Page 110 of 173 FirstFirst ... 1060100107108109110111112113120160 ... LastLast
Results 2,726 to 2,750 of 4313
Thread: UnOfficial Asus Rampage II Extreme Thread
  1. #2726
    Jun 2004
    Milano - Italy
    Quote Originally Posted by zoqiet View Post
    You remember where on the ftp server you found this new version?
    Here.
  2. #2727
    Apr 2008
    Chicago
    JMB363 Nag Screen
    Question 1: Does anyone know how to eliminate the JMB363 nag screen that can pop up during bootup?
    I have all my ICH10R SATA ports full with HDDs/SSDs, so I use the JMB363 (black) SATA port for my DVD drive. It works fine; however, I get a JMICRON nag screen that displays the DVD drive name for a few seconds during bootup. I can hit a key to make it disappear sooner, but it is still annoying. Any thoughts?
    Question 2: Any reason that I would want to make my SATA port for the DVD drive (brand/model in sig below) AHCI as opposed to IDE?
    I currently have it set to IDE and don't plan to change it unless there is some benefit to my DVD drive performance.
    Core i7 920 (D0) 4GHz | ASUS Rampage II Extreme | Corsair 3x2GB Dominator DDR3-1600 | BFG GTX295 H20 | Enermax Revo85+ 1050W | 2 x 120GB OCX Vertex RAID0 | 4 x WD RE3 1TB RAID10 | LG GGW-H20L Blu-ray/HD-DVD | Silverstone TJ07 | MPC355 w/ XSPC top | Feser XChanger360 rad | Magicool Pro Slim 240 rad | HeatKiller 3.0 LT | MCW-NBMAX | PrimoFlex 3/8x5/8 tube | 4 x Scythe S-FLEX SFF21F fans | 2 x Scythe Kaze-Jyuni 12mm thin fans | 2 x ATI Digital Cable Tuners (external) | 1 x Angel Dual-Analog Tuner (internal) | Win7 x64
  3. #2728
    Nov 2003
    So. California
    Memory Speed W/all six slots used
    Have any of you had any issues with your memory speed when populating all six slots? I am thinking about getting another 6 Gb but Corsair says I may have to slow it down some with all six slots populated.
    Main Rig;
    Asus Rampage II Ex, i7 920DO @ 3.64, 12 Gb Corsair Dominator DDRIII, Corsair H-70, Corsair 1 KW PSU, 2 ea EVGA 580's in SLI driving 3 Samsung 245t's at 5760 X 1200 surround, Boot drive Corsair Vertex II SSD, Programs 2 V- Raptors in RAID 0 and a WD 1 Tb RE3 for files and client data. Sound, ASUS Xonar D2X, Normal optical drives Etc. Win 7 Ult.
  4. #2729
    Oct 2006
    Scotland, UK
    Quote Originally Posted by ExEngineer View Post
    1. NO it can't be removed (which is why I'm peeved at having to use this port).
    2. None whatsoever as far as an optical device is concerned.
    A government big enough to give you everything you want, is big enough to take away everything you have.
    System Specs: CM Stacker STC-T01 | Asus Z68 V Pro Gen3 (BIOS 3202) | INTEL Core i7 2600K @ 5Ghz | Corsair 8GB DDR3 1600MHz Vengeance Blue RAM | Corsair 750W TX PSU | Geforce GTX 580 - EK-FC580 Watercooled | XSPC Drive Bay Res | XSPC Raystorm CPU Watercooled | Swiftech MCR320-QP | Swiftech MCP655 | 1 x Corsair Force GT 120Gb SSD & 3 x Seagate Barracuda 7200.12 500Gb RAID 0 | X-Fi Titanium Fatal1ty Pro | DELL U2410 (Rev A02) | Windows 7 Ultimate x64
  5. #2730
    Sep 2008
    Denmark
    Probably a pretty stupid question, but is there supposed to be a pin in the CPU socket, that is not aligned with the others i.e. a bent (or not-bent, since all the other are) pin? Or should I just send it back and ask for a new board?
  6. #2731
    Dec 2008
    Terra
    Quote Originally Posted by Brama View Post
    Tnx !
    Apple MacBook Air
    Apple IPad 2
  7. #2732
    Apr 2008
    Chicago
    Scaramonga: Thanks.
  8. #2733
    Nov 2008
    CA,USA
    I ran into some problems again. After I installed Win7 on my secondary drive, POST become unbelievably long. Sometimes it takes 30 seconds to get the AsusROG animation going. Any idea what might have caused the problem? I am on 1504 for a while now.
    EDIT: Actually, I found the source of the problem after disabled the Asus logo. The system is spending too much time "initiating USB devices" I have 13 usb split coming out of a single usb plug from the mobo. Am I using too much bandwidth out of a single USB channel? Or is there ways to quicken the POST process by limiting the USB and other devices the system checks during each boot?
    Armor.exe worklog
    Mobo: Asus Rampage 2 Extreme X58
    CPU: i7 920
    GPU: ATi HD 4870x2
    Sound: Auzentech X-Fi Forte 7.1
    PSU : Corsair HX1000
    RAM: OCZ 3 x 2GB tri channel DDR3-1600
    HDD: WD 640 Black RAID 0 + 1
    Watercooled
  9. #2734
    Visitor
    May 2008
    Quote Originally Posted by exe163 View Post
    For whatever reason I've found that some devices don't like being on a "splitter hub". I have an IR receiver that causes a long boot pause. However, when connected directly to a USB port it works fine. In your case it could be just a single specific device causing it as well.
  10. #2735
    Sep 2008
    Denmark
    110 pages and no one knows if theres suppose to be a bent pin in the socket? wow
  11. #2736
    I am Xtreme
    Dec 2008
    France
    Quote Originally Posted by koksy View Post
    None should be bent afaik.
    http://pic.xfastest.com/MB/X58/X58-ALL-12.jpg
    Donate to XS forums
  12. #2737
    Visitor
    May 2008
    There might be a slight variation, i.e., dark spots when looking at a socket depending on angle. No pins should be deformed though.
  13. #2738
    May 2008
    Ontario, Canada
    Would anyone recommend this board still today over a Classified? Assume the Classified is $50 more.
    Computer: i7 2600k @ 4.7Ghz | Asus P8P67 Evo | Corsair LP 16gb 1600CL9 | Silver Arrow | Essence STX | Crucial m4 128gb | Silverstone Raven 3|
    Video: 2x Sapphire 6950 Toxic 2gb @ 6970 Switch @ 880 / 1350 | Asus VG248QE |
    Audio: ODAC+O2 => JH|13 Pro | STX => ATH-AD700X / Audioengine A5
  14. #2739
    Dec 2007
    Never had a classified but since the last bios this board is stable as hell with a Pro MEG air cooler I can run 24/7 stable at 4.2ghz 24/7
    Processor: Intel 2500K 4.4ghz
    Motherboard:Asus Sabertooth P67
    Cooling: Prolimatech Megahalem 3x120mm fans 2x Icages, 2x92 mm fans, 140mm PSU fan
    Memory: Mushkin Redline (4 x 2GB) 240-Pin DDR3 SDRAM DDR3 1666 6 8 6 24 t1
    Video Card:Asus Matrix GTX 580 1.5GB
    Harddisk: Wester Digital Black Edition 32MB 7200 RPM 1TB SATA 3.0 ,CAVALIER SE 16MB 640GB SATA 3.0 DRIVE
    CD/DVD Drive: 1 BLACK LG LIGHT-SCRIBE DVD BURNERS
    CRT/LCD Model: BLACK ASUS 25 INCH MONITOR 50000 TO 1 RATIO 1920x 1080P
    Case: Thermaltake Armor Series VA8003BWS Black Full Tower Case solid side panel.
    Sound Card: Sound Blaster Live 24 Bit 7.1
    PSU: Thermaltake Xt 850 watt SLI 140mm silent fan
    Software Windows Vista Ultimate 64
  15. #2740
    Xtreme Supporter
    Jan 2008
    USA
    Quote Originally Posted by Bojamijams View Post
    My i7 920 and I are waiting for someone to do a decent comparison.
  16. #2741
    D-m.o.s.t
    Jul 2005
    The Netherlands
    Have both board overhere and i would recoment the r2ex for normal use and mild overclocking. The classified has some strange issues in booting still.
    bclock also no problem with the r2ex with last bios
    cooling the chipset helps in stability at high bclock. here it was watercooled.
    max bclock
    http://valid.canardpc.com/show_oc.php?id=667814
  17. #2742
    May 2008
    Ontario, Canada
    Do any of the R2E's have the new B3 revision of the X58 or are they all B2?
  18. #2743
    Worlds Fastest F5
    Aug 2006
    Room 101, Ministry of Truth
    They are all B2...
    X5670 B1 @175x24=4.2GHz @1.24v LLC on
    Rampage III Extreme Bios 0003
    G.skill Eco @1600 (7-7-7-20 1T) @1.4v
    EVGA GTX 580 1.5GB
    Auzen X-FI Prelude
    Seasonic X-650 PSU
    Intel X25-E SLC RAID 0
    Samsung F3 1TB
    Corsair H70 with dual 1600 rpm fan
    Corsair 800D
    3008WFP A00
  19. #2744
    May 2008
    Ontario, Canada
    But the B2/B3 thing is only errata enhancements right? What I mean is.. if one were to get into x58 now as I am, would you strictly look for a B3 mobo or not?
  20. #2745
    Mar 2008
    Anyone else having their board acting a bit crazy on higher cpu voltages? Like in the 1.45 + area with no LLC enabled. Could possibly be my c0 running out but it really seems more like a board issue to me though.
    Also noticed the NB/SB starts getting super hot around the 1.45 cpu volts also.......
  21. #2746
    Worlds Fastest F5
    Aug 2006
    Well I just bought a RIIE which is most definitely a B2.
    I was looking at B3 boards but almost all are cut down versions of B2 boards...
    There are a few reports of high clocks with B3 boards (look for a Biostar X58A report in this forum somewhere) but the B2 RIIE is fine for my needs.
    EVGA GTX 580 1.5GB
    Auzen X-FI Prelude
    Seasonic X-650 PSU
    Samsung F3 1TB
    Corsair 800D
    3008WFP A00
  22. #2747
    Mar 2008
    Quote Originally Posted by Biker View Post
    They are all B2...
    I've seen B3 versions of the R2E in this forum and several others.
  23. #2748
    Aug 2007
    Quote Originally Posted by Rol-Co View Post
    max bclock
    247 bclk Hell of a chip you have there !
  24. #2749
    Jun 2009
    Quote Originally Posted by PalmeAsus View Post
    +1 and @ 1.32 volts
    Project BlaXtreme:
    Core i7 D0 @ 4.5 GHz 24/7 "Heat Killer 3.0"
    Corsair Dominator GT 2000 MHz
    Thermaltake 1000W
    nVIDIA GTX480 SC SLI - On The Way
  25. #2750
    D-m.o.s.t
    Jul 2005
    The Netherlands
    Its a great chip at air like this, watercooled also good , can do 4840 mhz 3dmark 2005, 4600mhz+ 3d mark vantage and 4860 32m pi , 4900 1m pi but need a good ln2 chip and this isn't.
    coldboot at -100 coldbug at -117 but won't go faster as 229bclock at multi 23. multi 21 i can reach 246 bclock .
