XtremeSystems Forums
Go Back   XtremeSystems Forums > Xtreme Teams > Xtreme DC Vault > Seventeen Or Bust (SoB)
Reply
Old 09-04-2006, 11:57 AM   #1
Martijn
Mr. Boardburner
Martijn's Avatar
Send a message via MSN to Martijn
SoB as a service: multiple instance how-to
Since some people had use of this information, I was asked to post this in public so that everyone could be helped with this.
So you wanted to run multiple instances of Seventeen or Bust? But you already tried loading up 2 or more of them manually from the same folder? That doesn't work for you, as you probably noticed. The two instances will both process the same proth test. This means you won't get ANY points at all, and you are just calculating for nothing.
It is time for the service install. It may sound quite difficult, but if you follow my steps, it really is very easy to do. Follow these instructions to install multiple SoB services: (and leave the ' ' when you need to fill anything in)
  • Download the SoB 2.5.0 Windows client (with service installer)
  • Install SoB as you would normally do
  • Configure the client to meet your preferences
  • Un-check the option: 'Auto-Start on Windows Boot', as the service will automatically start itself.
Now stop the entire client and make sure Seventeen or Bust isn't running any more. This is very important, or else your service install won't do anything at all.
  • Press the start button
  • Press 'run'
  • Type: 'cmd' to open a dos prompt
  • Now type 'cd\' to go to your system root
  • Type 'cd\Program Files\SB' to go to your SoB folder. If the path is different, fill in the path you installed it to.
  • Type 'sobsvc -i' to install the service.
If you want to load multiple instances, type this after you installed the service:
  • 'sobsvc -p:x', where x equals the amount of clients you want to load.
This is the amount of clients you can run on a CPU:
Single CPU: 1
Single CPU with HT: 2
Dual CPU/Dual Core: 2
Dual CPU, Dual Core/Dual CPU with HT: 4
I think you'll all understand that .
No make sure your service is running by restarting it:
  • Press 'run'
  • Type 'services.msc' and look for 'Seventeen or Bust Service'
  • Select the service and press restart to start the service straight away, or reboot your rig.
After you restarted the service, or restarted your rig, you should see x clients loading on your screen and minimizing towards your system tray. You have one light blue 'Seventeen' in your system tray for every client currently running. If they're running, the light blue 17 slowly turns dark blue.
As a last thing to check whether the service is installed correctly, open up all the clients, and check whether each client is calculating a different K/N value. If this isn't the case, please post in this thread and explain what you've done, because it should JUST work if you followed these steps.
Get CRUNCHING!!!
__________________
Main rig:
CPU: Xeon W3570 C0 ES @ 3.8Ghz (160x24, 1.35v)
Mobo: DFI UT X58 T3eH8
RAM: 12GB OCZ DDR3-1600 Platinum
GPU/LCD: GeForce GTX280 + GeForce 8600GTS (Quad LCDs)
OS: Intel X25-M G2 80GB
Apps: Spinpoint F1 1TB
Media/Storage: 2x Spinpoint F1 500GB, 1x Seagate 7200.11 1.5TB, WD MyBook 1TB (USB)
PSU/Case: BeQuiet 650W DPP, Silverstone TJ07
Crunching:
Server: Dual XeonLV s479 @ 2.0Ghz (up), Lappy: T9300 (up)
Badges:
Statistics are like miniskirts. Sure, they give you ideas, but they hide the essence of what we're doing.
Martijn is online now   Reply With Quote
Old 09-04-2006, 12:09 PM   #2
Martijn
Mr. Boardburner
Martijn's Avatar
Please post questions if you have them and I'll answer them as soon as I can.
__________________
Main rig:
Crunching:
Badges:
Old 09-04-2006, 12:18 PM   #3
Weedsqueezer
The 8 second kid
Weedsqueezer's Avatar
k i have 2.5.0 installed and running already... is the download you pointed to different?
__________________
Intel 6600 @3.8 ASUS P5W DH Deluxe, 2x512 Patriot DDR2 1000
Weedsqueezer is offline   Reply With Quote
Old 09-04-2006, 12:19 PM   #4
Martijn
Mr. Boardburner
Martijn's Avatar
If you have the version with the service installer, no. Have a look at what you downloaded.
EDIT: there is only one Windows version, and that's the one WITH a service installer, so no problems here.
Btw, I want this stickied
__________________
Main rig:
Crunching:
Badges:
Old 09-04-2006, 12:27 PM   #5
Weedsqueezer
The 8 second kid
Great guide Martin! You just won the sunshine award!
__________________
Old 09-04-2006, 12:29 PM   #6
Martijn
Mr. Boardburner
Martijn's Avatar
need to edit that line as folder is SOB
Am I missing something?
__________________
Main rig:
Crunching:
Badges:
Old 09-04-2006, 12:38 PM   #7
Weedsqueezer
The 8 second kid
i'll edit my remark...that's what it was on my rig. sorry. also. after reboot, the services started, but the icons didn't come up.
__________________
Old 09-04-2006, 12:41 PM   #8
Martijn
Mr. Boardburner
Martijn's Avatar
Never mind.
Your second note: that happens to me as well sometimes, if you want them to come up restart the service through services.msc as explained.
__________________
Main rig:
Crunching:
Badges:
Old 09-04-2006, 12:49 PM   #9
Weedsqueezer
The 8 second kid
got it thanks again
__________________
Old 09-05-2006, 03:02 PM   #10
feedmemonster
feedmemonster's Avatar
Send a message via AIM to feedmemonster Send a message via MSN to feedmemonster Send a message via Yahoo to feedmemonster
This is great info... Sticky?
__________________
Don't you want a piece of that PIE?!?!?
Sign up NOW to help find a cure for cancer and aids and have a great time doing it!
feedmemonster is offline   Reply With Quote
Old 09-05-2006, 04:06 PM   #11
[XC] riptide
Dak's Son
[XC] riptide's Avatar
Send a message via MSN to [XC] riptide
Couldn't have done it better myself. Yep, this is stickie material. (It could be stuck under MY sticky )
__________________
Originally Posted by 3Z3VH View Post
A fine line divides "Ghetto" and "Extreme" !
De gustibus non est disputandum
[XC] riptide is offline   Reply With Quote
Old 09-05-2006, 11:37 PM   #12
[XC]thewildblue
Ker-Pow !
[XC]thewildblue's Avatar
Stuck !!!
[XC]thewildblue is offline   Reply With Quote
Old 09-06-2006, 06:54 AM   #13
Martijn
Mr. Boardburner
Martijn's Avatar
Thank you!
__________________
Main rig:
Crunching:
Badges:
Old 09-13-2006, 03:22 AM   #14
[XC] riptide
Dak's Son
Do you ever notice the 'explorer.exe' process in task manager using more proc. power than it should? Say 5-8 %? Apparently thats a bug in the service install setup. If you adjust the Seventeen or Bust service to not 'interact with desktop' this proc usage will go down to normal levels for 'explorer.exe' Might add that to main sticky too!
__________________
Old 09-20-2006, 07:37 PM   #15
bullet2urbrain
Xtreme Cruncher
bullet2urbrain's Avatar
Send a message via AIM to bullet2urbrain Send a message via MSN to bullet2urbrain
so i did this, and when i restart the service the 2 icons show up. but they never start running, and when i move the mouse over them they disappear like the service is magically killing itself.
anythoughts??
__________________
bullet2urbrain is offline   Reply With Quote
Old 09-20-2006, 11:28 PM   #16
Martijn
Mr. Boardburner
Martijn's Avatar
Are you sure you disabled the automatic start in the SoB clients themselves?
__________________
Main rig:
Crunching:
Badges:
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Powered by vBulletin® Version 3.7.0
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
XtremeSystems
