I made a nice alumninum bracket to support the fill tube.
It took quite a while to gt a mirror finish from the piece but in the end I was pleased
I drilled and tapped it for a pair of thumbscrews so it would be easy to remove in order to fill the res.
That's my 22" monitor captured on the support
Here we are back in the Lair putting this beast to rights.
I love how the gauges look with the rest of the rig. I wish Silverstone made a DVD dress plate like Lian Li but the finish of the case matchs the LiteOn pretty well.
I spent a few more minutes dressing the edges of the black part of the Raptor X display and polishing them before gluing it to the clear part of the window.
I then took the heatsinks off the BFG 8800 GTS 0C and cleaned the factory TIM off with denatured and mountd the waterblocks. The blocks have to come apart and be fitted with the G80 adapter kits.
Do you notice anything odd about these two 8800 GTS OC cards???
I tried heating the RAMsinks before installing them but it just wasn't working. The crappy self adhesive TIM they ship with is useless. I spent a fewa annoyed minutes pulling all that useless tape of all the sinks and cleaning them with dnatured so they will be ready to install when some better tape arrives tomorrow.
I then cleaned the TIM off the AMD processor and took the
GTX apart to put on a sweet copper top, AM2 adapter and pair of Iandh barbs.
Hot Sex! Why the hell Swiftech did not make them that way from the git go I'll never understand. They also neglected to include a pair of Orings with one of the MCW60 blocks...and NO NUTS for the AM2 kit..that's unacceptable. The latest revision of the
GTX has a special backing plate for Socket 775 that is vry nice...but the nuts are welded too that plate! So what the hell does Swiftech think an AM2 user is going to do if he does not happen to have 4 6-32 nits on hand? That's a srious oversite in an otherwise well thought out package.
Before I could install the motherboard I needed to do a lot of cable wrangling. You don't controll 8 fans without some wires... The Silverstone controllers are nicley designed for stealth mounting due to their dimuinitive size and sweet little modules that can be stuck anywhere there is a bit of space.
Here are the three modules from the three kits I for 2nd day air from NewEgg. Each controller handles three pretty high watt fans.
I made up a very nice "squid" to feed the thre gauges and terminated it in a Molex.
Mounted the HDD cooler. I went with a plain black non LED model. I briefly considered adding a 9th controller to control this 9th fan but it's a very low CFM fan to begin with.
I stealthed the USB/FireWire/Audio and switchgear cabling.
The top fans. 4 pin Mobo power, 24 in mobo power and DVD SATA power cables all get hidden by the motherboard. I lashed them to the motherboard tray to make removing and replacing the motheerboard less annoying...Silverstone uses very long mobo standoffs and I took full advantage of that. The 8pin mobo lead from the TT SU was too short...but in my amazing stash of cables n things I found an 8pin to 4 pin adapter that made it possible to reach the header...YAY for NEVAR throwing away an adapter. That adapter was at least 3 years old
At the moment the back side is just as neat as the front...a credit to the design of this case. I am endeavoring to take full advantage of the dual compartment layout by hiding all the fan cabling between the rad and the top of the middle bulkhead.
I shortened/sheathed/re-molexed the MCP655 pump (which always have about 3 foot leads for some reason)
And another look at my custom ported MicroRes. In the Future I will just make my own from scratch so I can use all BSPP fittings.
God I love having a shop
I have been wanting to mak stuff from metal but without a bench and vice etc it's about impossible. Gotta love polished aluminum.
I still have some work ahead of me here. I want to modify a Koolance temp sensor to fit in the reservoir. I think one lead should be intake air and another exhaust air and a third Res temp. I am not keen on cluttering the loop with any reducers/adapters for the Koolance stuff I have on hand. So I will make something special
Again my amazing collection of cables n things saved my ass. I just happened to have a number of extensions for 3 pin leads and some other odd adapters that allowed me to take the two molexed top fans and connect thm to the Silverstone controllers. I did a lot of connector modifying to make that happen.
The case is setting on it's front panel in this shot and the three cntrollers will nest in the small space in front of the Rad. This will keep them out of sight through the grill onc the panel is on.
I do whatever it takes too get at very nook. The case is really starting to fill up...But I have managed to keep it looking empty.
That's powered up and cabled up except for the DVD data cable and the PCIe pwer leads from the PSU.
I like that nice mpty front bay...something about unused space adds a sense of Luxury to the build...
Test fitting the cards to gt the loop completed. If only the RAMsinks were on...
