre worried about noise id ditch those 38mm boys there.
    Sep 2005
    Quote Originally Posted by creidiki
    j-mags black yate loons will arrive any day now.
    so the plan is to take the time to switch the fan setup as best i can and install the neoprene pad that came with the rad but to do any and all improvements at one time. shroud for the win? shrug actually i no space for that.
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    dont need shroud!
    Quote Originally Posted by iddqd View Post
    Not to be outdone by rival ATi, nVidia's going to offer its own drivers on EA Download Manager.
    X2 555 @ B55 @ 4050 1.4v, NB @ 2700 1.35v Fuzion V1
    Gigabyte 890gpa-ud3h v2.1
    HD6950 2GB swiftech MCW60 @ 1000mhz, 1.168v 1515mhz memory
    Corsair Vengeance 2x4GB 1866 cas 9 @ 1800 8.9.8.27.41 1T 110ns 1.605v
    C300 64GB, 2X Seagate barracuda green LP 2TB, Essence STX, Zalman ZM750-HP
    DDC 3.2/petras, PA120.3 ek-res400, Stackers STC-01,
    Dell U2412m, G110, G9x, Razer Scarab
    Xtreme Guru
    Jan 2006
    Milan, Italy
    yeah, shroud is actually pretty useless on PAs, the inbuilt one is more than enough.
    Banned
    Feb 2006
    Ontario, Canada
    From my experience PULL works best with a shroud, PUSH works best with no-shroud.
    shroud just takes away the dead spot...
    Dec 2003
    Germany/Europe
    I'm just about to test that with my rig... the push+shroud version does give me quite an impressive performance, but I'll test pull later on to see if it's even better than that.
    Intel i7 8700k | AsRock Z370 Gaming K6 | G.Skill TridentZ PC4-3200 | Gainward GTX 1080 Phoenix GLH | Seasonic Prime Titanium 650W
    Sep 2005
    hey let me KNOW! cuz if im doing push then basically my fans would have to go ontop of my rad which will be mounted to the case directly.
    hey on that thought: if the rad is gettin attached to the case directly, what would be a good dampening cushion? do i need one? or can the metal of the rad touch the alu of my case-top?
    Dec 2003
    Germany/Europe
    Just get another gasket like the thing Thermochill offers. Or simply neoprene... doesn't matter normally.
    I'll give you some scores as soon as I'm through with it. Using YLs there btw.
    Xtreme Guru
    Aug 2003
    Athens, Greece
    Keep us updated radical...
    Project ZEUS II
    Asus Rampage II Extreme
    Intel I7 920 D0 3930A @ 4.50GHz (21 X 214mhz)
    3 x 2GB G.Skill Trident 1600 @ 1716MHz (6-8-6-20-1N)
    2 x Asus HD 6870 CrossFire @ 1000/1100MHz
    OCZ Vertex 2 60GB | Intel X25-M 120GB | WD Velociraptor 150GB | Seagate FreeAgent XTreme 1.5TB esata
    Asus Xonar DX | Logitech Z-5500 | LG W2600HP 26" S-IPS LCD
    Watercooling setup:
    1st loop -> Radiator: 2 x ThermoChill PA120.3 | Pump: Laing DDC-3.25 with Alphacool HF 38 top | CPU: Swiftech Apogee XT | Chipset: Swiftech MCW-NBMAX | Tubing: Masterkleer 1/2" UV
    2nd loop -> Radiator: ThermoChill PA120.3 | Pump: Laing DDC-3.2 with Alphacool HF 38 top | GPU: 2 x EK FC-6870 | Tubing: Masterkleer 1/2" UV
    Assembled in Mountain Mods Ascension Trinity
    Powered by Corsair Professional Series Gold AX1200
    Dec 2003
    Germany/Europe
    I sure will. What would you think would be the most interestng fan rpm for looking at the push/pull difference? low, med or high rpms?
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    anything else than yates on the 120.3 is silly!
    Dec 2003
    Germany/Europe
    Well, l/m/h with Yates
    I'm testing them "low" at 600rpm, "med" at 900rpm and "high" at 1200rpm (which then is 9.5V on my scale). So none of them is really "high speed".
    Sep 2005
    sounds good to me radical, cuz i dunno if i would ever run em at that full speed (12v)
    Dec 2003
    Germany/Europe
    Ok... I'll have some nicer scores later on, but for now these should do.
    To start, for my setup push/pull only made a "real" difference at really low speeds. I'm using the shroud all the time, maybe that helps there too.
    I pute the PA 120.3 in to keep an Opteron 170 (280x10, 112% voltage), 2 x 7800GT 512MB (500/1400MHz) and NF4 chipset (1.6V) cool.
    push:
    4V, 600rpm: 7.8K
    6.5V, 900rpm: 5.9K
    9V, 1200rpm: 4.7K
    pull:
    4V, 600rpm: 6.9K
    6.5V, 900rpm: 5.5K
    9V, 1200rpm: 4.7K
    So as you see, the more air goes through, the smaller the differences are. By the way, I was really impressed of the overall performance... I've never seen anything alike.
  18. #18
    Sep 2005
    thanks! keep it coming! definatley me doin the push config where my fans go on top actually makes it easier to swap out me fans, since al lthe tubes are all connected and stuff. the only major issue im about to have is WHAT IN HELL DO I DO with all them molex connectors ARGH
  19. #19
    Dec 2003
    Germany/Europe
    Yup, give me some time to do that I'll try to test it the "marci way", with the air temps and all that stuff too.
  20. #20
    Jun 2005
    Thanks for your contribution Radical_53.
    Could you please,if you'd not mind, do test the difference between "with shroud" and "without shroud" ? Thanks.
  21. #21
    Dec 2003
    Germany/Europe
    I'll see what I can do. The one side of the rad is without a gasket right now, so it should be possible
  22. #22
    Jun 2005
    Quote Originally Posted by Radical_53
    sweet
  23. #23
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    k as in kelvin? whats that compared to celsius?
  24. #24
    Dec 2003
    Germany/Europe
    1:1
    If you measure temperatures and want to give the delta, the difference between air and water, you don't say °C but K. That's all. If you took absolute temperatures, like "24°C air to 28°C water", then Kelvin would be +273... as the Kelvin-scale starts at absolute zero, whereas Celsius starts at the freezing point of water at 1013mbar pressure.
  25. #25
    Xtreme Mentor
    Mar 2006
    Evje, Norway
    ok. good to know.
    did know that kelvin starts at absolute zero, but wasnt shure if it was 1:1 or what! but now i do!
