This unit is prepared to work with big loads.
Evap is the same i always use, chilly1 design but a little bit modified. (I've bought a few about year ago). Suction hose is about 1,2m long.
You can see polish coin on the polished base here *)
now some pics of parts used in system (sc21cl compressor, slhx and 1,9kW condenser)
i've put switch and fan regulator to the starting device
here is pic of slhx with cpev and suction side accumulator
and first run temp, ive used r507 and 1150 mix so temps were quite nice, about -65 to -70C at +0,4 - +0,5bar on low side so there was high refrigerant flow. But i wont use this mix (too high pressures on the high side - 25bar/350psi), maybe i'll get r23, it would be better i think.
i dunno much about load temps, i should test it this week
overall look? well you should like it, maybe besides insulation but it is 19mm thick on suction hose and even more on slhx. We dont want to loose any performance do we?![]()
now some pics, i hope you like it ^)
so what is your opinion :>?
