When news first surfaced of this board i thought...hmmm something i need for the multimedia machine.....i better give it a crack. Next thing you know guys are saying i should overclock it etc so why not
I sat down putting it all together and MSN lights up with youngpro going bananas over the board......i'll let him show off the clocking he did with his Core i7 860 later![]()
Suffice to say this little pocket rocket is exactly that. It's dead easy to OC and pushes the new Core i5 655K chip hard. I thought i would crank the voltage and do some 3DMARK06 CPU test runs for a laugh. I started off at 4.2/4.4/4.5/4.6....im thinking wtf this is nuts.......4.7/4.8/4.9faints. I left it to finish a 32M Superpi as well...didnt tweak obviously as it was single channel on w7, just wanted to see if its stable with pi too
Hardware setup:
- Gigabyte H55N-USB3 mini-ITX (F2 shipping bios)
- Intel Core i5 655K Unlocked CPU
- Intel Core i7 875K Unlocked CPU
- CoolerMaster Hyper 212 Plus CPU Air Cooler
- Corsair GTX2 Dominator (had clearance issues so just used one stick)
- WD 600GB SATA3 VelociRaptor
- MSI HAWK 5770 PCIe Graphics Card
- Corsair HX620 PSU
- Windows 7 32bit
5247MHz validation on air EEEEEK
http://valid.canardpc.com/show_oc.php?id=1232075
4.9GHz 3DMARK06
4.6GHz prime for a couple of hours eek
Core i7 875K Unlocked CPU results
PRIME at 3 hour mark
3DMARK06 at 4.1GHz
32M SuperPi at 4.4Ghz
BIOS SCREENS
