Page 5 of 29 FirstFirst ... 234567815 ... LastLast
Results 101 to 125 of 705
Thread: 700mhz wall on HD4850 is smashed.
  1. #101
    Dec 2007
    Anyone had similar issues on my prob?
    Quote Originally Posted by Battlestar View Post
    Hi I have a problem regarding the RBE latest version. I set the fan into default settings and it shows on GPU-Z 50% fan speedand it drops my temps from 72deg to 61deg , my problem is it underclock my GPU Clock into 500Mhz but the Default Clock remains 625 Mhz with same Memory 993Mhz I think. Is this normal? Sorry I can't provide screenshot still here @ the office Anyways, I revert my default BIOS and still waitin' for your answers
    Hmm Im not sure buddy, But Im pretty sure when you check on GPU-Z under Graphics Card Tab at the botton you can see this following:
    Using RBE with 50% FanSpeed (I used the Set all fan settings to recommended values that's why came up 50% FanSpeed)
    GPU Clock: 500Mhz Memory:9XXMhz
    Default Clock 625 Mhz Memory:9XXMhz
    Also on GPU-Z Sensor Tab:
    GPU Core Clock: 500Mhz
    GPU Memory Clock: 9XXMhz
    My Default BIOS
    GPU Clock: 625Mhz Memory:9XXMhz
    Another thing, I don't see anything this kind of tables on my latest RBE
    *See attached file with red box
    Im using WinXP SP3
    Sapphire 4850
  2. #102
    Xtreme X.I.P
    Mar 2005
    Belgium, Namur
    When i edit bios , fan speed is ok but GPU clock max to 700 and vGPU doesnt change.
  3. #103
    Jun 2008
    @Battlestar: I am also missing the area indicated by red box, however, I just used the graph and bumped the minimum up, and steepened the slope some. However, Sensors (page in GPU-Z) doesn't accurately report GPU speed when operating in 3d mode, just sits at 500 all the time... Not sure if this is just cause its early, or what.
    Also, my down clock to Power State 1 (power play 2d setting) doesn't change clock speed at all. So I'll try another setting... Perhaps I just have to use the right numbers. Can anyone confirm if changing voltage in Bios with RBE actually works? Or are we bound to mod for voltage tweaks?
  4. #104
    Dec 2007
    Quote Originally Posted by darkskypoet View Post
    I see, can you please provide a screenshot when you got an satisfied settings on RBE? Thanks
  5. #105
    Jun 2008
    @Battlestar; just PM me and I'll email you one of what I have that works fine for my fan speeds. I don't have power play under clock working yet.
  6. #106
    Aug 2004
    The Netherlands
    I was wondering, does the voltage control actually work? If so then hard-vmodding would be absolete, right? Nice!
    Proc: Q9650 9x496 @ 1.440v batch L844B703
    Ram: 2x2GB OCZFlexII PC-9200 4:5 1240MHz 6-6-6-18 @ 2.12v
    Mobo: Gigabyte EP45-UD3P rev 1.0 - bios F9b
    Video: 2x Palit Dual Sonic HD4870 1GB in CF (840/4400)
    PSU: OCZ PowerStream 520W + Thermaltake VGA 450W
    HDD: 3x250Gb Barracuda 7.10 SATA2 Raid0 (ICHR10) 2x200Gb Barracuda 7.10 SATA2 Raid1 (ICHR10)
    Audio: Audigy 4
    Case: Dual Coolermaster Stacker; one for system rig and one for watercooling loop and cooling
    [SIGPIC][/SIGPIC]
  7. #107
    Aug 2006
    Oxford, UK
    I have tried putting the voltage adjustments up to 1.4v but this results in only 1.21v...which is still .05v over stock so it's a small increase and allows you to go to 725-750 core.
    || 2500K @ 5GHz 1 thread, 4.8 2 threads, 4.7 3, 4.6 4 1.284V ||
    || P8P67-M Pro || 8GB @ 2133MHz ||
    || 5850 @ 1000/1225 || XFX 650W || Silverstone FT03B ||
    || 37" LCD TV || CM Hyper 212+ || Samsung 2.1 Soundbar ||
  8. #108
    Xtreme X.I.P
    Mar 2005
    Belgium, Namur
    Quote Originally Posted by gurusan View Post
    Could you post RBE frequency tab shot ? With 800mhz 3D core. When i try 800 or more than 700mhz, results is max 700mhz
  9. #109
    Aug 2004
    The Netherlands
    Okay, good to know before hard modding, I want to find out what the max is of my core.
    Quote Originally Posted by Pt1t View Post
    Take a look at this shot. it's my bios for 710core and Powerplay at 160/500 in 2D.
    Just replace al of the 710's with 800's (and giveup your corresponding voltage) and it should work. And disable Overdrive in Windows, or it wil override your setting of 800
    Audio: Audigy 4
    [SIGPIC][/SIGPIC]
  10. #110
    Aug 2006
    Oxford, UK
    You need to disable overdrive, otherwise CCC will force it back to 700mhz I did this mistake as well.
  11. #111
    Xtreme X.I.P
    Mar 2005
    Belgium, Namur
    Thanks, and for vGPU ? you just type ~1.3v for 3d settings voltage and it works ? Because i have only 1.17v in load ^^
  12. #112
    Aug 2006
    Oxford, UK
    For me the vgpu only allowed me to go up to 1.21v through the bios
  13. #113
    Xtreme X.I.P
    Mar 2005
    Belgium, Namur
    for 1.21 , you put 1.3v ?
  14. #114
    Aug 2006
    Oxford, UK
    I put 1.400v actually and it only got me to 1.21v
  15. #115
    Mar 2008
    What drivers are you guys using? The Hotfix I presume?
    My new Intel build, logged here.
    WE GO PLAY HOOP
    -Barry
  16. #116
    Jun 2008
    @biftek: Yep. Although, I never really encountered any stability issues with 8.6.
  17. #117
    Oct 2003
    Durham, NC
    Quote Originally Posted by [XC] gomeler View Post
    I can already bet that the 4870 will come out 10% ahead if not higher just from my experience with the 3850 vs 3870. Get a 4870 and clock it to 900MHz
    So 10% is worth 2x the price?
    Can someone elaborate on how much memory bandwidth the 4850 needs? How much is performance scaling on the 4850 with this new BIOS? I was leaning towards a 4870, but this BIOS hack is blowing my mind.
    BIOSTAR TP67B+ | RPP 750W
    Core i5-2500K @ 4.7 GHz | TRUE
    256GB Samsung 840 Pro | X-Fi Titanium
    16GB G.Skill Ripjaws X | Sapphire HD 7950 3L
  18. #118
    Feb 2007
    i got my visiontek 4850 doing 725/1050 no problems so far. what benches are you guys using for stability on these cards since ati tool doesn't work? I remember using the fur renderer when i had my 8800gt and it killed 2 of my cards and i know of several other people that had their cards die on them, so i don't really want to use that for stability testing.
    E8500 (4.2 ghz)
    Crucial 800 8gb
    Abit IP-35 Pro
    Thermalright Ultra 120 Extreme
    Hr-05 NB heatsink w/ 80mm fan
    GTX260
    Antec Quattro 850 psu
    28" I-Inc lcd monitor
    Logitech G9
    Logitech G15
  19. #119
    Aug 2006
    Oxford, UK
    For anyone who is interesed, I have modded the 4850 MSI bios....not only have I raised clocks and voltage under load, but I have improved on the powerplay feature as well as the fanspeeds. IMO this is how it should have been shipped from the factory...it is a bit loud while gaming and such but this way the cooler is actually effective!:
    2d clocks
    .98vGPU, 160core/500mem
    3d clocks
    1.20vGPU, 720core/1100mem
    Download here
    http://cid-dd5c526e6044c7cc.skydrive...ru4850Bios.bin
    The fan will only go down to around 25% in idle and 2d clocks, but it's pretty much inaudible and during 3d clocks should keep it under 70c full load, more like mid-low 60s.
    All the reference 4850s should be able to do this, but if you are getting crashes then I can make you up a slightly less aggressive profile, or you can edit it yourself with the RBE tool. I recommend stress testing with rthdribl and some Crysis benches.
  20. #120
    Dec 2007
    Hi Gurusan,
    It seems your pretty active on this thread Can I ask a favor? Could you make me one that comes with:
    GPU Clock: 675Mhz
    Memory: 1000Mhz
    FanSpeed 60% on Load and 25% on Idle?
    Clock Info1:160/500?
    Clock Info2:500/750?
    You may DL the stock BIOS of my card here: http://www.techpowerup.com/vgabios/i...ace=&memSize=0
    Thanks-Battlestar
  21. #121
    Aug 2007
    Istantinople
    Great work people! How about putting in some benches? The memory can hardly be overclocked and I wonder if with such aggressive core clocks (such as 925MHz :O) the card is bandwidth starved?
    For example, a comparison benchmark between 800-900MHz would do the trick
  22. #122
    Nov 2007
    Lisbon, Portugal
    Thanks gurusan!! this will come very handy!! I did my own profile with RBE too, but I couldn't fiddle with vgpu settings. I might give this one a try after lowering the core and mem freq. to a more acceptable 680/1075 (these ones I know my card can handle...)
    ASUS P5Q DLX 2201 | Q9400 @ 3680Mhz 1.26v (BIOS) cooled by Corsair H50 w/ Noiseblocker Multiframe PWM | 2X2 OCZ BLADE PC2-9200 @ 1150Mhz 5-5-5-15 1.80 (BIOS) | SAPPHIRE RADEON HD5870 @ stock speeds | PC P&C Silencer 750 Quad | iiyama ProLite B2409HDS
  23. #123
    Dec 2007
    One could explain me what is the difference between State 1 and State 3 in RBE ?
    And now much can we increase Vgup ? Is there a limit ?
  24. #124
    Aug 2006
    Oxford, UK
    Hi Gurusan,
    GPU Clock: 675Mhz
    Memory: 1000Mhz
    Thanks-Battlestar
    Try this, the fan profile may not be exactly as you want it, you can play with the slope using RBE:
    http://rapidshare.com/files/12540238...phire.rom.html
    Quote Originally Posted by Caped Crusader View Post
    The stock bios is 1.15-1.16 load, my bios is 1.20-1.21v load so you should be able to do much more than 680mhz on 1.2v No harm in being conservative though
  25. #125
    Dec 2007
    I have a small problem with RBE: every time I mod a bios and save it, i lose all the voltage settings, they re replaced with ---
    For example if I open an official bios file or your bios Gurusan in RBE, i see the voltages, but when I save the file and reopen it all the voltages are gone (---).
