Does anyone know if these will work on my GTX 480's that have Koolance blocks?? It looks like it might work.....
http://www.sidewindercomputers.com/ekwaekgtxban.html
(New build):MSI Big Bang X-power II with XSPC MB blocks, Core I7 3930k@4.6Ghz with HT on, 3x GTX 480 SLI with EK Waterblocks(for now), X-fi Titanium, Gskill quad kit 16GB 2133mhz, 2x240GB Corsair GT SSD's(raid 0), 3xWD 2TB drives, Silverstone Strider ST1500 Watt, Dell3007WFP and 2x Samsung 305T's. Water loop: EK HF CPU block, XSPC RX480 Rad, Coolgate GC480, Airplex Revolution 420 Rad, 2x DDC 3.25 18W with EK dual top, Caselabs STH10 white with customizations....
It would depend on where/if the Koolance block has the center screw holes and sizes, but I would doubt it.
The outer holes dont go into the block (at least not the EK block), but those center 3 holes do.
Oh, and you don't say who's 480's you are using, but the backplate WILL NOT fit correctly onto the ASUS GTX 480 (the EK full cover block fits just fine, I'm using them, but the backplate gets caught on some small extra circuits that the asus board has on the back).
Plus, be real careful, the screws that EK sends with the backplate use a small (very small and very shallow) hex head and mine stripped out entirely on the first attempt at installing it.
That's slightly before I found out that the backplate won't fit correctly on the asus boards (and EK updated thier compatibility listing shortly afterwards), but then I couldn't get the screws out of the backplate to remove it. I ended up, finally, being able to get 2 of the 3 screws out and then just snapped the third screw head off by pure force and got the rest out with some needle nosed pliers.
Thats weird as all gtx 480's are reference design....So if asus won't work no ones will......
Check out my WC worklog: BSG Pegasus - Lian Li PC-A77B
Rev. 1.0 Photos ----- Rev 1.1 Photos ----- Rev 1.4 Photos ----- Rev 2.0 Photos ----- Rev 3.0 Photos -----
Detailed flow comparison across all revisions ----- i7 980X @ 4960Mhz
PC:
i7 980X 4.2GHz @1.31v / Asus Rampage III Black Edition / Corsair Dom GT 3x4GB 2000 CL9 / 2x Palit GTX 580 3GB
Crucial RealSSD C300 256GB / 2x WD 2TB EARS / WD 2.5" 500GB / LG Blu-Ray DVD
Lian Li PC-A77B / Enermax Revolution 85+ 1250W / MS X-6 / SS Ikari / Logitech G27 + X230 / Win 7 x64 Pro
3x Dell AW2310 120Hz 3D + Nvidia 3D Vision Surround
WC:
3x DDC 3.25 + 3x HTS-PMP400 / EK DDC Dual V2 + Single V2 Tops - Single loop / EK Multi-Option / Bitspower fittings
EK Supreme HF v3 / 2x EK GTX 5X0 Acetal + Nickel / Primochill LRT Black 1/2 ID 3/4 OD
2x XSPC RX360 + RX240 / Aquaero 5 Pro + flow & temp sensors / 21x Akasa Apache Black
Wow, I didn't know that!! I have the gigabyte cards so they are probably completely reference....
they didnt bro
pure hogwash
got 4 cards with me one time
msi , asus, palit and galaxy
all the same.
btw my msi has no issue now with the backplate and the updated spacers+screws
previously yes..
hmm isnt asus and msi foxconn reference??
i am pretty sure he made up that because u told him about ure asus and my disro told him about my msi card .
they aint on the website anymore ..about the asus and msi caution .
I have a evga gtx470 cooled by a koolance full cover block and a ek gtx 470 backplate and there is only screw of the backplate that dosent fit with the koolance block and it dosent affect in any part the backplate or the full cover block. I guees it should be the same thing with the gtx 480.
Originally Posted by DDtung
MfG, Guapa
Guapa's Layout-Finder *** Wieviel Wärme gibt eine Pumpe an das Wasser/Umgebung ab? *** Übersicht: Softwarebasierende Überwachungsgeräte
nVidia Geforce - Wakü-Sammelthreads:
GTX 4XX *** GTX 560 Ti & GTX 590 *** GTX 570 & 580 *** GTX 670 *** GTX 680 *** GTX 690
A bit off-topic here, but nevertheless: Does anyone know if those blue LEDs (or whatever used in koolance NX480 blocks to light them up) can be replaced ? This "glowing" effect is quite nice, but I'd prefer it in orange, purple or white
Clip the old led and solder a different LED's on them.
Email Koolance Tech Support and ask what Voltage LED they use so you can solder a different color on.
My guess is its either a 3V or a 1.5V.
But im sure they will tell ya exactly what voltage LED it is.
EDIT: i found it for ya in a post from TIM
Also Guys can u use thermal tape to secure the backplate?
You can only use tape on certain pieces, and use tim on the other.
There is always that option... but it will be a PITFA to remove.
Lind: Dual Gainestown 3.07
Its my fault.. and no im not sorry about it either.[12:37] skinnee: quit helping me procrastinate block reviews, you asshat. :p
Circles SucQ!
Most blue leds use 3.4V, though some brighter blues use 4.6V (source).
“Little expense had been spared to create the impression that no expense had been spared.” - Hitchhiker's GuideMondays:It's better to ask dumb questions now, than to look stupid later
I think about getting EK backplate but found following attention on their site
In case I'll receive backplate without those washers, will it be possible to set up my own? How these washers look like? Any washers with 0.5mm height solve the problem?We would like to inform all users and potential users that we have found a difference on a back side on most of the GeForce 480 GTX vga cards compared to refference design VGA card that we recieve from Nvidia.
Because of this, backplate hits marked chips (see the picture), disabling safe mount of backplate. The height dfference is only 0,25mm.
To enable safe mount we have already prepared a set of PVC washers to raise the backplate for 0,5mm enabling safe mount of backplate. If you are already owner of GF 480 GTX backplate, please contact your seller our support and we will send you the washers.
Thank you for the understanding.
EK Team
Intel Xeon W3520 4200MHz HT
Foxconn Bloodrage
3x2Gb Patriot Viper II DDR3-1600 6-6-6-16
MSI GTX480 M2D15 850/1700/2000
Samsung F1 1TB
Corsair TX950W
Stacker 832 w/ Dual Loop Watercooling aka *Bong Build*
NEC 2690WUXi
Loop 1: Laing DDC1-T -> Watercool HK 3.0 LT -> Thermochill PA120.3 -> Bloodrage NB -> EK Res 150
Loop 2: Laing DDC1-T -> EK-FC GTX480 -> Thermochill PA120.2 -> EK Res 150
*New* CM 690 II Advanced Watercooled
*Coming soon* Stacker 832 Rebirth!
The problem was/is that EK received a pre-lease reference card without the offending row of chips on the back side. Search around for reviews. You'll find that early GTX 480 cards don't have those chips on the back. Only with washers and longer screws will the EK back plate fit the reference designs consumers got.
Thanks everyone ! You are very helpful
