Page 1 of 4 1234 LastLast
Results 1 to 25 of 92
Thread: [AwardFabrik] SandyBridge 2600K @5589 MHZ - first run air & compressorcooled
    Xtremely Bad Overclocker
    Jan 2005
    East Blue
    ...I am still a bit confused why the reviews and NDA was lifted earlier than expected - as everything was reveiled today I just rushed through some benches today...first on air, afterwards on singlestage...cold didn't really help, seemed to be hard to get good RAM-speed under cold (but I have trouble running 2133mhz on air anyway).
    Let's start 1m first:
    5589 MHZ 1m 6.688s (singlestage cooled)
    CPUz Valid @5500 MHZ
    5585 pifast 13.3s
    5500 MHZ wprime32m (singlestage cooled)
    Here is some 1m on air:
    3D Mark 2001 (full aircooled nothing special!) seems to like SandyBridge
    03 with 465 GTX aircooled
    05 with 465 GTX aircooled
    480 GTX @5588 maybe tomorrow
    regards
    SoF
    | '12 IvyBridge - "ticks different"... | AwardFabrik IvyBridge round I by SoF | AwardFabrik IvyBridge round II by angoholic & stummerwinter
    | '11 The SandyBridge madness... | AwardFabrik / Team LDK OC-Season 2011/2012 Opening Event
    | '10 Gulftown LaunchDay OC round up @ASUS RIIE | 3DM05 2x GPU WR LIVE @Cebit 2010 @ASUS MIIIE | SandyBridge arrived @ASUS P8P67
    | '09 Foxconn Avenger | E8600 | Foxconn A79A-S | Phenom II 940 BE | LaunchDay Phenom II OC round up
    | '08 7.438s 1m LN2 | AMD 1m WR LN2 | 2nd AOCM | Phenom II teasing
    | '07 100% E2140 | 106.5% E2160 | 100% E4500 | 103% E4400 | 5508 MHZ E6850 | 7250 MHZ P4 641 126.5% by SoF and AwardFabrik Crew all on Gigabyte DS3P c? and LN2...
    | '06 3800+ X2 Manchester 0531TPEW noHS 3201MHZ c? | 3200+ Venice noHS 3279MHZ c? | Opteron 148 0536CABYE 3405MHZ c? all on Gigabyte K8NXP-SLI compressorcooled
    | '05 3500+[NC], 3000+[W], 2x 3200+[W], 3500+[NC], 3200+[V] 0516GPDW
    Quote Originally Posted by saaya
    sof pulled a fermi on all of us !!!
    Feb 2009
    Mmmm good job! Could you tell us what the real Vcore was? (I read somewhere that cpu-z was not stating the real one as of now ).
    Quote Originally Posted by NKrader View Post
    im sure bill gates has always wanted OLED Toilet Paper wipe his butt with steve jobs talking about ipad..
    Mini-review: Q6600 vs i5 2500K. Gpu scaling on games.
    Tyler Durden
    Oct 2003
    Massachusetts, USA
    What kind of temps were you pulling on the chip and evap on your single stage?
    I'm starting to think a weaker single stage, like the OCZ Cryo-Z would be ideal for these things.
    Formerly XIP, now just P.
    Jan 2005
    East Blue
    I have ~42-44°C read directly on the evap. It fires on with a bit vccsa voltage (~1.05-1.1). it shows 1-2°C in bios after a while with 1.6V+ - boots better after beeing in bios compared to full cold boot. first booting is sometimes a bit hard, after a while it get's easier. having a constant temp is hard for wprime - can' get it running for 1024m 5500 :/ testing 480 gtx now
    Diablo 3! Who's Excited?
    May 2005
    Boulder, Colorado
    Nice runs I'm pretty exciting about the massive clockspeed jumps we've been seeing since ~December. I can only hope 6GHz will be eventually reached through max multi + a little bclk magic.
    Jan 2005
    East Blue
    Quick '01 110K with 480 GTX
    Admin
    Mar 2003
    North Texas
    It's great to see some good numbers with the SB. As bioses mature, it will only get better.
    Nice job SoF
    UNDER THE ICE .com
    Phase Change Cooling
    is the remedy
    World Champion - IRONMODS
    Sep 2007
    Northern Japan
    Nice speeds on that chip SoF
    Quote Originally Posted by Massman
    My definition of 'efficient' is 'it does not suck monkeyballs'. Yes, I set bars low.
    [CENTER]The post counter is not an intelligence meter!
    MAX11L - "It's like a console...with the suck turned down and the awesome turned up" -tet5uo
    Heat Team IRONMODS
    Jun 2007
    Bay Area
    omg that is beautiful. the on air numbers are with stock hsf?
    1. INTEL E5200 M0 (200x12.5 @1.175), Abit IP-35Pro, 2x2GB DDR2-1000, GT240
    2. INTEL i7-920 C0 (200x19 @1.275), Gigabyte EX58-UD4P, 4x4GB DDR3-1333, GTX680 FTW+ 4GB
    heat
    Xtreme Guru
    Jul 2004
    I dont even know where to start? Im so confused.
    i see 100 bus speed and 56 multi and sub 7 sec. spi1m
    Jul 2007
    Sofia, Bulgaria
    What CPU cooler did you use for the air tests and what was the room temperature ?
    24/7 Asrock P67 Extreme4|2500K @ 4600 @ 1.38v|2x2GB A-data value|XpertVision 8500GT 600/450|WD 6400AAKS|CM 690 + 3 x 140mm + 2 x 120mm|Zalman CPNS-10X Performa|Chieftec 750-14C|Zalman MFC1 Plus
    Jan 2005
    East Blue
    Thanks all!
    Quote Originally Posted by [XC] gomeler View Post
    As soon as we see some scaling with cold it shouldn't be a problem - so far my singlestage just helped me getting temps a bit lower under load but the next wall is around 5.6 now. and I had some more trouble with booting
    Quote Originally Posted by runmc View Post
    Nice job SoF
    Thanks man! Yeah I think we still need to learn some more things about the bios - it's interesting to know what these little options actually do
    Quote Originally Posted by miahallen View Post
    ty!
    Quote Originally Posted by darckhart View Post
    grand karma cross with arctic silver - need to get a better air cooler or start using the watercooling on my table which I actually never used before
    Quote Originally Posted by trans am View Post
    start with 50x100 1.4V to see if it is a good chip, 1.6 max under air only single core benches I would recommend
    Xtreme Guru
    Jul 2004
    Quote Originally Posted by SoF View Post
    Thanks all!
    ty!
    what about cold boot bug?
    Jan 2005
    East Blue
    rig pic
    480 GTX set of benches all with compressor but I think the brave ones will reach it on air
    01 110800
    03 125k
    05 49380
    06 35360
    Xtreme Guru
    Jun 2010
    In the Land down -under-
    SOF nice runs mate, Do you think watercooling would even be all that useful compare to air on these chips?
    Another thing I find funny is AMD/Intel would snipe any of our Moms on a grocery run if it meant good quarterly results, and you are forever whining about what feser did?
    Jan 2009
    Nice results right there , seems that the platform clocks pretty well on air .
    May I ask what was the room temp at the run ?
    2600k@4.8Ghz
    Asus P8P67 dlx (1254)
    G.skill RipJaws X 4X2GB 1600mhz CL8-8-8-21
    HD5450
    Samsung HD103UJ X3
    Intel X25-M 80GB SSD
    Hec Zephyr 650W
    Antec P182
    Team AF
    Mar 2007
    CeBIT-City
    If you have a hot chip (Not every Sb seems to be cool) it's definitely helpful to have watercooling.
    Maybe chilled wc is best for Sb OC.
  18. #18
    Xtreme Guru
    Jun 2010
    Fair nough @rne, From all the screenshots which have been posted here on XS, seems like your more vcore limited rather them temps..
  19. #19
    Mar 2009
    IRAN
    Awsome Sof Thanks For share
    what about Cb and CBB?
  20. #20
    Team AF
    Mar 2007
    CeBIT-City
    Quote Originally Posted by Johnny87au View Post
    Thats right.
    The increase of internal vPLL just changes the maximum core frequency into another range. Benching there needs higher vcore, so something to keep the lifespan of your cpu accetable is required. And if you need high vcore and have a hot chip, you won't get those frequencies stable with aircooling.
    In my view, there is no headroom above if the internal vPLL won't be further increased or some guru will find a way to let the chip scale with cold. Then the best coolingmethod to bench will change.
  21. #21
    Jul 2008
    Portugal
    Somehow it feels "5GHz for everyone" is coming closer and closer... I mean, not everyone has powerful cooling systems, 5GHz on air 24/7 should be possible in a near future
    ASUS Sabertooth P67B3· nVidia GTX580 1536MB PhysX · Intel Core i7 2600K 4.5GHz · Corsair TX850W · Creative X-Fi Titanium Fatal1ty
    8GB GSKill Sniper PC3-16000 7-8-7 · OCZ Agility3 SSD 240GB + Intel 320 SSD 160GB + Samsung F3 2TB + WD 640AAKS 640GB · Corsair 650D · DELL U2711 27"
  22. #22
    Apr 2007
    Germany
    Nice runs... performance seems to be very good in Pi...
    So hopefully the cold-scaling and the multi-problem will be fixed in the next days/weeks.
    I think the BCLK wall is acceptable with multis up to 65
    Thanks fpr sharing your results
  23. #23
    Moderator
    Nov 2006
    nice thread dude, i love 01 results with SB
    Quote Originally Posted by LardArse View Post
    i think you are asking the wrong person about safety limits, but
  24. #24
    Jul 2003
    Sweden
    SB is a real killer !! thats for sure
    [Core i7 4820K Ivy Bridge-E @4,7Ghz Vcore 1.28v][Asus Rampage Iv Extreme bios 4403][16Gb G-skill Ocz 2133mhz DDR3][Lian Li Pc2120 B, black Case][480Gb OCZ SSD main disk+120Gb ssd game disc][EVGA GTX Titan@900mhz Oc luft ][Os Windows 7][Telia 1000/250Mbits fiber ][24,4TB Lagring] upcoming Intel Haswell-E 8 cores/16 Threads next year Q4 2014 ?
  25. #25
    Jan 2005
    East Blue
    TY! Yeah water will be very helpfull when it comes holding the chip cool past 1.5V in benches like Vantage and wprime1024
    Quote Originally Posted by dany74q View Post
    Should be around 18°C here at the moment.
    [...]seems like your more vcore limited rather them temps..
    for single core benches yes it seems so but you never know what can happen with the next bios
    Quote Originally Posted by BaRaN View Post
    RAM CL8 1866 on air no problem, on singlestage gives "63" postcode often. 1600 runs fine but not with good timings - looks like something with the imc (vccsa voltage also seems to be a bit helpfull when having boot issues with a bit under zero). I think anything below DICE is not usefull atm singlestage seems ok - make sure to be prepared for full load on 2600K 4C/8T.
    Quote Originally Posted by NaMcO View Post
    with water and good chips I don't see a problem there
    Quote Originally Posted by loopy83 View Post
    Quote Originally Posted by hiwa View Post
    Thanks guys! Yeah 01 is really fun - and if we get like 400 MHZ more together with good RAM clocks it will make an old game shine
    Quote Originally Posted by PytonOrm View Post
    YEAH and it also rocks in pifast
