XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme > Xtreme News
Reply
Old 12-18-2008, 01:58 PM   #1
Tony
the jedi master
Tony's Avatar
something SSD you didn't know about from OCZ
VALUE matters to us at OCZ, you all know we have a new SSD coming called Vertex which we are positioning as a high performance part; what you didn't know is we have also been working on a new budget/value part.
I get questions about Core V3 all the time, the drive I will talk about here was destined to be Core V3 but we decided it needed a new name...hence enter Apex
Now I am going to be very clear about this new drive and where we think it will shine and where we are positioning it.
Apex is based off Core V2...now before you all shout crappy Jmicron again please listen up. We wanted to bring a cheap fast drive to market, one for the hardware raid fanboys but also one for those who don't mind a little OS tweaking so they can run 1 drive in a laptop etc or run SB raid with 2 or more drives. The point here though is this drive will be very affordable.
I have been watching forums for 2 months now and hardware/software raid is starting to gain momentum, people are liking what they see with SSD on it.
so:
What we have done with Apex is create a drive with internal raid0
So what does this mean in terms of speed? Well it depends on the sata controller on your motherboard but I can tell you I saw 180+ (actually touched 200) reads and 140+ writes on ICH8m (OCZ DIY Laptop), and on my HP Pavillion 9000 which uses an NVidia chipset, I am seeing 140writes and 160+ reads. Now i can't run any write tests as im actually real world testing this drive every day for 10 hrs, my system here has had 50 to 80GB of data on it at various times over this week while I have been testing... so when I bench it i get what you guys will see..IE this drive is in use.
I will post the ATTO from this laptop for you all, remember i saw higher than this on ICH8m, final speed is very controller dependent hence why I have been cautious
To finish....we are positioning Vertex for performance OS use, Apex will and does work fine for OS use also although helping the drive with a few OS tweaks makes it shine...Its a value part, one for those looking to build 4 with hardware raid or 2 with SB raid or even 1 drive with a few tweaks if they are on a budget.
We think Apex is a good fast budget solution and will suit many people.
I hope this is OK with you guys, i have tried to be honest here..i love the drive, its in a 2 yr old laptop running vista32 and it flies.
__________________
Got a problem with your OCZ product....?
Have a look over here
Tony AKA BigToe
Tuning PC's for speed...Run whats fast, not what you think is fast
Tony is offline   Reply With Quote
Old 12-18-2008, 02:06 PM   #2
zanzabar
I am Xtreme
zanzabar's Avatar
so will it be priced less than or more than the v2
__________________
p2 1090t, gd70, g.skill 2x2GB ddr3 1600mhz HZ w/ GTS
2x samsung 500gb(raid 0), ocz agility 120GB, SBA2 plat pro antec p180B corsair 750tx
beyerdynamic DT 770 PRO 80ohms headphones (they are like wall hacks for your ears)
zanzabar is offline   Reply With Quote
Old 12-18-2008, 02:07 PM   #3
cegras
cegras's Avatar
What I'm curious about is that will I be able to to buy this drive, stick it in, follow your 'tweak guide', and enjoy better performance overall? Or is there fine print? Like the system freezing when I want to type a message on MSN ..
__________________
E7200 ; 4850 512
cegras is offline   Reply With Quote
Old 12-18-2008, 02:09 PM   #4
Helmore
Helmore's Avatar
Now for the big question.....When will it be available?
Or should the big question be about pricing or capacity?
__________________
"When in doubt, C-4!" -- Jamie Hyneman
Silverstone TJ-09 Case | Seasonic X-750 PSU | Intel Core i5 750 CPU | ASUS P7P55D PRO Mobo | OCZ 4GB DDR3 RAM | ATI Radeon 5850 GPU | Intel X-25M 80GB SSD | WD 2TB HDD | Windows 7 x64 | NEC EA23WMi 23" Monitor |Auzentech X-Fi Forte Soundcard | Creative T3 2.1 Speakers | AudioTechnica AD900 Headphone |
Helmore is offline   Reply With Quote
Old 12-18-2008, 02:10 PM   #5
Tony
the jedi master
Tony's Avatar
I am running Vista32, all tweaks from my guide, 4GB ram and I have not seen 1 pause yet all week. I even have a config file for IOmeter that loads the drive for 20 mins with random reads and writes (really heavy load) and i was watching hero's off the same HDD without pauses.
Now im NOT going to say no one will have an issue and see a stutter, i see stutters on my workstation which uses Raptors when im pushing the drive really hard...i will say for normal everyday use this is a really good option.
__________________
Tony AKA BigToe
Old 12-18-2008, 02:12 PM   #6
PrometheusCon
PrometheusCon's Avatar
Niiice. I've been wanting a small SSD for my OS.
PrometheusCon is offline   Reply With Quote
Old 12-18-2008, 02:12 PM   #7
Tony
the jedi master
Tony's Avatar
We are looking to launch in the next 10 days, drives are inbound but it is holiday season Sizes I will have to check on but i think 30 60 120 are 100% for sure, larger I need to check.
__________________
Tony AKA BigToe
Old 12-18-2008, 02:14 PM   #8
Gambit_2K
Gambit_2K's Avatar
Send a message via ICQ to Gambit_2K Send a message via MSN to Gambit_2K
I haven't read much about SSD except it seems to have some issues and stuff. But why aren't people recommending me to use it with Vista64?
__________________
Foxconn Blood Rage GTI| Core i7 920 D0@4GHz| Corsair H50| 3x2 GB Corsair Dominator GT 1600 MHz 7-7-7-20| HIS Radeon HD5870 1024MB| Intel 80GB X25-M G2| Cooler Master Silent Pro M1000W| Cooler Master ATC 840|
Gambit_2K is offline   Reply With Quote
Old 12-18-2008, 02:18 PM   #9
FischOderAal
FischOderAal's Avatar
Send a message via ICQ to FischOderAal
What I'm curious about is how Apex and Vertex will perform under OS-X (especially Tiger as I'm still using that "old" version). Most reports on the internet are about Windows and SSD and you can barely read about someone who uses an SSD with OS-X. For instance if you should and how to deactivate indexing. I'm getting tired of my slow notebook drive...
If someone has more info about OS-X and SSD please inform me via PN or something else. Thanks in advance
P.S. Yes, I deliberately used the same beginning as cegras SCNR
__________________
Notice any grammar or spelling mistakes? Feel free to correct me! Thanks
FischOderAal is offline   Reply With Quote
Old 12-18-2008, 02:19 PM   #10
Tony
the jedi master
Tony's Avatar
its fine with Vista64...same as v32, I just like the option of Steadystate to really speed up the drive if needed and there is no V64 support...yet
__________________
Tony AKA BigToe
Old 12-18-2008, 02:31 PM   #11
Tony
the jedi master
Tony's Avatar
Sizes to start look to be 30, 60, 120, 250GB
__________________
Tony AKA BigToe
Old 12-18-2008, 02:32 PM   #12
Jazzy jeff
What about the prices?
__________________
MSI P55-GD65 - i5-750@4.2 - GTX260 - 4GB GSkill DDR3 - 4 OCZ Solid/1 VRaptor - Corsair HX620 - Windows 7 32bit
Jazzy jeff is offline   Reply With Quote
Old 12-18-2008, 02:37 PM   #13
Tony
the jedi master
Tony's Avatar
Prices = Core V2 ish, maybe a touch more to start
__________________
Tony AKA BigToe
Old 12-18-2008, 02:39 PM   #14
Serra
Xtreme CCIE
Serra's Avatar
Kudos to you guys at OCZ for bringing this to market. I've been wondering how long it was going to be until someone started making these, and they're finally here.
Out of curiosity, will the drives be bundled with any software or pamphlets pointing to resources such as SteadyState and your tweak guide? If not, maybe something to think about going forward. The 2 cents it would cost to include a small piece of paper explaining something like that would probably go a long way for a lot of people.
I appreciate the way you and OCZ have presented this product. Very straightforward, laying the cards all out without any marketing bull. When I was thinking about a product like this I had thought about how it would be hyped up as the best thing ever invented, I'm glad to see you were up front with its limitations as well as its benefits.
I also look forward (probably very far forward) to you releasing this kind of product but based on the Vertex (or similar) platform .
__________________
CPU: Dual Xeon E5520
MB: Supermicro X8DTi
Mem: 12GB (6x 2GB) Corsair ECC DDR3-13333
Storage: 4x WD640AALS on PERC 6/i
Case: Lian Li PCA77B
PSU: Cooler Master UPS900
OS: Windows 7 Ultimate
GPU: eVGA 9800GT
Display: N/A - Accessed via network
Serra is offline   Reply With Quote
Old 12-18-2008, 02:39 PM   #15
dengyong
dengyong's Avatar
so:
That's the way to do it.
__________________
i7 920 BATCH 3838B079 4.2GHZ on 1.312v HT on, CFO off
FOXCONN BLOODRAGE
6G CORSAIR Dominator TR3X6G1600C8D
1x GTX 285 w/ heavily ported AquagraFX fc block
ULTRA X3 1000w
Windows 7 pro 64
SWIFTECH GTZ
2x DDC3.2 EK tops 2x PA120.3
WESTINGHOUSE LVM-37w3
Donate to XtremeSystems
dengyong is offline   Reply With Quote
Old 12-18-2008, 02:41 PM   #16
dinos22
Team "TwoForForty"
dinos22's Avatar
price and when (its a rhetorical in case you didnt get it )
__________________
Team.AU
GIGABYTE Australia
Got tube?
Need a GIGABYTE bios?
dinos22 is offline   Reply With Quote
Old 12-18-2008, 02:42 PM   #17
flopper
flopper's Avatar
Seems like a nice touch.
what does internal raid0 mean?
__________________
Intel i7 i920 4.2ghz 1.4200v ekwater supreme -GA UD5 [F9e] - His 5850 940/1100 24/7 - Kingston valueram 6x1gb cl9 - Kingston 2x40gb ssd raid+ software raid and a-data ssd 3x32gb raid0 Areca 1210 - 22inch Lenovo 220x - haf932 - Corsair 750w-watercooled ekwaterblock-sennheiser hd600 headphones - Asus essence stx - Razer deathadder and G15 -windows 7 home edition 64bit - - 18k Vantage (40/60c -) WarHammer Rune priest (one of the 26% that isnt confused on xtreme forums)
flopper is offline   Reply With Quote
Old 12-18-2008, 03:09 PM   #18
Tony
the jedi master
Tony's Avatar
2 nand controllers, 1 raid chip in 1 drive.
split the nand in 2...half to each controller and then raid the output in raid0 to sata. The controller on your board sees it as a standard drive.
__________________
Tony AKA BigToe
Old 12-18-2008, 03:15 PM   #19
cegras
cegras's Avatar
So this would be a good replacement for my raptor OS drive?
__________________
E7200 ; 4850 512
Old 12-18-2008, 03:19 PM   #20
zanzabar
I am Xtreme
zanzabar's Avatar
is there extra cash on the raid controller, or is it the same as the nand controllers
__________________
Old 12-18-2008, 03:20 PM   #21
Tony
the jedi master
Tony's Avatar
does your raptor hit the speeds I showed in ATTO? Does the raptor seek in 0.2ms ?
__________________
Tony AKA BigToe
Old 12-18-2008, 03:22 PM   #22
Tony
the jedi master
Tony's Avatar
cash?? you mean cache
no there is no cache on the raid controller.
__________________
Tony AKA BigToe
Old 12-18-2008, 03:25 PM   #23
Macadamia
Macadamia's Avatar
Tony that means this raid0 is without any intervention then?
No need to install crappy drivers and etc? It always works as a virtual single drive?
If so BIG KUDOS. I use a SB700 AMD board and controller config is a royal pain.
__________________
om nom nom
Originally Posted by tajoh111 View Post
This only confirms what I have been saying for months. AMD trolls/fanboys are the worst and the present time is one of the worst years in terms of trolling. They like to troll anyone that doesn't worship AMD and doesn't hate nvidia. Its been getting worse and probably one of the reasons the Fermi thread reached in excess of 200 pages, people like to crap on NV and worship AMD. You always have a idiot saying this site was paid off because they don't bend their asses over for AMD.
Macadamia is offline   Reply With Quote
Old 12-18-2008, 03:31 PM   #24
shogo_ca
shogo_ca's Avatar
Sounds good tony, i understand the mess you ran throught with the other thread... This one makes it clear that OCZ cares.
__________________
CPU Intel C2D 6400 - 6600 L631B Aircooled 4010 MHz (wip) 3850 MHz daily
COOLER Big Typhoon 120 - Ultra 120/Panaflow 103cfm
MOBO Asus p5w dh - Badaxe 2
RAM 2gb Team 667 cl3 844mhz 4-4-3-4 2.0v (wip)
GPU Bfg 7900GT - XFX GX2 600/1600 3Dmark06 10554 (wip) 207K AM3
PSU Gamestream 600w - Powerstream 520 - Silverstone Zeus 750w
Chassis Lian-Li V2000b Plus2 Lian-Li v1100b
shogo_ca is offline   Reply With Quote
Old 12-18-2008, 03:45 PM   #25
SetteUltras
My first thought...
Tested from OCZ
or
WE test it for OCZ?
SetteUltras is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
XtremeSystems
