why do some of you are so sensitive and then get ugly?
call me noob or whatever you wish, I am just as interested as you (Intel disciple). By no means I am interested in any flame. take it somewhere else please.
Edit: I reduced the speed to 2.4ghz (A64 3000) and loosen timings to 3-5-5-10
and get WinRar = 684
WinRar multithreading gives same results since I dont have dual core.
This is not a flame. More than anything, I am interested in price/performance for my next upgrade, be it Intel or AMD.
my Dual core in single thread is only 647 with the CPU and Ram at 250*10 and 3-4-4 timings.
your ram is flying at 300 mhz which is making up for my 100 mhz advantage in CPU and slighly better timings.
__________________
i7 920 @4.305 ghz (205*21 HT on) Prime stable@ 1.312v (Batch# 3844A717) your results may vary
i7 920 @4.410 ghz (210*21 HT on) 1hr Prime stable@ 1.39v (Batch# 3844A717) could push more but no reason too
Enzotech Heat Killer SCW-REV.A (very nice block 73c / 79c per above voltages)
GA-EX58-UD4P (Bios ????),, 6GB- OCZ3P1600LV6GK (7-7-7-20 @1640 mhz) 1:1
XFX-5870 with Swiftech nickel block
Water Cooling - TFC X-Changer 480 and 6-Scythe SFF21E fans @1000 rpm , Vario 655
Raid 0 velociraptors 600GB,, ZM1000-HP (powerfull and silent)
Mitsubishi 22" CRT (old school ,,no input lag , no slow response times , true color reproduction & blacker blacks) its deep but so what
To compare Vic's latest results on Conroe to a 2.8 ghz dual core 1 MB cache Athlon64 X2 -- (with the same unofficial binary -- which I made myself)
With the best compiled build (Pentium 4 build):
Molecular Dynamics
A64: 1872.68
Cre: 2133.38
Primordia
A64: 1506.83
Cre: 1365.85
Cryptography
A64: 1345.05
Cre: 1065.59
STREAM
A64: 1512.55
Cre: 1242.94
Memory Benchmark
A64: 1586.46
Cre: 1465.20
BLAS/FLOPs
A64: 1449.17
Cre: 1836.98
MolDyn is a beast on Conroe -- but as you will see on multiple review websites, 64-bit mode is much faster in moldyn -- I can't wait to see a 64-bit result!
i think people are starting to compare to high frequency chips cause they can't admit tha intel is and will be releasing a very good chip..
i am not a fan from either company, what does the job, does the job.
but seening some of these stats so far i think some amd fan bois, have to suck it up , and bow for the moment .
maybe it's so they know how much better the conroe is than the A64... yes, everyone knows it's superior clock for clock, but if we (the community as a whole) can say a conroe at 2.4ghz = a toledo at 2.9 or 3ghz, we can say it is xx% faster. isn't that the whole point of making comparisons?
Exactly
The only reason I even posted sciencemark with my 170 @ 2.9GHz is because I had already done this test ages ago and wanted to show Conroe's superior performance, I did'nt set my 170 back to 2.4GHz because for one I just could'nt be bothered and secondly anyone with half a brain could extrapolate the performance clock to clock
This AMD v Intel fanboy/girl talk is just soooooo childish and is not giving XS the respect it and the members deserve
__________________
lots and lots of cores and lots and lots of tuners,HTPC's boards,cases,HDD's,vga's,DDR1&2 etc etc all powered by Corsair PSU's
This Conroe is just an A1 ES CPU... There are newer stepping already available...
Victor, can you plz run HWiNFO32 (http://www.hwinfo.com) to check the machine?
It should support Conroe and its thermal sensor too...
where did you find A1 stepping?
my friend told me it's an B0 stepping.
If you look at the CPUZ screenshots is says the stepping is 1. I don't know a lot about reading the steppings from software but it seems more likely to be an A1 to me.
Backup System
P4 630 W CNPS 9500 AT, Asus P5N32 SLI-SE
eVGA 7900 GT SC CO
Sony DRU702A, HP 530i
2X512 MB Mushkin DDR2-667, Seagate 80 GB 7200.7
WD Cavier SE 160 GB IDE
ThermalTake Soprano w 450 Watt Antec Smartpower 2.0
Damn, because... I know. Can't tell more . Stop speculating
Don't expect Everest to give you accurate result in this matter (Fiery consults this with me).
Don't search for any scheme in assigning CPU Stepping numbers in CPUID - it's fully in hands of CPU vendors. If they decide Stepping = 1 to be C5/C6, then it's C5/C6
Only to clarify. Have you noticed that Conroe 2.4 score with SM 2.0 *official* version is 1308 (neck to neck with X2 2.4)? and that the other score -with enormous moldyn score- is with *unofficial* and *special optimized binaries for Intel CPUs* made by redpriest?
