Results 1 to 22 of 22
Thread: A-Data PC6400 2x2G 5-5-5-18 1.8V what IC,s Please
    Mar 2005
    Ontario, Canada
    I just got some A-data pc6400 2x2g ram for $87 that is running very good for me. They are running 4-4-4-12 at 400fsb 1:1 at 1.8V and ran to 500fsb 1:1 5-5-5-18 at 2.1V, have not tried lower voltage yet. Does anyone know what IC's they have, how far they clock and what is safe voltage. Thanks.
    Rampage III Gene I7 950@4.48G--1.485V HR-02 12G G.Skill 1600-1.5V, GTX470-SLI@725core 1750mem, Antec P180 MINI
    Mar 2005
    Ontario, Canada
    WTF!!!
    This ram just passed two sets of memtest at 1066 5-5-5-18 at 2V in a maximus formula with clock twister on strong.
    I am Xtreme zanzabar's Avatar
    Jul 2007
    SF bay area, CA
    if it dose that then its probly a powerchips based kit
    5930k, R5E, samsung 8GBx4 d-die, vega 56, wd gold 8TB, wd 4TB red, 2TB raid1 wd blue 5400
    samsung 840 evo 500GB, HP EX 1TB NVME , CM690II, swiftech h220, corsair 750hxi
    Oct 2005
    Yes they are very good value for the money, my teammate got a pair of them and they are stable @ 2.1V 1100mhz
    Here some screens:
    Oh i forget week 50, the newer ones are total crap and can't even reach 1ghz 5-6-6-20 , no matter of voltage
    P67B3 SB D2@5.1G_1.47v :bow: SA PSC GF110 SSDS SPI-6.79 06-37580 Vantage-P36245
    If life gives you a computer...OVERCLOCK IT! :yoda:
    Mar 2005
    Indonesia
    i've tried one
    and tried two pair just for fun
    Sep 2005
    It is power chip
    Oct 2005
    Mine are stable @ 1100mhz 5-5-5-12-5-45 @ 2.15V everything i try to go higher gave in instant instability no matter of voltage, insane - even sub-taming change freezes the computer.
    Tested with Memtest2.0 and under Vista x64 Memtest for Windows
    Very nice memory considering the price in Europe 2x45$ for 4 gigs
    Jul 2006
    Massachusetts, USA
    Warning, n00b here:
    I have 4x1gb of this EXACT same set of RAM (5-5-5-18, 1.8.v) and for some reason they are holding back my system OC.
    @ 391 FSB, my system passes 6+ hours of Prime95 and Orthos small FFTs with NO errors and NO problems. I've run the small FFT tests over and over and by that measure alone, my system *should* be totally stable......
    But once I try Blend test, I get an error within two minutes; since blend puts more stress on the RAM, I can only assume it's the RAM's fault.
    I try higher voltages, 1.9, 2.1, even 2.2 and it makes NO difference; the timings are as high as my motherboard will allow (5-5-5-15).
    Can anyone tell me what the heck is going on here?
    Xtreme Mentor
    Oct 2004
    SLOVENIJA
    can you guys post exact what ram is it.....so we can track it down
    A-DATA DIMM 4 GB DDR2-800 Kit ?
    ASUS P5K-E // E8400 Q746A519
    G.Skill F2-8000CL5D-4GBPQ
    LC 550W GP// XPERTVISION 9600GT
    Mar 2005
    Ontario, Canada
    mine have red heat spreaders on them, will look in case for part number later.
    Jul 2006
    Massachusetts, USA
    Quote Originally Posted by fordf250 View Post
    Same here. They do not say "Vitesta" on them, I'm sure of that much, but I'm too lazy to open up my case and look for the number right now....
    Aug 2005
    Sweden
    I guess they look like this
    I7 2600K
    Asrock P67 Extreme4
    8Gb Team Xtreem
    Sapphire HD6950
    Cooltek 600W
    Jan 2008
    how is adata on warranty though some people have told me they had to send back the sticks to taiwan?? you think thats bs or any truth to that??
    upgrading...cooler master cm690 case, corsair hx850, samsung 1tb x 3, optiarc burners x2, gskill 4gb ripjaws, working on the rest again
    Mar 2005
    Ontario, Canada
    Quote Originally Posted by zfactor View Post
    I dont know but for $87 and 4G, if it burns it burns.
    Here is a screen of them doing 540mhz at 2V and occt ram test for 30min with part number from cpuz.
    http://good-times.webshots.com/photo...67863468oOyAwk
    Jul 2006
    Massachusetts, USA
    Oct 2004
    italy
    ADATA 4gb KIT HAVE POWERCHIP IC and ELPIDA IC
    ELPIDA run 520-530mhz cas 5 2.2v not gain over and 800mhz cas 4 2.0v-2.2v
    POWERCHIP IC run 550mhz-580mhz cas 5 2.2v not gai over.
    gig77
  18. #18
    Feb 2006
    Good afternoon. Would it be possible for someone to post up thier Timings for the A-Data 2x2gb kit 5/5/5/18 1.8v ram that this post relates to please?
    I'm having a rough time getting my sticks over 450 fsb in the board in my sig. Running the setup as;
    5/5/5/15,( as it fails memtest at 18), at 1.9v. NB voltage is 1.53v, tried all combos possible with cpu volts, mem volts up to 2.1v, GTL's,(which did make a slight difference in stability),and all sub timings are mostly on auto, however I did try 52 for trfc,(which the ram defaults to anyhow), tried Performance Level 9, no help there.
    Anyhow, any help is highly appreciated as I can't get 455 fsb stable, or anything higher of course. Been trying at 337/667 9x multiplier. Not board related, as my HZ's run 478x9 flawlessly. Thanks.
    Larry
    Q9650
    Asus P5Q-D Bios 1406
    280 GTX FC Block
    2x2gb OCZ Flex II PC2 9200
    Water Cooled/ Iwaki MD20/ D-Tek Fuzion
    XFX 850 Watt
    OWC SSD
  19. #19
    Mar 2005
    Ontario, Canada
    Quote Originally Posted by Big Lar View Post
    Larry
    Running 528 here at 2V memset showing 535? all timings.Click link.Tell me if it does not work.
    http://good-times.webshots.com/photo...67863468XvYWKW
  20. #20
    Feb 2006
    Thank You, I will try those settings out, tho not much different from default, other than tref.
    Larry
    Q9650
    280 GTX FC Block
    XFX 850 Watt
    OWC SSD
  21. #21
    Dec 2005
    ESTONIA
    im running mine at 1000MHz 5-5-5-12 2,1V tRFC 50. that was 6h OCCT-MEM stable.
    will try with lower voltage today
    Intel C2D E8400 @ 4000MHz ~1,192V
    Thermaltake Big Typhoon 120
    MSI P35 NEO2-FIR (bios v1.8)
    ADATA 2*2GB DDR2 800+ EE
    ASUS Geforce 8800GT 512MB + Accelero S1
    Seasonic S12-600
  22. #22
    Jun 2007
    Does anyone know how to distinguish between the sticks that have the Powerchips IC's and the ones who have the Elphida IC's? Can you tell from the Serial numbers or production dates?
    Drive it like you stole it
