Page 1 of 2 12 LastLast
Results 1 to 25 of 34
Thread: Multi-core supported OCCT
    Xtreme Cruncher
    Jul 2005
    London - UK
    Didn't see anything about this but it's been out for a few weeks
    http://www.ocbase.com/perestroika_en/
    Ocbase.com is the home of OCCT, a free CPU/memory stability test.
    OCCT comes from "OverClock Checking Tool". Here is a list of its features :
    Up to 16-core support ( for instance, up to a Quad-Kentsfield or an Octo-Conroe )
    Customizable tests ( Duration, Priority, CPU or RAM, ... )
    CPU and Motherboard detection
    Monitoring support through 3rd party application ( i.e. MBM5, Speedfan and Everest Ultimate Edition 3.50 or above )
    Can produce graphs showing temperature and voltages during the test : Unique feature !
    Multi-language support
    and much more !
    Core 2 Quad Q6600 @ 3GHz . DFI DK P45-T2RS Plus . XFX 9800GT 512MB . 8GB OCZ Blade PC2-9200 . WD6400AAKS AHCI .
    Creative X-Fi XtremeMusic . Hanns.G 28" LCD . Thermalright U120-E . Seasonic S12 600w . Windows 7 Professional E Retail x64 .
    Xtreme Cruncher
    Jan 2006
    Cornwall, UK
    Sounds great the old version was a very good stability tool, more stressfull then prime and only 30 minutes, great .
    xtreme energy
    Oct 2004
    Europe, Latvia
    I am using this all the time
    30 mins + 3dmark 06 a few times + gaming + WCG 24/7
    Usually occt + 3dmark is enough to say that the system is stable
    Xtreme Cruncher
    Jul 2005
    London - UK
    I think 30 mins is a little too short, probably doing the custom test of 1 hour of this would be enough though
    Mar 2006
    HaNoi_VietNam
    Can u revews this eatures I don't see opption config for RAM and CPU..?
    Jan 2005
    Paris , France
    click on the orange button to go to the options
    there ,you can choose the type of test, the duration and the software used for monitoring
    p4 1800A SL6SN @ 3.6 Ghz
    3200+ @ 2.7 ghz
    2*256 BH5@ 270 2-5-2-2 ( for bench )
    2*512 Gskil PC3200ZX @ 240 2.5 8 4 4 ( daily use )
    X800GTO² @ 645/630
    mobo : sapphire PI-A9RX480
    160 go SATA maxtor DM9
    200 GO SATA maxtor DM 10
    120 Go hitachi 180 GXP
    approaching aphelion
    Nov 2005
    Aix-en-Pce | France
    Newer version here:
    http://www.ocbase.com/OpenBeta/OCCTPT1.1.0.b03.zip
    Very nice tool.
    Best Regards,
    Xavier
    "I prefer to fly alone... when alone, I perform those little coups of audacity which amuse me..." Col. René Fonck (1894-1953), the Ace of Aces.
    Sep 2005
    Switzerland
    I have see this one was in preparation, and totally forget to see when it will be here.. thanks!!
    I was liked use it for test voltage too during stress test...
    I am Xtreme
    Dec 2003
    Talking Hallehuyah!
    Multicore support was one of the things that made me choose s&m & ignore this as a part of my OC stability toolbox.
    Got just the CPU to test this w/
    Quote Originally Posted by before
    Newer version here:
    Very nice tool.
    Xtreme 3D Mark Team Staff
    Nov 2002
    Juneau Alaska
    it doesn't seem to do anything...
    I have a Quad Core here, and it doesn't stress a single core, raise a single temp, or even touch the ram... it just doesn't seem to do anything more then report my speed and such.
    Xtreme Cruncher
    Jul 2005
    London - UK
    and you pressed the RUN button???
    edit: oh, and you do know that it does nothing for the first 1 minute and the last 4 minutes so it can take idle readings for the graphs?
    Sep 2005
    Switzerland
    don't know why Kunnaak:
    here some screen dual core runing
    you see the 2 core running at 100%.... yet i can test it with a Quad core.. will ask peoples...if they are not in hollidays.
    12V rails between the test:
    Vcore oscillation:
    Oct 2006
    Atlanta GA - USA
    It hasnt worked very well for me , It tested my x2 3800 and siad it was stable @ 2.9 each core
    I cant get it prime stable over 2.75 though
    Heatware -> http://heatware.com/eval.php?id=51939
    Ebay -> http://myworld.ebay.com/onewhoisplug
    Feel Free to hop in my ventrio server and chat with us
    Vent6.gameservers.com:4498
    Aug 2005
    Perth, Western Australia
    It failed mine within 3 minutes, doesn't seem right as I haven't had a single program crash...
    Sep 2006
    Silicon Valley, CALIF
    P5WDH - BIOS: 1801 - QX6700 @ 3.0G
    OCCT v1.1.0 b03
    - screen taken right before test end
    - 10min Custom Test length
    - too bad OCCT stops MBM dashboard
    - TEMPS: NB: 52.7c SB: 35.5c FETs: 55c MEM: 46.8c
    AMB: 68f/20c
    (temps taken with Fluke Mini-62 IR thermometer)
    yep, agreed
    - OCCT is a nice load utility and have been using it for a month now
    - really does smack QUAD systems, as well as SuperPrime v0.6
ID:	54397   Click image for larger version.
    CURRENT: (mild OC)
    P5W DH Deluxe Rev 1.02G/66MOAG (BIOS: 2602); CPU: Q6700 (G0, wk 23) @ 3.0G; FSB: 300
    MEMORY: OCZ OCZ2G11002GK 2x1gB or 4x1gB PC2-8800; vDIMM = 2.15vdc; 500mhz; 3:5; 5-5-5-15/18; 6113/6093
    HSF: Thermalright SI-128 w/120mm; LOADED TEMPS: CPU: 121f/49c; Cores(avg): 143f/62c; MEM: 102f/39c; AMB: 72f/22c
    GFX: AIW 2006 Edition PCIE; PSU: Seasonic S-12+ 550W; FANS: 4 x 120mm; 2 x 80mm (all low RPM, low noise)
    DRIVES: 7200.10 250G (x2); 7K500 500G (x1); 7200.10 400G (x2); 7200.10 250G (x1); ADDED Controller: Adaptec 1430SA PCIE
    AUDIO: X-FI Elite MOD: http://www.esnips.com/web/X-FIOpAmpandCapModification OPTICAL: LiteOn: DH-20A4P, LH-20A1H; BUILD LINK: http://www.esnips.com/web/ConroeReady
    Dec 2006
    Hey guys
    I found this thread about OCCT, so i thought i might as well keep you guys updated (I'm the guy behind OCCT)
    I just reached 1.1.0.b09, which includes new features, like :
    *New, more effective Error detection algorithm
    *Multi-CPU temperature support
    *Custom temperature and voltages support
    *Modified graphic design
    *Maximum CPU Temperature
    *Hyperthreading as Dual-core Option ( i.e. treat a P4 HT as if it was a Dual-Core Pentium 4 ==> launch 2 threads )
    This version, once properly translated into foreign languages ( english is fine, french too, i miss the other translations) will soon be released as 1.0.3 ( i'm making a release mid-way, otherwise the delay between 2 versions would have been too long).
    Just tell me how it works for you, and tell me if you find any new bugs !
    http://www.ocbase.com/OpenBeta/OCCTPT1.1.0.b09.zip
    Kunaak : can you try again this new version, and tell me how many cores OCCT detects ( in system monitor, look for "Core number") ? i'm wondering what's happening, i've had good reports from previous Quad-core users.
    Dec 2006
    If this is considered as spam, just let me know, i'll stop
  18. #18
    xtreme energy
    Oct 2004
    Europe, Latvia
    Great I will test it, keep great work on OCCT
    It has become one of the favorite stability tests
    Quote Originally Posted by LiQU!D
    Do your other progs stress and heat your cpu that much? Try also running 3dmark06 in a loop for 2-3 hours
  19. #19
    Dec 2006
    OCCT is a bit more demanding and stresses the CPU a bit more, from testing results, as the other CPU stability program with error checking.
    I'll never be on par with TAT on C2duos
    And keep in mind that we are dealing with a random thing : sometimes an error will be generated, sometimes not. OCCT just stresses your CPU to make an error likely to happen... but the time it is detected and produced may vary. But you can be sure of one thing : you should always trust the program detecting an error. OCCT, SP2004, Prime95 can be trusted Others too, probably. That's up to your own judgement !
  20. #20
    teh 0wnage
    Dec 2004
    Hey is there anyway you can make the bootable cd version of occt public or send a link to people that want it?
  21. #21
    Mar 2005
    Imladris
    Quote Originally Posted by Tetedeiench
    Hey guys
    Thanks for a great stress testing program, been using it for years. Keep up the good work.
    The little air system that could.
  22. #22
    Xtreme Enthusiast Celcius's Avatar
    Dec 2004
    Texas
    Nice program
  23. #23
    Xtreme X.I.P.
    Aug 2004
    Chile
    awsome program, if you need help translation to spanish let me know
  24. #24
    Nov 2006
    Zagreb, Croatia
    Need to commend Tetedeiench for his contribution and efforts for making OCCT world wide known programme in stability testing.
    Few months ago, when he came to the biggest Croatian computer forum (didn`t even know how he found us, cause we aren`t well known) we were amazed by his effort to help us, by answering all the questions we had for him, about OCCT. We contributed by helping him in translation of the programme to our language.
    Now we are very proud to have such a programme translated in our native language.
    We wish that our cooperation continues in the future...
  25. #25
    Sep 2006
    P5WDH (66M MCH1.65) - 1801
    QX6700 @ 3.0G
    OCCT v1.1.0.09b
    - short 10min "custom" test
    - other temps measured with Fluke Mini 62 IR thermometer
ID:	54427   Click image for larger version.
    CURRENT: (mild OC)
