Page 1 of 2 12 LastLast
Results 1 to 25 of 39
Thread: Jetway HA07-Ultra (790GX)
    Apr 2006
    Brasil
    It's cool when the manufacturers hear us. I'v just reviewed the HA07 Ultra, wich is a really good board, but it was lacking something. So I sugested Jetway to include CPU-NB Voltage and Multiplier settings.
    They have just send me a beta BIOS with CPU-NB Voltage setting, wich helped me to get my X3 8750 to 3.2GHz (12x266):
    The only problem with this beta is that the ACC is not working (no boot when enabled), hence the high vcore.
    Now waiting for the CPU-NB Multiplier
    Xtreme Cruncher
    Apr 2008
    Ohio
    Quote Originally Posted by doompc View Post
    I wish Giga-byte would do that...nice OC too
    ~1~
    AMD Ryzen 9 3900X
    GigaByte X570 AORUS LITE
    Trident-Z 3200 CL14 16GB
    AMD Radeon VII
    ~2~
    AMD Ryzen ThreadRipper 2950x
    Asus Prime X399-A
    GSkill Flare-X 3200mhz, CAS14, 64GB
    AMD RX 5700 XT
    Sep 2007
    Munich, DE
    Best looking 790GX board i think, plan to grab it for a future build. What memory options does it have?
    Are you sure it's not just a warm boot issue. I must do a cold boot sometimes after changing ACC values on various 790GX boards.
    Did you select 1.45V or 1.475V in the bios? Board temps look similar to GBT790GX was always a tad below cpu temp there with a small fan.
    Jan 2007
    Stephens City,VA
    Quote Originally Posted by justapost View Post
    I would say this one would be the best looking,
    Asus Crosshair III
    Phenom X2 550@X4
    Cooler Master V10
    2x2gb G-SKILL DDR3
    ASUS HD 4890 Top
    Antec 850w
    WD 500gb
    WD 80gb
    Apr 2006
    Brasil
    justapost, I'm pretty sure it's a bios bug. It costed me lots of clear CMOS to find out it was the broken ACC. I did some cold reboots too.
    I selected 1,40v vcore, the board overvolts a lot: 1,41v idle 1,50v full
    My previous best on this board was 12x250 1:2
    My RAM won't do 1066 so I had to lower it down to 667 for 266MHz base htt clock: (+100mv on CPU-NB to work at 2400MHz)
    There are reasonable timing settings and vdimm up to 2,85v (undervolts 0,1v):
    Sep 2007
    Munich, DE
    Quote Originally Posted by hstuehmeyer2000 View Post
    Oh did not know that.
    JetWay 790GX Extreme.
    http://www.jwele.com/motherboard_detail.php?147
    Hope they fix that, GBT did that with the first bios revision.
    Can be only the sensor reading is off. On the AsRock I saw a similar high overvolt under load. Measured with a DMM it was only half as high.
    But on that board also the idle reading was reported higher.
    Max difference between idle and load i measured was ~0.03V. That was close to the voltage regulators chip's limit for overvolts. This chip's spec said the chip powers off safe once that limit is reached. Was an STL6740L.
    Your board uses an Fintec Sensor chip. AsRock an Winbond and GBT used an IT87xx. On the gbt board the sensor chip readings where really close to dmm measurements.
    Thank you for the details, good amount of settings there.
    Ran everest mem bench for comparison (testing cpu's limits on aircooling with 330W psu there atm).
    Jan 2007
    I really hope that this board is available in UK ,I have been looking all over for this particular AMD GX board with no success.
    The Boss = AMD8120FX - CHV - 16GB DDR3 Vengence 1600LV@1866C9 - AMD7970 - Corsair 850W PSU Corsair FGT-120Gb - Samsung F1 500GB x 2 - Samsung F3 1TB x 1 - Thermaltake Caesar III
    The Workhorse = AMD955BE - Scythe Ninja Rev2 - CHF-III - 16GB DDR3 Vengence 1600LV - AMD6870 - Corsair 430W PSU Corsair F40A - Samsung F1 500GB x 2 - Samsung F3 1TB x 2
    The Slave = AMD Phenom 9850BE - M3A79-T Deluxe - 4Gb OCZ Blade LV DDR2-1150 - Tagen 480W PSU - XFX AMD5670 - Samsung F1 500GB - Coolermaster 330
    The Apprentice = AMD PhenomII 550BE - XFX890GX - 4Gb Corsair XMS2 DDR2-800 - Seagate ST3160316AS - The Unknown Chassis
    Apr 2006
    Brasil
    justapost, J&W != Jetway.
    I had no problems with ACC on older BIOS (initial and A02), it's just with this beta.
    With ACC AUTO this X3 gos to 3GHz with stock vcore (1,20v) plus 10% (secound "gear" on the 7 shift) = 1,36v full.
    Without ACC I had to set 1,325v wich gives about 1,39v full.
    I'll look for a vcore measure point to see if it really overvolts that high.
    Sep 2007
    Munich, DE
    I realized that as i followed the link but had written the first part of my post already and forgott to edit. So my bad.
    The 8750's clock nice for their price. Did i get this right you can select the CPU-VID and give an multiplicator for the vcore. GBT always used stock VID and and voltage offset. AsRock uses vid's up to 1.55V and then starts to add 0.1V voltage offsets. In the bios you can select that as vcore up to 1.8625V.
    Great, thank you
    Xtreme Mentor
    Apr 2005
    truly nice looking layout!
    I wish Jetway is selling here where I live
    Adobe is working on Flash Player support for 64-bit platforms as part of our ongoing commitment to the cross-platform compatibility of Flash Player. We expect to provide native support for 64-bit platforms in an upcoming release of Flash Player following the release of Flash Player 10.1.
    Apr 2006
    Brasil
    justapost:
    You can select the VID (from 0,8v to 1,55v in 0,025v steps) and a multiplier (the 7 shift, wich works just like the DFI's CPU Special Add): +5, 10, 15, 20, 25, 30 and 35%. The maximum selectable vcore is 2,09v (1,55v + 35%), but then there is the overvolt...
    The cool thing is that if you don't touch the VID, you can overclock keeping Cool 'n Quiet enabled. But Cool 'n Quiet sucks on Phenom, it refuses to return to normal clock with just one core on full load. Cinebench scales over 3x on the triple core because the 1CPU runs with one core at 1.5GHz and the xCPU runs with three cores at 3GHz...
    So I have to disable CnQ for maximum performance.
    But it works like a charm for power consumption. idle power with CnQ is 110w, idle power without CnQ is over 150w (total system, both on IGP only).
    Xtreme X.I.P. Particle's Avatar
    Apr 2008
    Kansas
    It might scale if your load would let it. The Windows thread scheduler bounces a thread between all cores in a system very rapidly. Try idling and just setting affinity to one core under load.
    Particle's First Rule of Online Technical Discussion:
    As a thread about any computer related subject has its length approach infinity, the likelihood and inevitability of a poorly constructed AMD vs. Intel fight also exponentially increases.
    Rule 1A:
    Likewise, the frequency of a car pseudoanalogy to explain a technical concept increases with thread length. This will make many people chuckle, as computer people are rarely knowledgeable about vehicular mechanics.
    Rule 2:
    When confronted with a post that is contrary to what a poster likes, believes, or most often wants to be correct, the poster will pick out only minor details that are largely irrelevant in an attempt to shut out the conflicting idea. The core of the post will be left alone since it isn't easy to contradict what the person is actually saying.
    Rule 2A:
    When a poster cannot properly refute a post they do not like (as described above), the poster will most likely invent fictitious counter-points and/or begin to attack the other's credibility in feeble ways that are dramatic but irrelevant. Do not underestimate this tactic, as in the online world this will sway many observers. Do not forget: Correctness is decided only by what is said last, the most loudly, or with greatest repetition.
    Rule 3:
    When it comes to computer news, 70% of Internet rumors are outright fabricated, 20% are inaccurate enough to simply be discarded, and about 10% are based in reality. Grains of salt--become familiar with them.
    Remember: When debating online, everyone else is ALWAYS wrong if they do not agree with you!
    Random Tip o' the Whatever
    You just can't win. If your product offers feature A instead of B, people will moan how A is stupid and it didn't offer B. If your product offers B instead of A, they'll likewise complain and rant about how anyone's retarded cousin could figure out A is what the market wants.
    Apr 2006
    Brasil
    Particle, I'll try it later. It will probably work, but then I have to set affinity to all cores for the xCPU run.
    This looks more like a OS issue. Nor XP or Vista know how to get the maximum out of current multicore processors.
    When a process is jumping from core to core a Core 2 Quad, there is no problem if it jumps from core 1 to core 2, but when it jumps to core 3, the L2 cache of the secound DIE (cores 3 e 4) doesn't have data for that process, wich leads to performance loss.
    Things will get a lot worse mixing physical cores and logical cores on Nehalem. Imagine if the OS schedules two heavy processes for the two logical cores of the same physical core...
    Sep 2007
    Munich, DE
    justapost:
    Thank you for the details. The multiplier way should produce an bigger overvolt than the offset way.
    Can be you have C1E enabled in the bios. That caused such behaviour here under linux. One core always jumped from c1e to p-state-0 and not p-state-1. So all cores ran at maximum voltage.
    If you want better power consumption, use CnQ with tweaked p-states.
    KTE summed it up here.
    Apr 2006
    Brasil
    Thank you justapost, I'll try that later.
    The new BIOS brings the C1E option, but I haven't tried it yet.
    I'm happy that AMD is a decent option now. This Jetway costs only $ 110 and a good X3 costs little over $100.
    Where a good P45 board is about $150 and a good Core 2 Duo (like the E8400 E0) is almost $200.
    And overclocking K10 is way more fun than doing pointless high FSB on Intels.
    May 2007
    HOw is the Jetway treating you still?
    ANy updates?
    Mar 2008
    New Jersey, Center of the Universe
    Newegg just got them back in stock, and I just ordered one to replace the aweful Gigabyte... (I hate that board)
    Asus M3A79-T W/ PII 720@3.6Ghz DTek Fuzion Water Block
    Raptor X 150G Boot Device & 3 X WD 500GB in RAID 5 Load Device
    8G OCZ Reaper @1066
    2xVisiontek 4870 Xfire @790/1080Mhz w/XPSC Water Blocks
    Razer Barracuda Sound System
    Windows Vista 64 Bit SP1
    LG 24" 1920X1200
  18. #18
    Apr 2006
    Brasil
    Eternalightwith, still no CPU-NB Multiplier.
    I hope the next BIOS (with Phenom II support) will have it.
  19. #19
    Sep 2007
    Jakarta, Indonesia
    I'm bookmarking this thread, interesting board indeed.
  20. #20
    Mar 2008
    OK.... Got mine yesterday. and wouldn't you know it, its dead..
    Will not boot, or even POST. Just gets FF in the port 80 display and hangs. No video. Tried multiple types of memory and processors... tried clearing CMOS, tried standing on my head with one toe facing mars.
    DOA, oh well. Just my luck
    As far as impressions go, it is a REALLY nice piece. Super clean design, terrific heatsinks and really clean layout. I'm gonna RMA it and try again
    The packaging is very austere, which is nice, although the box is a little cheesy, with "Hummer Studio" all over it. There is an awesome clear piece of the board in one corner that has a little horse on it that lights up!
    Also, it has the best selection of ports I've ever seen. It has 8 (eight) SATA ports (6 regular and 2 eSATA). 3 Video (HDMI, DVI, VGA). Tons of USB, on board CMOS clear, start and reset switches. A really nice product, just hope I can get a good one.
    8G OCZ Reaper @1066
    LG 24" 1920X1200
  21. #21
    Xtreme Mentor
    May 2008
    cleveland ohio
    Quote Originally Posted by nanohead View Post
    DOA no way.
    well anyways FF on the led screen on board the HA06 similar board I got has that and that shows up when it gets in to XP.
    what Power supply are you using ? and also have tried boot it with just cpu and memory in it the IGP usually defaults to D-sub after clear cmos.
  22. #22
    Sep 2007
    Jakarta, Indonesia
    Yeah, such life with Jetway, or more precisely, tier 2 AMD board makers, it's always a hit or miss thing. I do hope it will be successfull, i don't want another Soyo or Epox in the making -though the economy is certainly not that promising.
  23. #23
    Jun 2008
    WHAT?? this didn't work?
    Anyway..sorry to hear that...hope you have better luck.
  24. #24
    Mar 2008
    Quote Originally Posted by demonkevy666 View Post
    DOA no way.
    Yeah, thanks... FF is the correct runtime port 80 code, it is supposed to show up when the BIOS hands over control to the bootloader.... I hope to get it when I get it to boot.
    I may try swapping some other components to see what happens, did some CPUs and memory, no power supplies yet, but will do that this afternoon. I may try another video card and try and bypass the IGP...
    Quote Originally Posted by spursindonesia View Post
    I agree, although I had some GREAT Epox boards that were indestructible!!! The board itself looks as high quality as any Gigabyte I've ever owned. Looks awesome actually. Just may have gotten a dud, which has happened with every board manufacturer I've ever tried
    Quote Originally Posted by zif33rs View Post
    Not yet, but I might try connecting my brain to a vacuum cleaner while standing in a cauldron of boiling oil to see if that helps!!!
    8G OCZ Reaper @1066
    LG 24" 1920X1200
  25. #25
    Mar 2008
    Got it WORKING!!! hooah
    It didn't like the CPUs I was using.... Have no idea why, but I don't care ATM....
    Tried a A64 4100 and it popped to life!!!
    Now, on to testing
    8G OCZ Reaper @1066
    LG 24" 1920X1200
