Page 1 of 2 12 LastLast
Results 1 to 25 of 42
Thread: [Update 1] Corsair GTX6, new world records: 3078 MHz CL8, 3060 CL7
    Apr 2010
    Austria
    Lately there seems to be some rumble about the DDR3 CL8 world record, so I thought I am giving this one a try too. Fighting on my side are 2x1 GB Corsair Dominator GTX6 rated at 2625 MHz, 9-11-10-30, a pretty nice i7 870 ES  better than aIl of the retail chips 860/870 tested so far  and Besis memory freezer, which is definitely the reason why this could be working. Regarding the mainboard, I tried some boards in the last couple of weeks, but am still happy with my P55A-UD7. Does bclocks over 265+ and is quite comfortable. H55M-UD2H is too much pain in the ass.
    I started with CL8, same timings as marmott and Benji Tshi used on their 3068 MHz CL8 with Kingston T1 Go and went upwards from 200 bclock. Maximum bootable setting was 250 MHz bclock (ddr3 multi 12 = 3000 MHz), but temperature had to be around -90 and more °C for the memory and between -70 and -75 °C for the cpu (very close to its coldbug). From there it was easier to do the rest with SetFSB in little steps  add 1 MHz, wait a few seconds  VTT was 1.56 volts, VDIMM was 1.88, but I guess it could have been lower. I got to:
    World record CL8: 3078.2 MHz, CL8-11-8-31, 1T, tRFC 140, B2B CAS Delay disabled, Dual-Channel
    Link: http://valid.canardpc.com/show_oc.php?id=1374351
    I was also able to run SuperPI 1M at 3059.2 MHz! Other benchmark wont be a problem too  should have tried MaxxMem with a bit more frequency on the cpu. :p
    Well, that wasnt too hard to get, so I figured, that I should try to hit the bclock wall with CL10 with this precious 870. I tried whatever the IMC would love to throw overboard: Single-Channel, CL10-15-15-31  also played around with BCAS delay, but TaPaKaH/Sams result is unreachable (this time!). But I refused to give 1,7 volts VTT, like he did  1,62 was max  seems to make no difference on my chip.
    DDR3 memory clock, 2nd place: 3097.6 MHz, CL10-15-15-31, 2T, tRFC 140, B2B CAS Delay 30 (or so), Single-Channel
    Link: http://valid.canardpc.com/show_oc.php?id=1334974
    What should be mentioned is, that this result did not need any ln2 on the sticks (although I tried it as well). So I am still guessing pretty hard, that my cpu is limiting the results. Okay, CL10 got higher, but it seems like the IMC was just more relaxed by the loose timings and therefore allowed a slightly higher base clock. So next on my list was CL7 to really find out whats inside these heavily binned powerchips. I never tried CL7 before on those, so my expectations werent that high. I used the same settings as with CL8, just to know where Im at. I had to play around with the voltages a bit more  1.6 VTT, 1.94 VDIMM, 1.42 PCH and got it working to boot with 2880 (245*12) MHz. Now the sticks could really use the low temperature, so I had to go to about -115 °C. cpu was still near coldbug on -75 °C. I was pretty surprised when I had 3000 MHz CL7 running, SuperPI 1M stable. Here is what I finally got:
    World record CL7: 3059.4 MHz, CL7-11-8-31, 1T, tRFC 140, B2B CAS Delay disabled, Dual-Channel
    Link: http://valid.canardpc.com/show_oc.php?id=1374368
    And a nice 1M run with 3000 CL7, whatever thats really necessary for.
    For now its just a couple of useless frequencies and SuperPI times, but I will try to find some benchmarks, that can profit from these high bandwidths + low latencies. I guess I should crank up the cpu frequency too, maybe MaxxMem likes it, though we are on dual channel. Tweaking the subtimings or CL6 is also on my list  hell, theres a lot to do, so stay tuned!
    Here is the original thread on overclockers.at. Its in German, but adds a few images and infos: http://www.overclockers.at/extreme_c...fiziell_218663
    Update 1, 9/9/2010
    Hey guys, I just finished some tests with about 25 liters of ln2, so I have some results ready. But I still have to sort things out and for sure forgot a few comparisons, that would make things sweeter. Well, I need a few days more, but meanwhile I got for you the first part of my experiments:
    Everest
    CPU: 4900 MHz, memory: 2940 MHz CL8-11-9-24-90 1T
    CPU: 5000 MHz, memory: 3000 MHz CL8-11-9-24-90 1T
    Scales pretty well I guess. As I said, I didn't touch B2B Cas Delay, as it made no difference at all. Windows has a few issues with it, little bit like the R3E "slow mode" on the qpi setting.
    MaxxMem @ 4.8 GHz
    GTX2 @ Air, 2000 MHz CL7-7-7-18-74-1T, Score: 1466
    GTX6 @ LN2, 2880 MHz CL9-11-10-30-100-1T, Score: 1797
    GTX6 @ LN2, 2880 MHz CL8-11-10-30-100-1T, Score: 1837
    GTX6 @ LN2, 2880 MHz CL8-11-9-24-90-1T, Score: 1859
    MaxxMem likes high memory frequencies, so these results did not suprise me. Tweaking the subtimings had some effect too ... better be like that, because it's sooo time consuming . Please consider that the GTX2 was on air and not maxed out for frequency, but rather efficiency.
    SuperPI 1M @ 5 GHz
    GTX2 @ Air, 2092 MHz CL7-7-7-18-74 1T, time: 8.235 s
    GTX6 @ LN2, 2092 MHz CL7-9-8-24-90 1T, time: 8.235 s
    GTX6 @ LN2, 3012 MHz CL8-11-9-28-100 1T, time: 8.219 s
    Oookay ... not much to see here. 1M likes memory, altough it's not most important. But at these rates it just does not matter. But I guess 32M would scale much more. Ran out of the precious stuff, so yes ... next time!
    What is pretty interesting, is the fact, that timings can decrease performance. It seems like if one module is too weak, than the result goes back to single channel (even though it's shown otherwise in cpu-z). For example 1M at 2400 MHz with timings at CL7-8-8-24-74 1T was slower than CL9-10-9-30-134 1T. Altough CL7 is only possible under -90 °C and less.
    SuperPI 1M @ CPU: 4.8 GHz, memory: 2400 MHz
    GTX6 @ LN2, CL7-8-8-24 1T, time: 8.656 s
    GTX6 @ Air, CL9-10-9-30-134 1T, time: 8.594
    I also had the chance to shoot some new photos. Please view them here: http://www.overclockers.at/extreme_c...23#post3062423
    More to come very soon!
    Aussie God
    Feb 2005
    Copenhagen, Denmark
    SWEET!!!
    More pictures!
    Competition ranking;
    2008; AOCM II, Minfeld/Germany #2 @ 01SE/AM3/8M (w. Oliver)
    2009; AMD-OC, Viborg/Denmark #2 @ max freq Gigabyte TweaKING, Paris/France #4 @ 32M/01SE (w. Vanovich)
    2010: Gigabyte P55, Hamburg/Germany #6 @ wprime 1024/SPI 1M (w. THC) AOCM III, Minfeld/Germany #6 @ 01SE/AM3/1M/8M (w. NeoForce)
    Spectating;
    2010; GOOC 2010 Many thanks to Gigabyte!
    I am Xtreme
    Jul 2007
    Austria
    Nice one mat.
    Mar 2009
    Germany near Hannover
    HI,
    holy moly.
    Very nice result
    Xtreme Owner Charles Wirth's Avatar
    Jun 2002
    Las Vegas
    Knowing high B2B setting can produce useless results.
    Please run some bandwidth tests showing scaling.
    Intel 9990XE @ 5.1Ghz
    ASUS Rampage VI Extreme Omega
    GTX 2080 ti Galax Hall of Fame
    64GB Galax Hall of Fame
    Intel Optane
    Platimax 1245W
    Intel 3175X
    Asus Dominus Extreme
    GRX 1080ti Galax Hall of Fame
    96GB Patriot Steel
    Intel Optane 900P RAID
    Dec 2004
    Switzerland
    Verry nice Result !!!
    I like the Memoryfreezer Build by besi my team member !!!
    www.ocaholic.ch
    Dec 2007
    France
    very nicely done, congrats !
    this CL7 frequency is impressive.
    we've tried maxmem at high frequency but it was crap
    we'll try to get another shot with Benji Tshi but we need a cpu with a better max bclk and a proper ram pot.
    Apr 2010
    Austria
    Quote Originally Posted by FUGGER View Post
    On CL10 I tried to get as high as possible, so I also fiddled around with the B2B CAS Delay. But it did not do much for max frequency, altough iirc the CL10-validation was taken with it. Not sure.
    CL7 and CL8 had B2B CAS disabled _for sure_. Next time I will include a screenshot with CPU-Tweaker too. I really wasn't prepared to get these results. :P
    Btw, why is this thread now in the Intel forums? Is not not extreme enough?
    Xtreme Mentor
    Aug 2008
    Australia
    Nice clocks. Maybe I'm a purist but with timings of CL10-15-15-31, it's just, a little bit weird. I also don't really consider CL7-11-8-31 'truly CL7' (although it is technically, I know), I think it gives a false impression of the situation once the timimgs other than CAS Latency get bloated beyond a certain point. These days it seems it's all about the raw MHz and not timings vs MHz and resultant performance.
    EDIT - I don't mean to sound harsh or detract from the MHz achievement. I'm just a little over these results where people claim a CL 'x' record with every other timing bloated out of proportion.
    As Fugger said, show some bandwidth scaling with these speeds and timings.
    Ci7 990X::Rampage III Extreme::12GB Corsair Dominator 1866C7GT::2 x EVGA SC Titans in SLI::Corsair AX1200::TJ07::Watercooled
    Ci7 920 3849B018::Rampage II Extreme::6GB GSKILL Trident 2000C9 BBSE::EVGA GTX580::Antec Signature SG850::TJ09::Aircooled w/TRUE 120X
    "AKA Alonso"
    Jan 2003
    Germany
    Great results, Mat
    Keep on rockin´
    Apr 2010
    Austria
    Quote Originally Posted by CryptiK View Post
    Next chance is Tuesday, next week. I will update my post with screens including CPU-Tweaker then.
    Which bandwidth tests should be included? Will try MaxxMem, but without proper cpu frequency, there won't be much to show. Everest memory benchmark?
    I am Xtreme
    Jul 2007
    Austria
    I think everest should be a good start.
    Quick to do.
    Jun 2005
    TAIWAN
    very impressive 3GHz CL7
    Oct 2008
    Bologna,Italy
    impressive
    sorry for my bad english
    Gigabyte Battlefield Pi 1M #3
    Banned
    Nov 2005
    Acreageville, Alberta
    Sickness
    Nov 2006
    Vienna
    Nice mat. It was a big pleasure to see the scores live. Well done. Next step is 3k on CL6^^
    Xtreme Legend
    Oct 2005
    Austria
    well done bro
  18. #18
    May 2009
    Greece
    Gongrats for the record.. Some spi32m maybe next time...
    Also, pretty awesome job by the memory freezer..
    24/7 Rig: AMD Athlon II 450 - MSI 760GM E51- 8GB 1600MHz Gskill RipjawsX- Nvidia GTX260 - OCZ Vertex2 60GB - Seagate 640GB - Antec Quattro 1200W - Samsung T220
    Bench Rig: Intel Core i7 3770K - Asus Maximus IV Extreme - 4GB 2000MHz Corsair Dominator GT - 2x Nvidia GTX260 - Intel Postville 40GB - WD VelociRaptor 36GB - Antec Quattro 1200W
  19. #19
    Dec 2002
    Sweden
    what mem ic? not hyper? awesome oc
    Vishera 8320@ 5ghz | Gigabyte UD3 | 8gb TridentX 2400 c10| Powercolor 6850 | Thermalight Silver Arrow (bench Super KAZE 3k) | Samsung 830 128gbx2 Raid 0| Fractal case
  20. #20
    Feb 2009
    Athens - Hellas
    Stunning IMC
  21. #21
    Oct 2008
    feldkirch.at
    Thumbs up
    nice mat!
  22. #22
    Oct 2007
    Austria, Linz
    Quote Originally Posted by Tomasis View Post
    iirc, Powerchip.
    Mainsys: Intel Xeon w3520 @ 4,3GHz (1,296v) || DFI Lanparty X58 T3eH8 || GTX 280 SLI || 6GB Mushkin DDR3-2000 CL9
    Watercooled by: Alphacool NexXxos X2+ Highflow || Thermochill PA120.3 Triple || 2x Watercool HK GPU-X² G200 || Innovatek HPPS Plus
  23. #23
    -100C Club Member
    Jul 2005
    Somewhere off topic
    Nice work Mat
    Quote Originally Posted by jimmyz View Post
    sorry to hear about the dead cards, but.. If stuff ain't dieing, you aren't trying.
    נְפִילִים
  24. #24
    Xtreme X.I.P.
    Dec 2003
    Awesome CL8 and CL7 results, Mat! Congrats on your WRs and thanks for sharing what CMGTX6 is capable of, when pushed very hard!
  25. #25
    Feb 2010
    Thumbs up
    great job, mat(e)!
    keep on pushing!
    SYS 1A: Q9650 @4.1GHz | Noctua NH-C12P | Gigabyte EP45-UD3P | 2x2GB OCZ Platinum DDR2 1066 @1100 | GTX285 | Corsair TX850W | 2x WD Raptor 150GB Raid0 |WD Raptor 74GB | Optiarc AD-7243S | Floppy | Coolermaster Stacker 830 NV Edition | Logitech G15 R.2 | Razer Lachesis
    SYS 1B: Q6600 | Noctua NH-U12 | Abit IX38 QuadGT | 2x1GB Super Talent DDR2 800 | Zotac 9500GT | BeQuiet 400W | Samsung T166 500GB | Optiarc AD-7191S | Aerocool AeroEngine Sr. modded | MS Wireless Desktop
    TFT: LG L227WT
    Mobil: HP Compaq 610 | Core 2 Duo T5870 | 2x2GB DDR2 800 | Hitachi 320GB HDD | HD ready LED-Display
