Page 1 of 4 1234 LastLast
Results 1 to 25 of 82
Thread: X-Fi functionality on ANY Realtek HDA Codec!
    I am Xtreme Ket's Avatar
    Apr 2004
    United Kingdom
    Thats right, I've been up to my "old tricks" again Original thread @ TPU
    I said I would, and here it is! Very nice little upgrade from standard crappy Realtek drivers There is just one issue though, the Creative software is a 30 day trial. These drivers may miff Creative something fierce, do I care? Nah. I suggest Creative actually start making decent products with the right components (ie; use proper audio caps and the like not normal caps) instead of hyping their cards as this an that when in reality its 90% software driven.
    Realtek XP X-Fi mod driver R2.16 15.6MB
    X-Fi MB Software 138MB (recompressed for much smaller DL size)
    Realtek Vista X-Fi mod driver R2.17 15MB
    Realtek XP X-Fi mod driver R2.17 16MB
    Realtek XP X-Fi mod R2.18 32/64bit 16MB
    Realtek Vista X-Fi mod R2.18 32/64bit 15MB
    As usual, let me know how it all works for you.
    "Prowler"
    X570 Tomahawk | R7 3700X | 2x16GB Klevv BoltX @ 3600MHz CL18 | Powercolor 6800XT Red Devil | Xonar DX 7.1 | 2TB Barracuda | 256GB & 512GB Asgard NVMe drives | 2x DVD & Blu-Ray opticals | EVGA Supernova 1000w G2
    Cooling:
    6x 140mm LED fans, 1x 200mm LED fan | Modified CoolerMaster Masterliquid 240
    Asrock Z77 thread! | Asrock Z77 Extreme6 Review | Asrock P67 Extreme4 Review | Asrock P67 Extreme4/6 Pro3 thread | Asrock Z68 Extreme4 thread | Asrock Z68 Extreme4 Review | Asrock Z68 Gen3 Thread | 8GB G-Skill review | TK 2.ZERO homepage | P5Q series mBIOS thread
    Modded X570 Aorus UEFIs
    Xtreme Mentor
    Sep 2006
    So, what features are available and not available? Is EAX functional?
    Nice in' work, though, my friend.
    For my part I know nothing with any certainty, but the sight of the stars makes me dream.
    Apr 2004
    United Kingdom
    Lots of features work, the crystalizer, equalizer, SVM, CMSS-3D, and EAX should work too.
    "Prowler"
    Cooling:
    Xtreme Guru
    Aug 2005
    Burbank, CA
    nice job
    Jul 2006
    Amazing stuff. Well done.
    Q9250 @ 3Ghz
    Asus P5K-E wifi
    OCZ ReaperX @ 1040Mhz
    Sapphire HD4870
    TRUE + Xilence
    Coolermaster 1000W
    Antec Three Hundred
    Hitachi 7PK500 + 7TK500
    Oct 2008
    Vista driver mirrored, original link maxxed out: http://rapidshare.com/files/207115918/LinX.7z
    Xtreme Mentor
    Feb 2007
    Oxford, England
    which way round to install? software then driver? or driver then software?
    "Cast off your fear. Look forward. Never stand still, retreat and you will age. Hesitate and you will die. SHOUT! My name is…"
    //James
    Oct 2008
    Driver first
    Xtreme Mentor
    Feb 2007
    Oxford, England
    ty!
    driver installed Under Windows 7 X86, going to try software although doubt that will work, definatley noticed a difference
    GJ KET your the man
    //James
    Apr 2004
    United Kingdom
    Its my mission to make things work as they were intended to Any probs post here or at TPU, TPU is the thread I'm maintaining the most.
    "Prowler"
    Cooling:
    Jun 2005
    NYC
    im gonna try later if it work u da man
    Amd Nvidia/Ati -3dmark06 scorebord revisted
    asus L1N64-ws or /b depending on bios chip
    4x1gig 8500 gkill bpk
    2x opteron 8224 @ 3.8ghz
    http://www.xtremesystems.org/forums/...&postcount=236
    vga= 8800gt
    winxp pro
    custom chiller -31 water
    2x dtek fuzions
    bix3-with x3panaflo hi output
    antec 850 quattro
    heat under msimax abitmax and dfimax
    Jul 2006
    does it offer asio driver interfaces for the realtek codecs?
    Apr 2004
    United Kingdom
    You will have to check that, I haven't noticed any, but I've been messing with the equalizer mostly to get my music sounding right
    "Prowler"
    Cooling:
    Xtreme Mentor
    Feb 2007
    Oxford, England
    right mr Ket =]
    Seems I can get the software to install.... WITH the crappy 30 day rubbish. So then I read the TPU thread.
    So then I tried to do your fix of downloading a driver off their website etc..... Problem is when I do that it's obviously searching for a specific card i.e xtreme music etc.. So my luck it says it can't find it.
    Just wondering which driver did you use for the install?
    //James
    Apr 2004
    United Kingdom
    you have to keep the 30day software installed, then run appsetup right on top.. lets just say something will happen to the creative audio control panel
    "Prowler"
    Cooling:
    Xtreme Mentor
    Feb 2007
    Oxford, England
    Quote Originally Posted by Ket View Post
    oh good after i just deleted both
    Also, should I use a Setup from the Win7 Beta drivers ? or just a standard vista?
    //James
    Oct 2008
    Campbellsville, Kentucky
    Is this enabling EAX 5.0 or 4? Also, Is the crystilizer purely software? I was under the impression that it was a actual chip that had to be on the soundcard
    Now lets see how long this thread last before Creative makes a threat
    Download it quick guys!
    Main Rig
    • Intel Core i7 4790K CPU Stock @ 4.4Ghz
    • Asus Maximus VI Extreme Motherboard
    • 32GB GSKILL Trident X 2400MHZ RAM
    • EVGA GTX 980 Superclocked 4GB GDDR5
    • Corsair TX850W v2 TX Power Supply 70A 12V Rail
    • Swiftech Apex Ultima w/ Apogee Drive II & Dual 120 RAD w/integrated res
    • 2X Seagate 333AS 1TB 7,200 32MB HD's in RAID 0
    • 2X Samsung 830's 128GB in RAID 0
    • Windows 8.1 Pro x64
    • Coolermaster HAF-XB
    • Dual Asus ProArt PA248Q 24" IPS LED Monitors
    • Samsung 46" 5600 Series Smart HDTV
    • iPhone 6 Plus 64GB AT&T & Xbox One
    UNOFFICIAL Rampage II Extreme Thread
  18. #18
    Xtreme Mentor
    Feb 2007
    Oxford, England
    hope they wont
    + Ket again, could it be that the actual driver install just installs the licence into the registry?
    If so.. wouldnt it be easier to extract the regkey, if it just usess that to activate it?
    //James
  19. #19
    Apr 2004
    United Kingdom
    Dunno. Creative software is very different to what I do, which is mod drivers. Its actually harder and simpler at the same time. I'm still learning with the Creative software, works fine on XP / 64, Driver works in Vista and W7, but the creative software itself doesn't work on Vista. Driver alone gives people a real nice audio quality boost though
    As we discussed in the TPU thread, we would pay to use the creative software for such additional features, but you click to buy a key and it leads you to a blank page, sooo... I'm sure people can guess what users are forced to do
    "Prowler"
    Cooling:
  20. #20
    Oct 2008
    I've got a Rampage II Extreme and the actual MB sound card. But, Ever since i reformated and i try to activate my creative software with the key they gave me it gives me a Internet Connection Error and says that the program can't find a connection to the internet to validate. BS if you ask me. So i've been doing without all of my x-fi features. i've tried everything to get it to work
    I've uninstalled everything, Deleted every x-fi registry key, Turned off the firewall, opened ports, and it still gives me that error. I even added the launcher to the exception list on my firewall and then tried it. Still a no go. I'll see what your mod tells me when i enter my key to get past the 30 days.
    I do have vista 64 tho.
    It has worked in the past and even works on my windows 7 hard drive, but for some reason it's blocked out this time. i'm thinking i'm going to have to reformat to get it to finaly work properly.
    Main Rig
  21. #21
    Xtreme Mentor
    Feb 2007
    Oxford, England
    yeah definatley, ahh well everything works asin no need for a trial etc... but It still says cant find supported Device etc.. which is a pain but nonetherless still better audio quality and can use the Realtek stuff
    Thanks loads great work!
    //James
  22. #22
    Apr 2004
    United Kingdom
    Odd.. I dont get that unsupported device thing. Closest I had to it was when I cleared out all creative / realtek stuff with driver cleaner. All I had to do was reinstall the ATi HDMI R2.03 driver from realtek.
    "Prowler"
    Cooling:
  23. #23
    Oct 2008
    I get a error while installing the Creative Software "Error 610" "Product State Could not be Determined"
    Anyone know what the deal is with that?
    Main Rig
  24. #24
    Jan 2008
    Thanks ket, it was kinda pointless of me to have high end alesis studio monitors with onboard sound.
    Now with the new drivers some songs are very noticably better,
    the no one knows remix now shakes my floor at half volume and clarity is up
    Edit: win7 x64 btw fyi
  25. #25
    Apr 2004
    United Kingdom
    Glad their working good and once again, the creative software does not work in Vista, but the modded Realtek driver does and that alone gives people much better sound quality.
    "Prowler"
    Cooling:
