Page 1 of 8 1234 ... LastLast
Results 1 to 25 of 191
Thread: New revision nForce4 from DFI
    Jan 2005
    The Netherlands
    On Computex2005 is saw a picture of a unkown motherboard of DFI, I e-mailed DFI and found out that they planned a new revision nForce4 motherboard's!
    This was my question:
    Hello,
    A saw a report of Computex 2005 on a dutch website with a special about DFI, on the website I saw this picture:
    Now I kown that this isn't a released motherboard (yet), and by the tekst on the motherboard you can see that the nForce4 chipset is used. Now my question is, will this motherboard be released and if so when(EU, The Netherlands)? And what will be the specifications?
    Yours faithfully,
    This is what they replyed:
    Dear Sir
    Thank you for your interest on our product.
    The board shown below are still being refined at moment. the current set schedule is around October launch.
    We will make the announcement on our website as soon as the launch schedule is confirmed.
    When we launch such product, you will be able to buy it through MyCom shops throughout Nederland.
    Best Regards,
    So it looks like they solved the 5V jumper problem, they use the crossfire lay-out and the replaced the Silicon Image 3114 S-ATA controller by a Promise S-ATA300 one!
    I thought this is something you all might wanted to know.
    AMD Opteron 148 CABYE 0543 FPBW || DFI LanParty nF4 SLI-DR AD0
    2x 512MB OCZ PC3500 Limited Edition Winbond BH-5 || 2x 512MB Corsair PC3200LL V1.1 Winbond BH-5 || 1x 256MB Mushkin PC3500 LV2 Winbond BH-5
    SAPPHIRE X800GTO2 @ 16P 600/570, Voltmodded, GPU=1,7V/VDD/VDDQ=2,3V
    Zippy PSL-6720P(G1) GAMING ,POWER - I love it!
    Aug 2004
    Ummm looks like they have all but admitted the "old" version is faulty. if it ant broke dont fix it
    DFI Ultra-D
    X2 3800 Toledo 290x10 (1.39v) (not tweaked yet)
    2x 1GB Ballistix
    Sapphire X1950 256
    Seagate Barracuda 7200.9
    OCZPowerstream 520
    Custom water cooled
    Mar 2005
    Nice to see that there's an extra slot between the two main PCI-e slots for Gfx. This means that there will still be reasonable airflow to the chipset even if the Gfx cards do have stonking big air-HSFs on them
    Hmmm, I can't seem to locate the following sockets...
    1) The 4-pin molex power socket
    2) The 4-pin square head "P4" power connector
    The standard 24pin power and floppy power connector is easily located but the above two aren't. Less power required for stability perhaps?
    Dec 2004
    .ca
    There is no 4 pin connector, its 8 pin connector and you would need BTX ready PSU for that board. Other than that, sweet sweet board. The 8 pin connector is that black spot above the 24 pin connector.
    i9 9900K/1080 Ti
    Oct 2004
    Athens,Hellas
    the DFI guys must understand we need more space for insulation around the CPU socket
    if this is your first night in xtremesystems,
    you have to overclock.
    Jan 2004
    a little more about the board here
    http://www.xtremesystems.org/forums/...t=66651&page=5
    Athlon 64 X2 5200+ || Gigabyte GA-MA69GM-S2H || Connect3d 4850 || Crucial ddr2-800 Lanfest 2x1 Gb || AKASA PowerPlus 650W || Watercooled
    AthlonXP-M 2500+ @2500 || Abit NF7-S v2.0 || ATI 9700 PRO || Corsair XMS PC3500 v1.1 2x256 + 1x512 Kingston HX || Enermax EG465P-VE FC || Slk 900A - Delta 92mm
    Jun 2005
    I really like the extra slot between the PCI-E video slots. Will take some time to get used to the new cpu/memory layout though.
    Gryph
    Sep 2004
    Fantasia
    Quote Originally Posted by [timko]
    The 4 pin molex has changed to a floppy power connector above the top PCI-E slot.
    Mar 2005
    Quote Originally Posted by Mr. Tinker
    On the current version of the board there are the following power connectors...
    1) Floppy power
    2) ATX 24pin power
    3) 4pin cube "P4" power
    4) 4pin molex power
    The new version pictured in the first post appears to have dispensed with 3) and 4) whilst still retaining the other two.
    Mar 2005
    Quote Originally Posted by esdee
    Heatsinks such as the XP90(c) and XP120 would still overhang (but not prevent the use of, just ease of access) the lower two memory slots as it does on the current version of the mobos
    May 2005
    Awesome, 3 PCI slots. I can finally bring out my old TV Tuner. Yipee!
    May 2005
    ESP/NL
    Quote Originally Posted by jiff
    Haha, now i wished my RMA'ed DFI could hold till then...
    Jul 2005
    Blah. This doesn't mean the DFI first revisions are bad. If you have the know how and get a DFI Ultra-D or SLI up and running tweaked right, it's excellent.
    Xtreme Guru
    Dec 2003
    Vancouver, Canada
    4-phase CPU power
    i5 750 4.20GHz @ NH-D14 | 8GB | P7P55DLE | 8800U | Indilinx SSD + Samsung F3 | HAF922 + CM750W
    Past: Q6600 @ 3.60 E6400 @ 3.60 | E6300 @ 3.40 | O165 @ 2.90 | X2 4400+ @ 2.80 | X2 3800+ @ 2.70 | VE 3200+ @ 2.80 | WI 3200+ @ 2.75 | WI 3000+ no IHS @ 2.72 | TBB 1700+ @ 2.60 | XP-M 2500+ @ 2.63 | NC 2800+ @ 2.40 | AB 1.60GHz @ 2.60
    Quote Originally Posted by CompGeek
    The US is the only country that doesn't use [nuclear weapons] to terrorize other countries. The US is based on Christian values, unlike any other country in the world. Granted we are straying from our Christian heritage, but we still have a freedom aimed diplomatic stance.
    May 2005
    The Netherlands
    hmmm that board has 1 more heatsinked mosfet... but what is it for? seems like it belongs to the cpu power regulator stuff.. I hope it's better..
    The only major turnoff about this board for me are the dimm slots.. how am i going to cool them? Can't put a fan on the left of them coz of the video card, probably can't put a fan on the right of them either. And the Powerstream 520 PSU doesn't have a fan on the underside.
    I'm a big fan of the wind tunnel kinda air cooling.. 120mm exhaust 120mm intake, all in one straight line with the cpu&ram. That's not gonna work with the dimms placed like that though
    Nice to see 3 PCI slots though, especially with the I-Ram coming out soon now i can put 3 in raid 0 lol
    Feb 2005
    bakersfield ca
    im excited to see some phase changed cpu overclocks with the dual 12v rail imput for the cpu and the 4 phase regulation it looks good i think i might need to pick up this revision
    ________
    LovelyWendie
    Dec 2004
    .ca
    Time to move on to NF4. Lets hope it perfoms as it looks !
    i9 9900K/1080 Ti
  18. #18
    May 2005
    Quote Originally Posted by TurboDiv
    It looks like the PCI-E power plug that came with my neo480 power supply, guess that could be one of the reasons for being able to eliminate the 4 pin molex power connector on the mb.
    Work Rig: Asus x58 P6T Deluxe, i7 950 24x166 1.275v, BIX2/GTZ/D5
    3x2048 GSkill pi Black DDR3 1600, Quadro 600
    PCPower & Cooling Silencer 750, CM Stacker 810
    Game Rig: Asus x58 P6T, i7 970 24x160 1.2v HT on, TRUE120
    3x4096 GSkill DDR3 1600, PNY 660ti
    PCPower & Cooling Silencer 750, CM Stacker 830
    AMD Rig: Biostar TA790GX A2+, x4 940 16x200, stock hsf
    2x2gb Patriot DDR2 800, PowerColor 4850
    Corsair VX450
  19. #19
    Sep 2004
    Fantasia
    1) Floppy power
    2) ATX 24pin power
    4) 4pin molex power
    You're right.
  20. #20
    Xtreme Mentor
    Jul 2004
    Ontario
    It seems from all the above posts that everyone is happy about this new revision, I on the other hand am a little annoyed and dissapointd that this is coming out after spending the money I did on my current one not too long ago. DFI seem to have a lot of 'new revisions' come out of same model boards. No other manufacturer seems to do this.
    Silverstone Temjin TJ-09BW w/ Silverstone DA750
    Asus P8P67
    2600K w/ Thermalright Venomous X Black w/ Sanyo Denki San Ace 109R1212H1011
    8GB G.Skill DDR-1600 7-8-7-24
    Gigabyte GTX 460 1G
    Modded Creative X-Fi Fatal1ty w/ Klipsch Promedia 2.1
    1 X 120GB OCZ Vertex
    1 X 300GB WD Velociraptor HLFS
    1 X Hitachi 7K1000 1TB
    Pioneer DVR-216L DVD-RW
    Windows 7 Ultimate 64
    Quote Originally Posted by alexio View Post
    From the hip and aim at the kitchen if she doesn't approve your purchases. She'll know better next time.
  21. #21
    Jul 2005
    Quote Originally Posted by cantankerous
    I'm sure they were threatened(?) by all those complaints
    My heatware: http://heatware.com/eval.php?id=41179
    cpu: e6600
    mb: evga 680i
    ram: Ballistix 8000
    video: XFX 8800 GTS
    pw: 750 Quad
  22. #22
    Feb 2005
    ASUS has already began to sell their new revision nf4 sli mainboards.
  23. #23
    Xtreme News & Reviews
    Apr 2005
    Atlanta, GA
    what is that floppy connector for on the current SLI-DR?
    Desktop
    AMD Phenom II X2 550 (Quad Unlocked @ 3.4Ghz / 2200Mhz NB)
    Gigabyte GA-MA790X-UD4P (F9 Bios)
    8GB (4x2GB) @ DDR2-800
    ASUS GeForce GTX 560 Ti DirectCUII (920/1840/2200)
    Corsair Force GT 120GB
    LSI MegaRAID 8408E (3x750 R5)
    Windows 7 x64 SP1
    Cisco E2000 with DD-WRT kernel 2.6
  24. #24
    Jun 2004
    Saginaw, Michigan
    You didn't expect your current hardware to be improved upon in the future?
  25. #25
    Xtreme 3DTeam Member
    Jan 2005
    AMD factory
    Nothin' for me - the socket itself and the RAM slots are placed wrong if You plan to go with a phase changer.......
    Previous system:
    DFI NF4 ULTRA 0453A3 KOREA CHIPSET / BIOS 510-2FIX / FX-57 0516WPMW@3.62GHZ / 2x256 CORSAIR 3200LLPT BH-5@13x278MHZ 2-2-2-5@3.69VDIMM / MACH II GT@MOD BY BERKUT / ACTIVE COOLING FOR RAM - MOSFETS - GPU RAM / CHIPSET & GPU CORE WATERCOOLED / OCZ POWERSTEAM 600W / BUILT BY ATI X850XT@660/651 - VGPU@1.73-VDD@2.26-VDDQ@2.21 PENCIL MOD / WIN XP 2x80GB SAMSUNG SPINPOINT SP80 SATA - RAID 0 & WIN 2K 40GB SAMSUNG SPINPOINT SP40 IDE BENCH DRIVE / PIC
