Results 1 to 22 of 22
Thread: A truly STUNNING article on burning in...
    Technician
    Jun 2002
    Merseyside, UK
    Ive just been searching around the web for theories on the best methods of burn in. During this search I found a terrific article that explains what actually goes on, and hints at the correct technique that should be applied.
    Its quite an old article by the look of it - it seems to have been written at the start of the P3 era, but the points and theory are still very much valid.
    Take a look, at the very least itll give you something ot argue over, at best itll educate you . I know I certainly learnt from it.
    Kudos to the author!
    http://people.freenet.de/s.urfer/conditioning.htm
    PiLsY.
    Jan 2003
    excellent stuff.. definitely a good read
    Dec 2002
    I've always thought that it was due to thermal compound being a viscous fluid that under pressure and high temperature would flow more quickly. Thus at high temperatures it would reach an optimum thickness more quickly.
    I suppose this would be easy to test by reseating your heatsink after a burn in with noticeable effects.
    Technician
    Jun 2002
    Merseyside, UK
    Well I changed heatsinks (and thus compound) a fair few times on my cpus and have never noticed that I need to burn in again. Infact ive usually replaced with a better heatsink and noticed a small but noticeable boots in clockspeed over my previous stable.
    Its definitely the cpu thats improving and not anything else. You get burn in improvements from motherboards and memory that wouldve burned in (or out in my case lol) long ago.
    PiLsY.
    Xtreme Legend
    Jun 2002
    Belgium / Denmark / Russia
    running 2.22 Vcore, 800 MHz (coming from 2500), and about -10/-15C core temp under load , programs used are Toast (strong stuff), Prime95, FAH all at the same time, but toast is getting 99.9% of the cycles it seems
    wonder if it'll help
    Technician
    Jun 2002
    Merseyside, UK
    JC - I find that you need to use programs together which use unused cpu cycles. FAH and Prime are a good combo, with each getting roughly 50% cpu usage. CPU temp is higher than when running either of them on its own, and even higher than toast. Under FAH i get cpu temps of 53c, under Prime95 I get 57c and with both together its been up as high as 64c. To me this would indicate that every single part of the cpu is being pushed to the max.
    This is at 1733mhz / 2.2v btw. I was going to do it at 667mhz, but I really couldnt use my pc with it clocked that low. Games and other stuff were really choppy. I dont think the heat thing is as relevant now. That was written around the P2 450 time - those things ran at up to 120c under load .
    Anyway, my 48 hours was up 3 hours ago, but ive got some stuff to do atm. Will get round to testing if it worked a bit later.
    PiLsY.
    Xtreme Legend
    Jun 2002
    its a shame I have to shut this thing down overnight... but it"ll still be the same effect if I just continue tomorrow I hope?
    btw, I'm using prime, FAH and toast at the same time now
    Technician
    Jun 2002
    Merseyside, UK
    Toast will probably take all the cpu cycles m8, so it wont actually be running FAH and Prime, only toast. The point in running FAH and prime is that they work out different areas of the cpu, essentially meaning that the whole cpu gets a strong burn in. If I were you I would forget about toast and just run FAH and Prime .
    PiLsY.
    Xtreme Legend
    Jun 2002
    i'll do that cheers
    also looking if I can find another proggy able to "share" the CPU time rather than take it all up.... even by playing with the priorities it can be difficult
    Technician
    Jun 2002
    Merseyside, UK
    You can do it via the registry m8. Give me some time to look into it as its a while since ive done it. Cant remember exactly how atm. Will play about a bit and get back to you.
    PiLsY.
    Nov 2002
    Earth: The Insane Asylum of the Universe
    Well, I found this thread at the perfect time, since I have 3 new chips coming. I'm also glad I read about Prime95. If I should happen to get lucky, I'll remember you guys.
    c[_]
    Nov 2002
    Alberta, Canada
    Prime, Folding, seti.
    All along the watchtower the watchmen watch the eternal return.
    Technician
    Jun 2002
    Merseyside, UK
    For some reason seti takes no cpu time off either prime or folding. It seems to force itself to a lower priority, no matter what you set in task manager. Its odd as it should give you an even 3 way balance, but it doesnt .
    Still havent found the registry hack for cpu load prioritising. Its been too long since ive done it, think I may have to admit defeat.
    PiLsY.
    Jan 2003
    Leicester UK
    A great tool for burning in CPUs is HOT CPU TESTER,can be bought for just $20 runs all these tests SIMULTANEOUSLY.
    Complex Matrix
    Calculating Pi
    Quick Sort
    Prime Test
    Chipset
    L1 Cache
    L2 Cache
    Memory
    Peripherals
    MMX
    SSE
    3DNow.
    I've been burning in at 500MHz(100MHz FSB) with vcore of 2.25v(My board overvolts), vdimm of 2.9v and VAGP of 1.8v(I set AGP frequency to 50MHz also.
    So I'm burning in my whole system ATM. Hot CPU tester does a good job of testing ALL parts of the CPU with just one program.
    I highly recommend you people try it
    Jun 2002
    I dont recommend running below stock speed, for starters, it renders your machine useless during this "burning in" period.
    The best way i've found, is to run max volts / stock speed during the night (when your in bed), and run your normal day speed minus 0.25 Vcore. Repeat.
    Set me free.
    A64 3200 @ 2250mhz (10x225 @ 1.6v) | Chaintech ZNF3-150 | 2x 256mb Corsair 3200LL TwinX @ 2.5-2-2-7-12-16 | 256mb Albatron 5950 VIVO | 80gb DiamondMax 9 | Pioneer 106 | APC 2200RMI3U UPS
    k|ngp|n/Sham my brothers
    Aug 2002
    Athens---Hellas
    Complex Matrix
    Calculating Pi
    Quick Sort
    Prime Test
    Chipset
    L1 Cache
    L2 Cache
    Memory
    Peripherals
    MMX
    SSE
    3DNow.
    I run this proogie and I asure you that it's a VERY HEAVY stuff for ALL your rig......Very heavy indeed....!!!!....
    INTEL PWA FOR EVER
    Dr. Who my arss...
    Nov 2002
    Back in London
    Generally i tend to take the flipside approach when burning in new chips (no way would i stick 2.2v up a brand new cpu its asking for trouble)
    1. Burn in @ stock mhz and volts for 1day
    2. Burn in @ max oc mhz at stock volts for 1day
    3. Burn in @ max oc with increased voltage 1day
    4. Burn in @ max oc max voltage 1day.
    For step 2 i generally use the biggest bootable, stable for 10min overclock, set the pc to reboot every 5 or so minutes and put toast in the start up folder, after a day of doing that i find the overclock is permentatly stable at that voltage.
    ]JR[
  18. #18
    Dec 2002
    Jersey City, NJ USA
    hrmph. PiLsY and JC, you guy's suggest running cpu at half stock and max volts for burn in? I have never tried this, but would be worried at giving my cpu 2.2 volts right now with air cooling. Is this voltage ok as long as you don't keep it there for extended periods of time? Also FAH and Prime only work out the cpu right? What do you suggest to burn in Ram?
    | MSI K8N Diamond Plus | WaterCooled A64X2 4200+ | 2x1024 PC4000 EB Plat | 2x BFG 7800GT | Maxtor DMax 10 SATA 250gb 16mb cache & 200gb 8 mb cache| OCZ 700watt GamerXtreme PSU | Plextor 716SA DL DVDRW
    HeatWare
  19. #19
    Oct 2002
    Personally i think its a bunch of poop out of the 100 or so cpu's i have had. Not 1 has benefited from it.
    You mine as well burn in yor psu and keyboard too
    imo of course.
    heres a burn in guide for ya btw.
    www.afrotechmods.com/burnin.htm
  20. #20
    Jul 2002
    [M] - Belgium
    we do
    slam your new keyboard with your fist 10-20 times a day, during the 1st week
    and connect 10x 120mm fans to your PSU for burn-in, let the fans run until your hair start to grow backwards on your head instead of up
    Belgium's #1 Hardware Review Site and OC-Team!
  21. #21
    Nov 2002
    Mountains of N. AZ.
    LOL, jmke!!
    Thanks for the linkage, Pilsy, gonna start this when I get outta work today.
    so, you want to run low clockspeed with the max voltage you can, but keeping the heat down as much as possible, yes?
    2.5 ghz 250 HTT
    Winnie 0449 CHBBD MPM stock HSF 1.4v
    9NDA3j rev 2.1 2/15/05 bios
    2gb Corsair TwinX XMS @ 2.5-3-2-7, 2.6volts.
    eVGA 6800GT @ 380/1.06 stock
  22. #22
    Technician
    Jun 2002
    Merseyside, UK
    Yep. I wouldnt use above 2v with a Tbred though. Mine seems to have actually got worse if anything by running that high a voltage (2.2v).
    PiLsY.
