Bloodrage new G25 bios
well the wait is over here it is
http://www.yourfilehost.com/media.ph...e=8A1F1G25.zip
ok the list is a bit like this
Added BIOS setup control item "PCI Express Bus Clock".
Added BIOS setup control item "CPU QPI Latency".
Added BIOS setup control item "IOH QPI Latency".
Added BIOS setup control item "CPU QPI Drive Strength".
Added BIOS setup control item "IOH QPI Drive Strength".
Added "Current Timings" item.
Added "CPU Hardware Prefetcher" item.
Modify "DRAM Voltage" default from 1.85V to 1.70V for "Memory Profile Select"
Auto and "Virtual XMP" Enabled.
Modify "CPU VTT (UnCore) Voltage" default from added 5 step to 9 step for
"Memory Profile Select" Auto and "Virtual XMP" Enabled.
Modify for BIOS item "QPI Target Speed" show wrong speed.
Modify BIOS POST CPU speed string from 3.06GHz to 3.07GHz for 950 CPU.
VID defaults for some older CPU how sorted
am the not working list is like this
PCI-E clock(still been worked on ) so you can get to 102.4 but helps a little on bclk
Cas Latency 1 lower then it should be
CPU and IOH QPI Latency options - if you scroll up from auto to 256, it doesn't let you scroll back down to 0
so have fun and don't shout at me about stuff not working that i've said
we are working on fixing the bios but it does take time and shouting will not speed it up
thanks
- You may not post replies
- You may not edit your posts
Forum Rules
